Anyone interested in a run to Hidden Falls? - Page 42 - JeepForum.com
post #616 of 979 Old 09-03-2013, 04:12 PM
bigt2317
Mall Crawler
bigt2317's Avatar
Originally Posted by StanF View Post
Wow...this thread has been dead lately!
We're planning another trip out to Hidden Falls for Sunday, Sept 8th, if anyone wants to join us. There should be at least a couple of TJs and a YJ. Post up here if you plan to attend, so we will be expecting you. We'll meet at Camp B at 10am. For those with CBs - let's use Ch 4.
The weather should be good - partly cloudy and 96 degrees.
Pictures from our last trip on July 21st:
I'm out, jeep is tore down for the clayton lift install. I'm really thinking about the K2 run in October though. I'll try to get a shake down run in before the K2 run and that will probably be late sept. at hidden falls
2005 LJ Black Rubicon - Boring mallcrawler
2005 LJ Khaki Rubicon - slightly modified - TOTALED
FOR SALE
PM me for great deals on enclosed or open trailers
bigt2317 is offline
post #617 of 979 Old 09-03-2013, 06:13 PM
Perkalater79
Originally Posted by Rumbloki
I don't want to cut my seams. I did some testing with a 2x4 (1.5"x3.5" actual) at Hidden Falls. I didn't get any rub. I will replace them with 2"x4" tube stock.
What kind of mod did you do? I'm thinking about squeezing 35s. Might need 1"-1.5" bump stop extension. This seems like a great way to test the spacing. With 35s I will need to cut my pinch seam, no doubt, I'm talking about bump stop extension to avoid hitting my fender well.
Ps. I have no lift. I've seen it done with the right kind of backspace. I need to check mine out.
Perkalater79 is offline
post #618 of 979 Old 09-03-2013, 07:06 PM
Winners97TJ
Go Big Or Go Home
Winners97TJ's Avatar
You're going to rip those fenders off the first speed bump you hit..... Do it right the first time.
Gun Control Means Using Both Hands
1997 Jeep TJ - Truly BUILT not BOUGHT! Purchased from original owner stock... obviously THAT didn't last long!
Winners97TJ is offline
post #619 of 979 Old 09-03-2013, 07:15 PM
JcArnold
Originally Posted by winners97tj
you're going to rip those fenders off the first speed bump you hit..... Do it right the first time.
x2
1990 YJ Islander without the Island so I guess that makes it just an " er "
2010 JKU Sahara Super Lift 4", 33" Nitto Mud Grapplers, Custom Front bumper and rocker protection-SOLD
2012 Jeep JKU MW3 Edition Rubicon
37x12.50x17 Goodyear Wrangler MTRs
Pro-Comp 7031 17x9
Rock Krawler 5.5" X-Factor
Fox Racing Shocks
Synergy Front Cage Kit
Synergy Axle Tubes/C gussets
4.88 gears frt/rr
Replacement frt/rr driveshafts
Poison Spyder rockers
And a bunch of other little stuffs
JcArnold is offline
post #620 of 979 Old 09-03-2013, 10:06 PM
Perkalater79
By the way I should have added that I have Bushwacker flat fenders. With my 295/70 17 tires (approx 33.25 converted) I have stuffed my tires fully, while rocking on 2 wheels, and have stopped just prior to rubbing the fender well. Hence my thought that a 1"-1.5" bump stop along with a pinch seam adjustment is all I need.
Like I said. I now a guy running no fenders who fit 35s without any lift. It seems crazy that given these 2 examples that I can't fit 35s. Am I crazy?
post #621 of 979 Old 09-04-2013, 06:32 AM
JcArnold
This I gotta see
Pro-Comp 7031 17x9
Fox Racing Shocks
4.88 gears frt/rr
JcArnold is offline
post #622 of 979 Old 09-04-2013, 07:53 AM
Winners97TJ
Go Big Or Go Home
Originally Posted by JcArnold
This I gotta see
opcorn:
post #623 of 979 Old 09-05-2013, 06:16 AM
Winners97TJ
Go Big Or Go Home
Agreed, the 35s will probably fit under there with a BB, BUT......
