reasonable Jeep parts? - JeepForum.com
post #1 of 3 Old 08-11-2011, 12:27 PM Thread Starter
BillyBob69
Our PD has a 98 Grand Cherokee as one of their vehicles. The thing keeps dimming the dash lights at night on it's own but if you jiggle the switch a little, you will get them back. Or just press in a bit on the face of the switch.
Where can I go, other than the dealer, for a replacement switch? We are a small town and don't exactly have a huge parts budget.
Thanks all!
BillyBob69 is offline
post #2 of 3 Old 08-12-2011, 10:03 AM
TJaefick
Before you consider complete replacement, remove the switch and take a close look at all the connections. It sounds as if it's just a loose connection that may be fixed with zero money. Otherwise, try a pull & pay. those switches are some of the first things to be removed from junkers, but if you find a place that has some fresh metal in their inventory, you might get lucky. Also, before you head out there, try to find what range of vehicles that switch would work for (i.e. make sure you know the years that are compatible, as well as other makes and models).
'05 LJ, 2" OME, ARB/4.56, 33x12.5
TJaefick is offline
post #3 of 3 Old 08-12-2011, 01:24 PM
COLOUXJ
2010 JK Wrangler
Check out rockauto.com if the above does not fix your problems, they have pretty much everything other than dealer only parts.
COLOUXJ is offline
Jeep Parts In Colorado CLNinja Colorado Jeep Forum 74 10-03-2017 01:40 PM
need parts help Irish_Assassin Colorado Jeep Forum 5 06-06-2010 06:29 PM
Parts please hammer99tjdd Colorado Jeep Forum 5 01-03-2008 10:33 AM
Where they get the parts from? likefre Colorado Jeep Forum 4 04-30-2007 08:54 AM
Parts is parts jeepster93 Colorado Jeep Forum 9 01-27-2007 08:50 AM
