Quick question about backspacing...... - JeepForum.com
post #1 of 8 Old 07-26-2007, 02:55 PM Thread Starter
stangman68inftc
stangman68inftc's Avatar
1993 XJ Cherokee
Tj Quick question about backspacing......
Hey guys, I've got stock canyons right now on my TJ with 31x10.5 and I have to problems with them except that at full lock, right or left, they rub. So I've been looking around for sometime now for some black steelies and think I've found a good deal on a pair of 15x7's. I called and asked the guy if he knew what the backspacing was on them and he wasn't sure so he measured from the inner edge of the rim to where the wheel bolts to the hub and it was 4.5. First question, this is the correct way to measure backspacing right? Second question, I have heard, but am not positive, that a 12.5 inch wide tire will fit on a 7 inch wide wheel, is this correct? Last question is can I mount a 12.5 inch wide tire on a wheel with 4.5 inches of backspacing and have it not rub while turning? Thanks for the help guys.
Colorado Jeep Club member #87
stangman68inftc is offline
post #2 of 8 Old 07-26-2007, 02:57 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Can't answer your TJ specific questions on rubbing, but generally a 12.5" wide tire wants an 8" wide rim. The only way to know for sure is to visit the tire manufacturers website and check on their list. It'll display the minimum rim width. Too narrow and it'll bow the tire and cause poor tread wear.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 8 Old 07-26-2007, 03:12 PM
KUK9
KUK9's Avatar
First, yes, that is the correct way to measure backspacing- basically lie the wheel face down, put a straight edge across the wheel, and measure from the outside of the wheel to the mounting surface.
Second, I'm confused a bit. You are saying that you have 10.50 wide tires, but then are jumping to 12.50. Is this just to make sure that in the future if you go larger that you are ok, or is there a typo in there somewhere?
As far as a 12.50 wide tire, I would go with an 8" wide wheel (which is what most people run...some run 10" wide). With an 8" wide wheel, a 12.50 will fit very well, and allow you to air down lower than a 10" wheel without the chances of blowing a bead as easily. You should be able to run a 12.50 on 4.5" and not have it rub...but you might need to go to 4.75".
REDLYNER Racing #4550
My Build Thread:
http://www.jeepforum.com/forum/f22/adapt-die-kuk9s-stretch-tj-build-1160620
KUK9 is offline
post #4 of 8 Old 07-26-2007, 04:19 PM Thread Starter
stangman68inftc
1993 XJ Cherokee
Tj
Sorry if I was a bit confusing. I currently am running a 10.5 inch wide tire, and on the stock wheels they rub at full lock. This is the main reason why I want new wheels. However, I am curious about whether or not I would be able to fit a 12.5 inch wide tire on these wheels in the future so that was why I asked about both. I would assume that for now, these 15X7 would be fine for my 31X10.5. After I get my, lift on, I have been thinking about getting some 33X10.5 BFG AT's because they are cost effective, and I would assume don't hit the gas mileage as badly as a 33X12.5. I am not however, set on getting 33X10.5, that's why I was curious about 12.5 inch tires as well. One last question, anyone know of a good inexpensive place, preferably in northern colorado to have my tires mounted on these new wheels assuming I get them? Thanks again guys.
post #5 of 8 Old 07-26-2007, 04:27 PM
Shag
Shag's Avatar
I have the stock canyons as well with 31x10.5 BFG AT's. I was having rubbing issues until I added a couple of washers to the steering stops.
____________________________________
Shaun
Originally Posted by afbond03
....just need a nice tug it would be really simple to get me from behind just pull me back....
is a thief. I bought
gears from him, and now I am out my money and still no gears. Do not trust him.
Shag is offline
post #6 of 8 Old 07-26-2007, 06:14 PM
otisdog
2008 WK
12.50's probably would be ok with 4.5" backspacing, however if you could get them with 4" it would be better.
Rubbing when turning full is the least of your worries with too much backspacing - how close the tires are to the upper rear spring perchs is a bigger concern. You don't want to slice up a couple $160 tires. You have to check both sides also because your lift [ trackbar] may be pulling your axle to one side a bit more than the other.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #7 of 8 Old 07-26-2007, 09:43 PM
MtnHighTJ
MtnHighTJ's Avatar
I got some 1.5" wheel spacers for sale $90 shipped, that would take care of the rub.
5spd Banks Monster exhaust
Dana30 ARB Locker Dana 44 LSD 4.88's
4" Explorer Pro Comp lift
1 1/4 JKS BL Brown Dog 1" MML
RE monos Nasty's Disco's
15"x 8" soft 8's w/ 35"x12.5'' MT Baja MTZ
A to Z sliders. Nth degree oil pan skid
Rokmen gas skid steering skid Warn dif plate
Superwinch EPi 9000
Currie HD Tie rod
BESRK rear bumper w/swing out
Colorado Jeep Club Member #85
MtnHighTJ is offline
post #8 of 8 Old 07-26-2007, 09:45 PM Thread Starter
stangman68inftc
1993 XJ Cherokee
I know I can just add spacers as far as the rubbing goes, but first of all I'm too lazy, second of all, it's only at full lock and I know it so I can avoid it, third of all, I would rather get some wheels with better backspacing so that I can take full advantage of my turning radius. The main that I haven't put my lift on yet is because I have a feeling my stock wheels will make my tires rub on the spring perches.
HELP - Need quick connect for trailer lights dlcrenshaw Colorado Jeep Forum 1 01-26-2009 01:10 PM
Quick! Tint laws here- how bad are the cops? REDLYNER Colorado Jeep Forum 26 11-15-2007 06:10 PM
Where to get quick release mirrors? E_ROCK Colorado Jeep Forum 0 11-15-2007 11:57 AM
quick stay in Denver nquaint Colorado Jeep Forum 15 07-06-2007 07:52 AM
A Quick HEY jeepster93 Colorado Jeep Forum 1 10-22-2006 08:47 PM
