Hudson Valley - Page 520 - JeepForum.com
post #7786 of 7919 Old 10-25-2013, 07:28 PM
YJames90
YJames90's Avatar
thats what we are here for. glad your ok
My 2.5 to 4.3 swap thread
YJames90 is offline
post #7787 of 7919 Old 10-26-2013, 02:44 PM
Bear94
Bye bye fenders! Thanks for the idea James
Sent from my smartassphone using whatchamacallit
Never force anything... Just get a bigger hammer.
[_]IIIIII[_]
Craigslist is my Quadratec!
Bear94 is offline
post #7788 of 7919 Old 10-26-2013, 04:22 PM
YJames90
YJames90's Avatar
You've done good kid!
YJames90 is offline
post #7789 of 7919 Old 10-26-2013, 04:35 PM
jeepmischief
If everyone is gonna do it, I'll put mine back on!! Lol
jeepmischief is offline
post #7790 of 7919 Old 10-27-2013, 07:43 PM
ScrimpsZJ
Hey guys, does anyone have JKS Quick Disconnects that are laying around and wouldn't mind selling?
ScrimpsZJ is offline
post #7791 of 7919 Old 11-01-2013, 07:53 AM
Lincolnwelding
Dang i finally find some new york jeep meet ups and of course their 3 hours away like everything else.
Must. Leave. Binghamton.
"Piper, theres a big difference between wingin it, and seeing what happens"
Want to change my forum name to jeep wheelikers
WJC #292
Lincolnwelding is offline
post #7792 of 7919 Old 11-01-2013, 10:01 AM
mmmanimalfat
When removing front sway bar end links on a tj can I just unbolt them from the sway bar and flex out the suspension (by driving it) or do I really need a ball joint tool to get them out?
mmmanimalfat is offline
post #7793 of 7919 Old 11-01-2013, 10:16 AM
biffgnar
biffgnar's Avatar
If you have stock links the ball joint is connected to the swaybar with a tapered bolt. You have to do a little work to get it out. There are plenty of threads in TJ Tech that discuss. Go there, search and read.
Why are you removing the links? Driving a TJ at speed on the road without the swaybar connected not a great idea.
Romney in 2020!
biffgnar is offline
post #7794 of 7919 Old 11-01-2013, 10:24 AM
mmmanimalfat
Originally Posted by biffgnar
If you have stock links the ball joint is connected to the swaybar with a tapered bolt. You have to do a little work to get it out. There are plenty of threads in TJ Tech that discuss. Go there, search and read. Why are you removing the links? Driving a TJ at speed on the road without the swaybar connected not a great idea.
Yeah, I read everything from use ball joint tool to use a big hammer. It just seems that if you unbolt the link from the swaybar and let the suspension sag, the weight if the droop would pull it apart.
My front drivers side link flexes at the top bushing where it connects to the swaybar and needs to be replaced. I think I'm going to get my hands on some jks disconnects.
post #7795 of 7919 Old 11-01-2013, 10:51 AM
biffgnar
biffgnar's Avatar
The tapered bolt is in there tight and remember the bar will move as the suspension cycles so the arms will just come down. You'll separate the ball and socket well before you pull the tapered bolt out.
Romney in 2020!
biffgnar is offline
post #7796 of 7919 Old 11-01-2013, 11:34 AM
mmmanimalfat
Well that makes sense. Thanks. I guess I'm renting the tool then. Maybe while I have it I'll finally replace my leaky steering box that's sitting in my garage!
Thanks again.
post #7797 of 7919 Old 11-01-2013, 05:45 PM
mmmanimalfat
Does anyone have experience with this type of swaybar disconnect? Or can anyone tell me what brand they are. I've noticed that most have the pin location as the lower mount, while this is just above, disconnecting the link bar itself. Just curious if there's a difference?
Thanks.
post #7798 of 7919 Old 11-05-2013, 04:12 PM
00XJMikey
Thanks.
Looks like a stock link modified into a disco link.
00XJMikey is offline
post #7799 of 7919 Old 11-05-2013, 05:13 PM
biffgnar
biffgnar's Avatar
Stock links have a ball and socket joint on one end.
Romney in 2020!
biffgnar is offline
post #7800 of 7919 Old 11-05-2013, 05:48 PM
mmmanimalfat
The closest I could find is like and older version of rough country or skyjacker. Either way, they didn't cost me anything so they are better than my broken stock ones. Plus, I'll have some fun with them. Don't know why it posted this picture. I had one with the headlights off. You could see my poser flex better. I was running out of daylight.
Legal playgrounds in Hudson Valley NY 96-XJ North East USA 11 01-10-2010 01:44 PM
Hudson valley help, sadass North East USA 10 12-14-2008 08:49 AM
Panamint Valley - Dec 19,20,21 L8 APEKS California Jeep Forum 0 12-13-2008 06:47 AM
Johnson Valley 1whitetj California Jeep Forum 1 12-11-2008 07:38 PM
Hungry Valley 12/29/07 jrod196 California Jeep Forum 11 01-02-2008 03:56 PM
