Blair county. - Page 4 - JeepForum.com
post #46 of 165 Old 12-29-2012, 03:15 AM
chriswj
yea i can help but i would have to give a better look see at it thats gonna be a b!tch around that control arm bracket but i think i could do it. As long as the metal inside that bracket is good it should be no problem
2000 Wj in the works taking donations daily!!
chriswj is offline
post #47 of 165 Old 12-29-2012, 09:08 PM Thread Starter
tj1997tj
Thanks , I'm concerned about that also. See what the weather and this cold thing brings and see what happens. i pulled the remainder of my belt from underneath the jeep today so I can get a replacement. Wonder why that happened ...... rest of the belt looks good
tj1997tj is offline
post #48 of 165 Old 12-30-2012, 06:28 AM
PA_YJ19
Usually because a pulley is locked up, so the belt tries to move over it neway, causing it to tear. Normal culprits r power steering pump and alternator, but could just b a worn belt. Could b dry rotted n the cold made it worse...
PA_YJ19 is offline
post #49 of 165 Old 12-30-2012, 11:34 AM Thread Starter
tj1997tj
yup ...... its the alternator pulley.
ya know ....... they wasn't kidding about "just empty every pocket" where they?
at this rate i'll never be able to toss money at the good stuff like lockers and shocks , winches , etc , etc.
wouldnt be to bad if it was summer but its a little to cold and im a little to sick to be doing this crap outside , thinking i just may pull the battery and say screw it until spring gets here
tj1997tj is offline
post #50 of 165 Old 01-07-2013, 11:31 PM Thread Starter
tj1997tj
should be back off road shortly. The belt that is called for did not fit ..... it was the correct listed belt but about 4 or 5 inches too short. it was the same as the belt that had broke but they must not have had it run correctly to fit it on , can't say tho cause i never actually traced the belt before it broke but think they may have bypassed an idler ..... have someone to do the welding ..... it's saveable and the rest of the frame is still good even the pass side rear trailing arm.
tj1997tj is offline
post #51 of 165 Old 01-08-2013, 07:57 PM
squareeyes
let me know when you get back on the trail tj1997, we'll get together and hit some trails, only been doin this for about a year dont know any one in the area that goes muddin , or many places to go hope to hear from ya or anyone else
squareeyes is offline
post #52 of 165 Old 01-09-2013, 04:56 PM Thread Starter
tj1997tj
I will be sure to do that.
tj1997tj is offline
post #53 of 165 Old 01-14-2013, 07:52 PM Thread Starter
tj1997tj
Well, frame is fixed. Just Had a fresh sticker put on it and it's time to wheel. "Kind of" wheelin wednesday and deff on thursday , not sure where i'm going. Mostly just bummin around here/there. Thursday will be taking off about 9am'ish
tj1997tj is offline
post #54 of 165 Old 01-17-2013, 04:31 PM Thread Starter
tj1997tj
went , saw and concurred x2.
probably too buy too wheel until next week
tj1997tj is offline
post #55 of 165 Old 01-25-2013, 07:57 PM
PA_YJ19
Ne one up for ne snow wheeling tomorow? I feel like beating on the heap...
PA_YJ19 is offline
post #56 of 165 Old 01-27-2013, 10:09 AM
PA_YJ19
Found a county map of Bellwood that has a jeep trail marked on it. Goes thru game lands but I no there r no gates in this area, i plan on going to check it out in the next couple weeks if ne1 is up for it.
PA_YJ19 is offline
post #57 of 165 Old 01-27-2013, 10:11 AM
chriswj
if i have any gas money when it comes time im game
chriswj is offline
post #58 of 165 Old 01-27-2013, 11:18 AM
PA_YJ19
Alright lemme no, I'm in no hurry its not going newhere. U get ur transfercase workin right yet?
PA_YJ19 is offline
post #59 of 165 Old 01-27-2013, 12:30 PM Thread Starter
tj1997tj
I'd be game to go. Hoping to hook up with square eyes soon but I can't do anything if it's too icy in the woods , that tj slides around like a freakin tobaggan. Even on wet pavement I got to be careful.
Mud/rocks/dirt ..... o.k , slippy stuff ... not so much.
climbed an unknown road the other day and got to the point that backing down would not have been good so had to finish the climb, turn around and come down ............ , ended up in a spot where you need to brake but can't and that's not where I like to be. So I'm being careful at the moment.
tj1997tj is offline
post #60 of 165 Old 01-27-2013, 06:01 PM
PA_YJ19
Cool we can wait til the snow melts, I'm going to go check it out and see if it really exists before I have us all meet up down there. My buddy lives right by it n tells me there is one that goes the wholeway up the mountain but he has never been that far on his go cart lol but according to him it should exist. The map I have was drawn by the county and is marked 2009.
PA_YJ19 is offline
