Hudson Valley - Page 500 - JeepForum.com
post #7486 of 7919 Old 06-02-2013, 08:41 PM
mikd
2009 JK Wrangler
What do you think of putting the log bridge where the current go around for the stream is?
mikd is offline
post #7487 of 7919 Old 06-03-2013, 11:47 AM
Dodgethis
I may be in haha
Dodgethis is offline
post #7488 of 7919 Old 06-03-2013, 01:17 PM
YJames90
YJames90's Avatar
thats probably the best spot for the added fear factor.But,,, the only problem with that spot is the traffic jam it creates. With 2 obsticles in the same place it may cause a bottle neck.
We can easily make a log bridge connecting 2 mounds of dirt or bridgeing 2 stone walls
My 2.5 to 4.3 swap thread
YJames90 is offline
post #7489 of 7919 Old 06-03-2013, 01:37 PM
mikd
2009 JK Wrangler
It is def a funnel point and the lack of parking is a constant. There is plenty of space to add a 2nd go around and room needs to be cut to park on the sides of the trail if this is going to work. Seems doable?
The logs would be about a foot above the water which is only about a foot deep so the height seems about right.
mikd is offline
post #7490 of 7919 Old 06-03-2013, 01:47 PM
mikd
2009 JK Wrangler
For those reading this, we are not wheelin this weekend. After we get a couple of new obstacles set up we'll have a wheelin day.
mikd is offline
post #7491 of 7919 Old 06-03-2013, 03:59 PM
_TIM_
Progress. Ill be wheelin real soon
1998 tj|chili pepper red|
_TIM_ is offline
post #7492 of 7919 Old 06-03-2013, 04:24 PM
mikd
2009 JK Wrangler
Tim, you swapped your frame right? Looks to be pretty close then, time to get it back over here and test it out!
mikd is offline
post #7493 of 7919 Old 06-03-2013, 04:56 PM
_TIM_
I actually cut and patched the rot and replaced the UCA brackets and rear coil perches. I also had to replace 8 of the body mounts on the tub. Lots of fun. Couple more weeks and I should be good to go. Can't wait to see what it can do!
_TIM_ is offline
post #7494 of 7919 Old 06-03-2013, 05:35 PM
papod
instead of sonic for the meet and greet, would you guys want to meet in beacon at healey brothers for food and possibly more?
papod is offline
post #7495 of 7919 Old 06-03-2013, 07:03 PM
YJames90
YJames90's Avatar
Yes but we already have plans to be there for coffee and cars. If you dont mind having us twice Im up for it.
RTI ramp and car crushing?
We can eat alot of dogs and burgers
let me know asap.thanks
YJames90 is offline
post #7496 of 7919 Old 06-03-2013, 07:30 PM
papod
last sunday in june possibly? jeeps , cars, trucks, fjs. or whatever.i will work on the ramp and maybe some other things, let me know if enough are interested
papod is offline
post #7497 of 7919 Old 06-03-2013, 07:52 PM
YJames90
YJames90's Avatar
If you can do it we are there June 30th. Thanks Pat!
YJames90 is offline
post #7498 of 7919 Old 06-03-2013, 08:58 PM
biffgnar
biffgnar's Avatar
Going to have an HP30 out of a TJ for sale in a few weeks (just bought the replacement). Will not be posting in classifieds till its actually out of the jeep but figured I'd mention it here to give locals a first look. Here are specs:
4.88 gears (originally setup by East Coast Gear Supply)
Axle has about 1 yr/15k miles of use, everything was refreshed new before it was put in
Timken Unit Bearings
Spicer Ball Joints
Spicer 5-760 Ujoints with full circle C clips
Superior Evolution Chromolly Axle Shafts - 30 spline inner/27 spline outer
ARB air locker
15" Vanco Big Brake Kit w/Black Magic Pads
Barnett Differential cover
USA alloy axle seals
Johnnie Joint conversion on axle side upper control arm mounts
Axle side lower control arm brackets boxed with Currie miniskids
U bolt pinion yoke
Lower half (spring pad) of Currie bumpstop kit
Lower shock mount refabbed for eye mount shocks
Swaybar links raised to allow for driver's side tie rod flip
Driver's side knuckle drilled and with tapered insert for tie rod flip
Have to give some thought to what $$s I'll want for it. If you add all that stuff up even if you do the work yourself its not going to be cheap to replicate that.
Romney in 2020!
biffgnar is online now
post #7499 of 7919 Old 06-04-2013, 04:05 AM
mikd
2009 JK Wrangler
Sick rhino in the avatar pic! Is it yours?
mikd is offline
post #7500 of 7919 Old 06-04-2013, 08:17 AM
biffgnar
biffgnar's Avatar
Belongs to a friend of mine in Texas. He's put a lot of time and money into it. Races it in many of the west coast desert races. Picture is us doing about 60 across the Baja desert in the NORRA Mexican 1000.
Romney in 2020!
Legal playgrounds in Hudson Valley NY 96-XJ North East USA 11 01-10-2010 01:44 PM
Hudson valley help, sadass North East USA 10 12-14-2008 08:49 AM
Panamint Valley - Dec 19,20,21 L8 APEKS California Jeep Forum 0 12-13-2008 06:47 AM
Johnson Valley 1whitetj California Jeep Forum 1 12-11-2008 07:38 PM
Hungry Valley 12/29/07 jrod196 California Jeep Forum 11 01-02-2008 03:56 PM
