off road/sandy beach capability - JeepForum.com
post #1 of 8 Old 12-09-2010, 07:23 PM Thread Starter
drjohnm
I am new to the forum and new to the world of Jeep. I just purchased a 2011 Grand Cherokee 4x4. It has the basic 4 wheel drive, not the upgraded manual switch set up. (quad track?). The dealer assured me that it will be fine in the sand, but I am concerned. My ford escape has a setting for 4 wheel 'low' which I use in the sand without a problem. Any experience on this out there?thanks.
drjohnm is offline
post #2 of 8 Old 12-09-2010, 07:31 PM
XJDitchbanger
My experience with this type of 4wheel drive has not included driving in sand; but the only times I have ever switched to "low" is in mud and deep snow at very low speeds. it does not allow you to go as fast as I would assume you would want to in sand
XJDitchbanger is offline
post #3 of 8 Old 12-09-2010, 07:33 PM
XJDitchbanger
Sorry, I never answered your question: I think it will do great in sand, however you probably don not need to drop into low unless you get stuck and need that little extra torque
post #4 of 8 Old 12-09-2010, 11:49 PM
Tru2Chevy
Tru2Chevy's Avatar
1992 XJ Cherokee
The biggest thing that will help you get through the sand will be airing down the tires, not some fancy 4wd setting. Drop tire pressure down into the teens if you are gonna be spending some time on the sand, and drive with your head.
- Justin
1992 Cherokee Laredo - all stock, DD. Needs some minor rust repair, then on to the mods!
1996 Cherokee Classic - 3.5" lift / 31.0x10.5 Mastercraft Courser CTs / Warn XD9000i - Stripped for parts / junked :(
2004 Grand Cherokee Laredo - 4.7, bone stock - Wife's DD
Tru2Chevy is offline
post #5 of 8 Old 12-10-2010, 08:57 AM
Technohead
^ What he said. Airing down is critical to running in the sand, especially soft sand. To a degree it depends on your tires/wheels but I normally air down to less than 10 psi. It makes a HUGE difference.
-Eric
Technohead is offline
post #6 of 8 Old 12-10-2010, 09:04 AM
Toms87
1987 YJ Wrangler
Can you air street tires down that low without losing a bead?
Toms87 is offline
post #7 of 8 Old 12-10-2010, 10:51 PM
gojeepgo
1981 CJ7
Airing down to around 15psi will be fine for the sand. You just want to make the footprint wider. You dont need to go much lower than that for sand.
gojeepgo is offline
post #8 of 8 Old 12-11-2010, 08:52 AM
Technohead
I have. And like I said it makes a huge difference. 15 is certainly better than 30 but the lower the better. If you can't see the sidewall bulging then you are still too high.
-Eric
sandy neck beach cape cod reconvet88 Massachusetts Jeep Forum 11 06-22-2011 09:33 PM
Good off road shop in Virginia Beach area. drbomer Virginia Jeep Forum 8 03-05-2011 04:05 PM
Jeep Beach in Daytona Beach FL. mnypitZJ Florida Jeep Forum 4 01-24-2010 07:43 PM
Sandy Neck allanmacaulay North East USA 0 08-30-2008 10:01 PM
