Q's for anyone who knows diffs.... - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South Central USA > Colorado Jeep Forum > Q's for anyone who knows diffs....
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 08-25-2007, 02:46 PM   #1
zigsrig
Hey gang,
AFter replacing both of my front hubs on my WJ i am still gettin some wierd noises... Only when i am on the gas, i am getting a noise that sounds like my front drive shaft is rubbing on something.
I have tried different speeds, at different RPM's, up and down hill and the noise is the same, and only when i am on the gas. If i am coasting there isnt a noise.
ANy thoughs on this. I havn't taken the diff cover off yet, i think thats my next step.
Does anyone know a good place to get the diff fluids i need for this? (99 WJ with Quadra-drive)
thanks for the help
Zig
www.ZigsRig.com
zigsrig is offline   Reply With Quote Quick reply to this message
Unread 08-25-2007, 04:08 PM   #2
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
1) I hear that if the front diff whines when accelerating it is the pinion bearings. (and if the rear whines upon deceleration, it is the pinion). The wheel bearings normally don't have an acceleration/deceleration sound associated with them.
2) Pick up the diff fluid anywhere (Napa) buy you'll need to get the friction modifier from the dealership. Check out www.wjjeeps.com for the specifics on which gear oil you need.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline   Reply With Quote Quick reply to this message
Unread 08-27-2007, 10:05 AM   #3
zigsrig
Thanks,
thats what i was looking for... the passenger side wheel hub was so loud that i could not hear the pinion bearing until i fixed it, not all i can hear is the faint pinion bearing...
www.ZigsRig.com
