Hudson Valley - Page 78 - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > North East USA > New York Jeep Forum > Hudson Valley
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge BushingsStainless Steel Door Hinge Pins
Unread 10-01-2009, 07:02 PM   #1156
Kenbo-Slice
Yes James, I'll be at the next HV4W meeting. We haven't set up any plans for wheeling there again as of yet, but I am pretty sure that I can get the parking at the shop without a problem. We can talk more about it at the meeting if you guys want.
Kenbo-Slice is offline   Reply With Quote
Unread 10-01-2009, 09:08 PM   #1157
mgtsldr
Originally Posted by sentinal02 View Post
so you're dealing with 7 degrees of positive camber? that sounds kind of weird because the load on the axle will usually bend the tubes the other way, creating a negative camber angle. the ground pushes up on the tires while the weight of the jeep on the springs pushes down on the tube to make the axle bow like a smile when looking at the jeep from front or back. just like walking on a board supported at the ends. in order to bend the other way, the forces would have to reverse and short of landing the tubes on a rock or stump oir something like that a couple times I can't see how you would bend the axle that way to get the kind of angles you're looking at. have you checked the ball joints and the hub bearings?
Yea its wierd, but all the ball joints and everything were replaced before I put the axle in. Maybe I did something wrong?
And whens the next HV4W meeting?
94 wrangler - flat black, 350 SB, 44/60, SOA, 35" boggers, 36" military specs, 39" mickey thompsons
mgtsldr is offline   Reply With Quote
Unread 10-02-2009, 04:13 AM   #1158
YJames90
aka Jamesx2
YJames90's Avatar
Oct 19 2009, Mon, 7:30PM
Originally Posted by timatoe View Post
SOA is completely out of you're league at this point.
Originally Posted by JeeperDon View Post
Some Jeepers can do some of the mods some of the time, but not all Jeepers can do all the mods all the time. :cheers2:
My 2.5 to 4.3 swap thread
http://www.jeepforum.com/forum/f12/4...begun-1237704/
YJames90 is online now   Reply With Quote
Unread 10-02-2009, 05:13 AM   #1159
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Make sure the unit hub is seated cleanly against the knuckle, with the three bolts holding it tight. If it is coc.ked, that will do it. I would pull the tires and brakes, and the hub to verify the problem angle is actually the knuckle.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline   Reply With Quote
Unread 10-02-2009, 06:46 AM   #1160
mgtsldr
Thanks, Ill have to take a look at it when I get home this weekend. I cant be messing with the jeep for too much longer, its almost time to bring the sleds in the garage!
Unread 10-02-2009, 09:20 AM   #1161
Kenbo-Slice
Moving the sleds around to squueze the jeeps in has never stopped us before!!!
Unread 10-02-2009, 11:14 AM   #1162
mgtsldr
hahaha, very true!! hows everything going on the Jeep? Ill be home this weekend if you got anything you wanna try to work on.
Unread 10-02-2009, 12:28 PM   #1163
Kenbo-Slice
I have a lot to do on my Jeep haha, just nothing quick, cheap or easy.... Haha. I'll be down in westchestahhhh this weekend though. I think I'm gonna pull the trigger on the clayton longarm next month. So everything else will be put on hold for a little bit.
Unread 10-02-2009, 12:30 PM   #1164
YJames90
aka Jamesx2
YJames90's Avatar
What about planning that bank hiest in town tomorrow?
Unread 10-02-2009, 12:41 PM   #1165
Kenbo-Slice
How else am I supposed to build up my Jeep? Haha
Unread 10-02-2009, 12:48 PM   #1166
_TIM_
I plan on winning a million dollars to build my Jeep.....that way I can still have my Jeep instead of being in jail....
1998 tj|chili pepper red|
_TIM_ is offline   Reply With Quote
Unread 10-04-2009, 07:59 PM   #1167
mgtsldr
Ill take my jeep to jail with me!
Unread 10-05-2009, 04:04 PM   #1168
McMottTJ
Hey guys and gals I have read about 3/4 of all the pages, I have been looking about info on where I can take the jeep wheelin for free and within an hour of Middletown, I am from mount hope and am bring my jeep back to NY for the first time, I was think of going to the lead mines down in wertburo but I dont know how that would go over, I have heard thru the grape vine that its ok, I know I use to ride my dirt bike their but who knows anymore.
any help would be great thanks everyone.
McMott
McMottTJ is offline   Reply With Quote
Unread 10-05-2009, 07:53 PM   #1169
Irongrave
nothing legal thats free that I know of unless you know some one with land
2006 Ram 1500, towhore, intake tune 285 70 17 KM2s 2001 18' Parker, crawler hauler
1997 TJ, Dad's Claytons 4:88s and stuff A TJ for Dad
1992 YJ crawler, getting 60s. Build thread the illusion of progress
North Jersey Jeep Club, AtoZ Fabrication, Rozzo Fabrication
Irongrave is offline   Reply With Quote
Unread 10-05-2009, 08:31 PM   #1170
Kenbo-Slice
Oh **** Irongrave, I forgot to call you this weekend. I was in Westchester all weekend but I was busy as hell with my girlfriend. Did you get it all taken care of?
