Alignment shop recommendations KC area - JeepForum.com
post #1 of 9 Old 02-24-2013, 07:31 PM Thread Starter
bwpilot20
Tj Alignment shop recommendations KC area
Just lifted my TJ 4 inches and have adjustable control arms and track bars. Anybody know of a good shop that will know what they're doing with a lifted jeep around the KC area or even anywhere nearby?
bwpilot20 is offline
post #2 of 9 Old 03-02-2013, 11:38 AM
unabashedpraise
I've never used them, but i would go to chux trux.
1998 Grand Cherokee Limited; 5.2 L, 249
Help: Rear left lock doesn't lock using power locks, but will unlock. Any ideas?
unabashedpraise is offline
post #3 of 9 Old 03-05-2013, 08:01 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Chux trux will rob you blind. Take to a local shop that does alignments that will provide you a printout of the specs.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #4 of 9 Old 03-06-2013, 04:17 PM
unabashedpraise
That is good to know. They are the only off road type shop i know of. Tires plus in Raytown was ok. They jacked everything up the first time, but the manager Brian made it right.
post #5 of 9 Old 03-09-2013, 10:00 PM Thread Starter
bwpilot20
Chux Trux wanted $180 for a 4 wheel alignment. I ended up going to a shop in Columbia called Midwest autoworx that let me go in the shop and help with the alignment since all my control arms are adjustable. They would have got it right without me but they weren't sure how to adjust my savvy double adjustable arms and tried to dial my caster back to the factory 7 degrees that the hunter machine wanted. I interjected and told them to set the caster to 5.5 and everything worked out great. Best part was it only cost $75 and it was so nice that they let me stand there and make sure the arms got adjusted correctly. I didn't need a printout since I saw firsthand what the settings were. If anyone needs an alignment I'm sure they would let you do the same if you tell them you have a custom suspension like I did. The guys knew what they were doing it just saved a test drive with me there to give them an idea what the specs should be close to after the lift.
post #6 of 9 Old 03-19-2013, 02:46 PM
JeepN4KC
JeepN4KC's Avatar
Awesome Glad to hear you got this done right and for a good pricetag!
~Mike~
WK
XJ
JeepN4KC is offline
post #7 of 9 Old 03-24-2013, 06:19 PM
benneplex
http://www.4x4land.com/
These guys in Topeka have always been good to work with. I know that they aren't exactly in KC but worth the drive in my book.
benneplex is offline
post #8 of 9 Old 03-26-2013, 11:17 PM Thread Starter
bwpilot20
I'm thinking of using 4x4 land when I swap gearing in the future. They seem to be the only legit 4x4 shop anywhere close to KC.
post #9 of 9 Old 03-27-2013, 08:29 PM
JeepN4KC
JeepN4KC's Avatar
If you're gonna regear and you either can't do it or don't know anyone who can - don't just think about going to 4x4 Land. Just plan on going there. Mike Starkbaum knows his ****.
~Mike~
WK
XJ
JeepN4KC is offline