There will be no room for movement/tucking/flexing on the trails. You'll be going home with your fenders in the trunk. And possibly be rubbing the inner fender wells due to lack of room. I'm in a 97 TJ, but have marks on my 35" tire tread from where they have hit in the rear of the tub. And that's with 5.25" of lift. (4" suspension/1.25" body)
Owning a JKU and running a 2.5" lift and 35's, it's not enough. Winners was right, I popped off my rear fenders on the trail due to flex and no room for tires. You should plan for 4" minimum if you want 35's.
Bump stops work as advertised. If you look at my profile, I have some photos with my maroon jk on 35's with the 2.5" lift. I only had about 3" of clearance between tires and fenders so your bumps need to be pretty close together. My recommendation would be once you have both the lift and tires to flex it out and then measure for correct bumps.
BAM!
Go big or go home.
By all means a BB would work for the road, but will DRASTICALLY limit your capabilities on the trails. Won't take long until you're rubbing all kinda of stuff. I think we had to pull JCArnold's fenders within 10min of trail riding when we went that day. Literally, 50yards into first trail.
Enough said.......
post #624 of 979 Old 09-05-2013, 07:32 AM
bigt2317
Mall Crawler
bigt2317's Avatar
I'll chime in here on what I know but this is TJ/LJ talk, I know nothing of JK/JKU's. I ran a bone stock suspension and a 2-1/4" BB for about a year, I also had a little extended bump stops and the hockey pucks on the front lower spring perches, all while running 33's. With it like that I can say that the jeep was pretty dang capable, I choose the hardest group at jeep jamboree and did everything (minus one obstacle) that the guys on 37's and coilovers did. I did rub a little on the front while at full flex but I just learned to take that into account while picking a line.
Grant, do you still only have the leveling kit in the front? If so then I would at least swap that out for a full BB prior to 35's
All in all, a full suspension upgrade is the best way to go but I have a hard time believing that BB limit capabilities when I ran one and kept up with knowledgeable guys on 35 and 37's. As I'm saying this my jeep is tore down for a clayton 3 link and 4 link long arm setup so I definitely understand the benefits of a good suspension setup.
FOR SALE
bigt2317 is offline
post #625 of 979 Old 09-05-2013, 11:28 AM
Rumbloki
Originally Posted by JcArnold View Post
Dude you need bump stop extensions. I will post up some photos when I build mine. Cheap and super easy.
Like I said, the blocks were for testing. I wanted to see if 2" extension was enough.
2012 Rubicon - RK 2.5", 35" KM2s on 15" MB72s, Engo E9000 on Smittybilt SRC, Bestop Trektop NX
Rumbloki is offline
post #626 of 979 Old 09-05-2013, 11:41 AM
Rumbloki
With this fender trim and stock bump stops I have no rubbing up front. 1.5" block was enough to keep the tires off the seam and rails.
Rumbloki is offline
post #627 of 979 Old 09-06-2013, 10:11 AM
jon_allison
Are some of you still planning to be at the park this Sunday (9/8)?
I'd like to head out there if a group is going.. I'm very familiar with the park, but would love to meet a few of you guys to run around.
-Jon
jon_allison is offline
post #628 of 979 Old 09-06-2013, 11:24 AM
StanF
-Jon
No, unfortunately, I don't think anyone is going out on Sunday. We're going to try again later in the month.
StanF is offline
post #629 of 979 Old 09-06-2013, 09:24 PM
Perkalater79
Awesome. Just what I was hoping. Quick question. Did you cut your rubi rails and pinch seem? I looks like I'll have to on my unlimited.
Also, looks like you're running 15" wheels. Correct? What kind of backspace do you have?
Nice pic by the way
post #630 of 979 Old 09-26-2013, 09:25 AM
JcArnold
Im resurrecting a dead thread one last time, Im heading out to hidden falls this sunday. If anyone wants to go I will post up some details.
Pro-Comp 7031 17x9
Fox Racing Shocks
4.88 gears frt/rr
JcArnold is offline
Hidden Falls Adventure Park Apr 15-17 TxRubiGrl Texas Jeep Forum 10 05-01-2011 07:27 PM
Hidden Falls April 15-17th 2011 TxRubiGrl Texas Jeep Forum 0 04-04-2011 05:21 PM
Hit Hidden Falls yesterday in the WJ.... Texas_Heat Texas Jeep Forum 8 03-28-2011 08:12 PM
Headin to Hidden Falls Tomorrow!! TxRubiGrl Texas Jeep Forum 5 01-12-2011 08:54 AM
hidden falls advice jdub36 Texas Jeep Forum 7 06-06-2010 01:58 PM
