Dana 30 carrier removal help needed (Fort Worth) - JeepForum.com
post #1 of 5 Old 12-28-2012, 03:39 PM Thread Starter
TexasTJ
No Longer DD
TexasTJ's Avatar
I'm trying to install my Aussie locker in my D30 but I can't get the carrier to budge. Anyone near Ft Worth that could swing by and help?
May TJ of the Month 2015
TexasTJ is online now
post #2 of 5 Old 12-28-2012, 07:57 PM
dirtdude35
First you will need to drop the tie rod from the drivers side knuckle. Then put a rag in between the ring gear and the pinion gear and rotate the yoke and it should push the carrier out. I am in Hurst if you need more help just PM me
04 LJ 2in body lift, 4in rough country n2.0, winch, 35 Goodyear Wrangler MT/rs new style, poison spyder stinger, front locker
93 ZJ, 2in BB, Moabs, Goodyear wanglers MT/r Cherry bomb glass pack
dirtdude35 is offline
post #3 of 5 Old 12-29-2012, 08:42 AM
chainz
1976 CJ5
Or you can use a pry bar too!
chainz is offline
post #4 of 5 Old 12-29-2012, 09:40 AM Thread Starter
TexasTJ
No Longer DD
TexasTJ's Avatar
I've tried the pry bar method. I'll try the rags next, but I can't get to the Jeep right now. Thanks.
post #5 of 5 Old 12-29-2012, 02:04 PM Thread Starter
TexasTJ
No Longer DD
TexasTJ's Avatar
I got it! Put a tow strap around the carrier and hooked it to my friends JK to use the ratchet strap but when he put it in park it yanked right out. Nothing broke thankfully.
