Overheating engine 304ci - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South Central USA > Texas Jeep Forum > Overheating engine 304ci
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 07-01-2015, 11:38 AM   #1
heyseg
1973 C104
I know this is long, but some history...
Installed a long block from reputable frim. Ran well through the fall. brought home from hunting camp for the summer, and to do a few modification to elecrical system. Started running hot. Radiator was cleaned and new water pump and thermostat during new block install.
Have flushed cooling system, installed new fan clutch and additional auxillary electric fan.
Tested radiator cap and radiator, no leaks. left tester on radiator and started motor, pressure in radiator begins to build.
Not a large amount, several pounds per minute. Pulled each plug with the thought that if blown / leaking headgasket, could determine which cylinder was leaking, pressure built, no matter which plug was pulled.
Any ideas on problem,
Thanks in advance,
Heyseg
heyseg is offline   Reply With Quote Quick reply to this message
Unread 07-04-2015, 07:26 PM   #2
ossj7
I would try the thermostat. They go bad all the time, I buy the fail safe ones. A little more expensive ,but they fail open.
ossj7 is offline   Reply With Quote Quick reply to this message
Unread 07-06-2015, 07:28 AM   #3
heyseg
1973 C104
Thanks,
Will give it a try.
Heyseg
