Quantcast Twin Cone: Sunday the 31st? - Page 2 - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South Central USA > Colorado Jeep Forum > Twin Cone: Sunday the 31st?
Truck-Lite's New LED Headlamp SeriesGR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 05-27-2009, 09:40 AM   #16
PatTJ05
Originally Posted by James750 View Post
I have a feeling that we should be able to get pretty far up this trail, if not all the way up. But if we don't make it very far, we can always run Slaughterhouse on our way back. The forest service said that Red Cone and Webster are closed and will likely be closed until at least July 4th.
Slaughterhouse open again after all this rain we've had?
2000 Sport mostly stock ...GONE...
2005 Green Rubicon -- Specs in my profile.
Colorado Jeep Club Member 116
PatTJ05 is offline   Reply With Quote
Old 05-27-2009, 09:47 AM   #17
jeepster93
jeepster93's Avatar
I could be up for this run.
jeepster93 is online now   Reply With Quote
Old 05-27-2009, 10:06 AM   #18
James750
1990 MJ Comanche
I haven't even thought about them closing it Pat. I will have to give the forest service another call...
1990 mj,
Colorado Jeep Club #178
Originally Posted by Ubie View Post
Three words: Flying Spaghetti Monster
Originally Posted by War Eagle View Post
Praise be unto His Noodly Appendage.
James750 is offline   Reply With Quote
Old 05-27-2009, 10:52 AM   #19
2slw4u
1992 XJ Cherokee
i went to slaughter house in my stock xj in feburary there was barely any snow, but with the rain could be exciting! if i had my lift on i would join you but lacking tires at the moment
Colorado Jeep Club Member #125
Also am on http://www.cherokeetalk.com
2slw4u is offline   Reply With Quote
Old 05-27-2009, 11:55 AM   #20
XJimmy
What you need is a set of frame tie in brackets. What they do is attach the tow hook to the 3 bumper bolts and they extend back and tie into the unibody a little bit past the sway bar mount. I would give you my old set, but I gave them away about a week ago to another XJer in need.
Here is what you need:
http://www.jeeperz-creeperz.com/front-hook-p-6752.html
Some companies are selling knock off versions that do not have the unibody tie in portion and are basically just for looks. These will not work for an actual recovery situation. Here is one of them:
http://collinsbros.stores.yahoo.net/xjtowhookbra.html
Without that bar that extends back and ties into the unibody, it will rip out the bumper mounting holes in any real pull.
I am purchasing and getting a winch bumper installed by Josh J. with anchor shackles on it...
http://denver.craigslist.org/pts/1156644383.html
Should be good to go with that on.... Josh also said he may come up to Twin Cone too with his new TJ..
___Only in an XJ____
XJimmy is offline   Reply With Quote
Old 05-27-2009, 12:02 PM   #21
James750
1990 MJ Comanche
That will work! Glad you can make it.
1990 mj,
Old 05-27-2009, 12:04 PM   #22
James750
1990 MJ Comanche
Meeting place: Lets meet at the Conifer Staples parking lot at 9:00.
1990 mj,
Old 05-27-2009, 12:15 PM   #23
307cj7
1980 CJ7
Ill most likely go if you thing a stock cj can make it.
80 CJ7 with 307 chevy motor
BRAKES GOOD, TIRES FAIR
ITS A LIL UGLY, BUT THE KIDDO LOVES IT
Colorado Jeep Club Member # 9999
307cj7 is offline   Reply With Quote
Old 05-27-2009, 12:36 PM   #24
James750
1990 MJ Comanche
What kind of spare parts should I bring on this trail if any? I don't have any axle ujoints because the ones I have wont work in my new axle (newer D30 with the stronger ujoints). I plan on Bringing my spare front DS and it has ujoints on it that will work on the rear shaft if need be.
1990 mj,
Old 05-27-2009, 12:53 PM   #25
jeepster93
jeepster93's Avatar
About the only spare parts I carry anymore are u-joints. Both the axle and drive shaft ones. I carry 2, one axle and 1 ds.
I also carry a foot of fuel line, a braided brake hose, air locker repair kit, a fan belt, a spare spring shackle, Nuts/bolts, duct tape and bailing wire.
Can kind of tell what I have broken on trail by what I carry as parts...and upgraded(axles, brakes, drive shafts, all have been upgraded so I don't need spares).
And tools...spare parts do no good if you can't put them in while on trail.
Old 05-27-2009, 01:00 PM   #26
James750
1990 MJ Comanche
I had a spare ds ujoint, but it went into my now spare front DS before I knew what the problem was with it and thought it was ujoints (ended up being too much play in the splines). I also had a drive axle ujoint, but it will not work in a 94XJ axle. If I break a rear DS ujoint I will just transfer one of the front spare DS to the back DS. Not too worried about breaking an axle ujoint this trip since I have the bigger ujoints, but I'll try to grab one before the weekend.
1990 mj,
Old 05-27-2009, 01:09 PM   #27
Shag
Shag's Avatar
I should be able to go.
____________________________________
Shaun
Buy Shag A Lifetime Membership
Originally Posted by afbond03
....just need a nice tug it would be really simple to get me from behind just pull me back....
rbowling is a thief. I bought these gears from him, and now I am out my money and still no gears. Do not trust him.
Shag is offline   Reply With Quote
Old 05-27-2009, 01:10 PM   #28
XJimmy
I can bring a spare Tie Rod and Drag link.
Old 05-27-2009, 01:14 PM   #29
XJimmy
Did you make it all the way up the first climb at Moody Hill wet with out assistance the other day?
Old 05-27-2009, 01:34 PM   #30
307cj7
1980 CJ7
Only got hung up on the 1st spot cause it was wet. Otherwise it was a good day
Glock Forum
