AUSTIN/RR/SAN MARCOS...meet up? - Page 107 - JeepForum.com
post #1591 of 2056 Old 03-09-2013, 11:32 PM
Kenny-g
^ Jeep1000, when I went this past Sunday with them, a stock YJ kicked *** so I wouldn't doubt that a CJ would do fine (depending on its overall condition I guess...) he'll even my Patriot didn't do too bad...just got stuck going up most every hill -____-
Sent from AutoGuide.com Free App
Project; LOST YETI
'13 Wrangler Sport "Lee-Roy2.0"
32" BFGoodrich Mud Terrain T/As | Rubi MOABs | OMIX-ADA Locking Lugs | Rough Country hybrid front bumper & 8K lb Smittybuilt winch coming soon!
Kenny-g is offline
post #1592 of 2056 Old 03-13-2013, 07:09 PM
anarchychoppers
So no one has a dana 30 with 4.10 gears that they want to get rid of? I just don't want to spend a lot on an axle right now as I just redid my entire suspension and new tires all around. Just need it so I can have 4x4 again, while I save for my Dana 44 for the front.
Thanks,
Ronnie
1990 Larado, 258 CID, TF999, MC-2100, CRT HEI, 2" body lift, RS44044 front and back flipped for 98 wheel base, 1" booms, teraflex SYE, DIY Rock Sliders, rear bumper, and fenders, 35 MTR's and one crazy nut behind the wheel.
anarchychoppers is offline
post #1593 of 2056 Old 03-13-2013, 08:07 PM
Winners97TJ
Go Big Or Go Home
Winners97TJ's Avatar
Thanks,
Ronnie
(Edit: didn't read the entire post prior to quoting)
Just run with what you have for now without 4x4 until you get the funds for the 44.
Gun Control Means Using Both Hands
1997 Jeep TJ - Truly BUILT not BOUGHT! Purchased from original owner stock... obviously THAT didn't last long!
Winners97TJ is offline
post #1594 of 2056 Old 03-14-2013, 03:35 PM
anarchychoppers
yea, that is what I am doing now, but my front axle is disconnected, as it is 4.10 in the rear and 3.53 in the font. so no 4x4.
post #1595 of 2056 Old 03-14-2013, 03:43 PM
Tommy R
Tommy R's Avatar
Thanks,
Ronnie
Ronnie, wouldn't a stock D30 from any 4 banger YJ work? Didn't they come standard with 4.10s? If so, I'd ping Krawltex, Just Jeeps, or Jeep Masters to see if they have one available.
Good luck,
Tommy
2001 Wrangler homemade long arm, 99" WB, ARBs, alloys, 4.88s, 35" MTRs
Tommy R is offline
post #1596 of 2056 Old 03-14-2013, 03:44 PM
AustinTexasXJ
1987 MJ Comanche
Good luck,
Tommy
I second this.
Benjamin
ΜΟΛΩΝ ΛΑΒΕ!
AustinTexasXJ is offline
post #1597 of 2056 Old 03-14-2013, 04:08 PM
anarchychoppers
Yea, that is what I am looking for. I'm thinking if I get one cheep enough. I could swap it in and have 4x4. then build the HP 30 that I have now. Add a Truss change it to a 30 spline and run it. It would be as strong as a Stock dana 44.
post #1598 of 2056 Old 03-14-2013, 04:14 PM
Tommy R
Tommy R's Avatar
Well, I wouldn't say that. The ring/pinion will still be weaker than a D44, but it'll still be plenty stout enough for most folks. Case in point, I'm still running a D30 and my rig isn't exactly a mall crawler. I just added alloys, but in 6 years I've only snapped one axle and only lost one u-joint. The D30 gets a bad rap, but if you're smart with the skinny pedal, don't bind it, and drive smoothly it can stand up to some hard use!
That being said, however, I'll be going with a full width D44 at some point, but I eventually will plan to run 37s and want a bit more peace of mind. The axle swap will likely wait 'til the hot rod is driveable, though. That may be a while!
Tommy R is offline
post #1599 of 2056 Old 03-22-2013, 12:18 PM
anarchychoppers
Anyone up for Opals?
post #1600 of 2056 Old 03-22-2013, 12:36 PM
AustinTexasXJ
1987 MJ Comanche
Today?
Benjamin
ΜΟΛΩΝ ΛΑΒΕ!
post #1601 of 2056 Old 03-22-2013, 12:56 PM
anarchychoppers
Sure its.Friday
post #1602 of 2056 Old 03-22-2013, 01:06 PM
AustinTexasXJ
1987 MJ Comanche
Let's go. I'll be off work at 5:30 and it will take me about 15 to get there.
Benjamin
ΜΟΛΩΝ ΛΑΒΕ!
post #1603 of 2056 Old 03-22-2013, 01:14 PM
anarchychoppers
I'all get there around 5:30 and grab a table.outside
post #1604 of 2056 Old 03-22-2013, 01:30 PM
AustinTexasXJ
1987 MJ Comanche
Sweet you'll see my red *** JKU pull in
Benjamin
ΜΟΛΩΝ ΛΑΒΕ!
post #1605 of 2056 Old 03-22-2013, 02:12 PM
anarchychoppers
I know you wont miss my Red Yj. I'll have a green Harley Shirt on with a brown fedora on.
Machine Shops in the Austin (and surrounding) areas Winners97TJ Texas Jeep Forum 13 05-07-2015 11:12 PM
found trails in oak hill texas.(austin) AustinTexasXJ Texas Jeep Forum 13 10-01-2012 02:22 PM
Axle rebuild and gears in austin Area? bjl95mustang Texas Jeep Forum 6 02-25-2010 07:48 AM
Boulder Creek (Austin area) June 7th tube yj Texas Jeep Forum 24 04-09-2009 10:30 AM
Service in Austin, TX? docmarvy Texas Jeep Forum 2 09-11-2008 08:13 AM
