#31 | ||
Do not bind them up. Don't turn the steering wheel all the way to its stops while on the gas pedal. Do not go backwards with the wheel turned full(a u-joint breaker for sure). Binding up the front end(steering to its stops) is very hard on the front u-joints. I always turn off the front locker(if on) BEFORE I go backwards even an inch. If you have a front auto-locker...CARRY U-JOINTS! (almost impossible to go backwards while turning, with the locker engaged and not bind up the inside axle)
#32 | |
Im not very exp but I think if you can do what I can do you should be ok.. How did you end up doing at the quarry?
___Only in an XJ____ __________________ |
#33 |
I would say that the 2 trails are close to the same in difficulty.
Twin cone has a spot or 2 that can be a bit tough, but there are a couple of lines through it. |
#34 |
any news on Slaughterhouse being open or are you only doing Twin Cone?
2007 Wrangler X - Jeep Green, 4" lift, JKS front/rear trackbars, Fab Industries custom front/rear bumpers, fenders, 6-point cage, Treks/T&T gas tank skid, 10lb co2 tank, rolling on 35s w/ 15s Colorado Jeep Club member #2007 My JK Build Thread Items For Sale: - front/rear trackbars |
#35 | |
80 CJ7 with 307 chevy motor BRAKES GOOD, TIRES FAIR ITS A LIL UGLY, BUT THE KIDDO LOVES IT Colorado Jeep Club Member # 9999 |
#36 | |
#37 | |
I personally would rather run the 31" ATs rather than the 29s but I really don't know if the mismatched tire would cause any issue. Im running a 4" lift and 33s (open/open)
#38 |
The first five miles of Twin Cone are scenic and easy - then you make that sharp left turn and the last couple miles are tougher.
What really counts is if there's snow... Snow could make the first five anything from easy to impassable. Snow on the last section would really make it impassable to anything but super machines. I've done the first five when there was some snow and it was quite enjoyable. Jim Steep nasty hill which is bypassable by a steep smooth hill - these pics are on the tougher top section ![]() Optional obstacle ![]() I think there is a bypass here also ![]()
03 Sport |
#39 | |
I've run it open on 33's and made everything including the optional stuff. I have spare D30 axles. Jim
03 Sport |
#40 |
I found a vid on Youtube of Twin Cone this time lastyear almost to the day (05/25/2008)... Looked pretty nice.. hopefully we get more of the same this year.
http://www.youtube.com/watch?v=GRomlPm4Hds
#41 | |
#42 |
Well i'd like to make this trip with everyone...But, can someone call the forest service and make sure its open before we all get too excited...I would hate to all convoy up and only be able to run 1/4-1/2 of the trail and have to turn n head home...I tried to call today, but they are only open til 4pm ..maybe also ask if SLaughterHouse is open or not...
(id call but i dont get home from work until 5 or later)..So if one of ya has a free moment and would be so kinda to call, it would help all of us anxious wheelers out a ton! ![]()
Colorado Jeep Club Member #'303' 1998 Jeep Wrangler TJ Sport 4.0 I6, D30 and D44,4.56 G2 Gears,belly,gas & steering skids, 35x12.5 Wrangler MTR Kevlars,4" ProComp Coils,1.25" JKS BL,1"Currie MML,Bilstein 5100's, Chromoly LCA's front and rear, JKS Disco's,K&N intake,PSC BFH front stinger bumper w/winch & d-rings,PSC Rear stinger/carrier w/d-ring,PSC Rocker Knockers,Dynomax Ultraflo welded ss, APN header,PIAA 520 ATP, Bestop top,alpine CDA-105 deck,Tuffy underseat Security box, JL Audio speakers in sound bar and dash, Corbeau front seats, matching Neoprene cover on bench,trimmed flares...and PLENTY more to come.. **Oil Field Trash Makin' Oil Field Ca$h**
#43 |
#44 |
This is what i found..and the # i called earlier..not sure if its 100% correct...plz chime in if anyone else has diff info.
South Platte Ranger District 19316 Goddard Ranch Court Morrison, CO 80465 Phone 303-275-5610 Fax 303-275-5642
#45 |
I already called, I even posted it in this thread. Yes it is open, as for how far we can get up, the forest service could not tell me as they have not sent anyone up there since last season (or so they said). I didn't think to ask if Slaughterhouse was open. I will try again tomorrow to ask about Slaughterhouse. Webster and Red Cone will not open till at least July 4th weekend according to the ranger I talked to so those trails are out as a backup plan.
And yes, South Platte Ranger district is the right # to call. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
