Moving to Texas, odd emmisions question, - JeepForum.com
post #1 of 6 Old 11-11-2013, 08:04 PM Thread Starter
Dysan
I will be moving to the Houston area and I know they do emmisions testing. Now I wonder if having a quick disconnect for the battery would affect the test. I have the quick disconnect because I have been having electrical issues that I have been trying to diagnose for the past six months and installed the quick disconnect to make it easier to disconnect the battery. I will hopefully fix the electrical issue before the move, but wanted to now if the quick disconnect will affect the emmisions test.
Dysan is offline
post #2 of 6 Old 11-11-2013, 08:31 PM
ttusqrl
2005 WK
No reason I could see this affecting emissions as it doesn't do anything from a testing perspective. They toss a sniffer in the exhause, check the gas cap, and that's about it.
2005 WK 5.7 ORT | Mod SL (OME struts & 990s) | JBA UCAs & Discos | Saguaro Front Bumper | Warn Zeon 10s | 285/70/17 BFG TA KO | AIRAID CAI | Gibson 3" Exhaust | DiabloSport Intune | JL Stealthbox
ttusqrl is offline
post #3 of 6 Old 11-11-2013, 11:21 PM
mitchlandry
Only foreseeable issue would be that disconnecting the battery on some vehicles can clear the ECM in which will not send a "ready" signal to the OBDII scanner. Not sure if Jeeps reset after short battery disconnects, but I'm sure they would after an extended.
Also, I not familiar at when OBDII was introduced so you may not have any issues with a 99', just throwing this warning out there as I have a friend that has to deal with this every time he does an inspection, but he has a different make / model vehicle.
mitchlandry is offline
post #4 of 6 Old 11-20-2013, 10:50 PM
SchizophrenicMC
2016 JK Wrangler
If you reset your OBD-II vehicle (all 1996 and newer vehicles) it will report all its readiness monitors as NOT-READY. If more than 3 readiness monitors report NOT-READY, you automatically fail emissions. OBD-II vehicles are tested by OBD report, not the exhaust sniffer.
Signature rules are dumb
SchizophrenicMC is offline
post #5 of 6 Old 11-25-2013, 06:54 AM Thread Starter
Dysan
Thanks for the replies, haven't had much time to get on with packing and getting everything ready to move over there. But how long after a reset would it be OK, because I can usually drive around for a while and not have to unplug as long as if doesn't sit for more then an hour I am typically fine and it doesn't mess up.
Dysan is offline
post #6 of 6 Old 11-25-2013, 11:10 AM
SchizophrenicMC
2016 JK Wrangler
By the time the readiness monitors all show ready again, you'll have your light back on. Just fix your error.
