Opinions on wheel spacers - JeepForum.com
post #1 of 25 Old 08-27-2007, 11:32 AM Thread Starter
stangman68inftc
stangman68inftc's Avatar
1993 XJ Cherokee
What do ya'll think about wheel spacers? I've been looking for a while now for a set of black steelies to no avail. Whenever i find some that sound good, they are either only 7 inch wide, in colorado springs and the guy tells me he wont meet me in denver so I call the next day to drive down to the springs and he's sold them, or they are really crappy condition. Basically I'm not wanting to shell out 200 bucks for a brand new set, thats why ive been looking used, but lately ive been thinking about spacers instead. I like my current wheels just fine, and you can get a set of spacers for 100 bucks. Anyone have any experience? Likes or dislikes? Thanks for the input guys.
Colorado Jeep Club member #87
stangman68inftc is offline
post #2 of 25 Old 08-27-2007, 11:50 AM Thread Starter
stangman68inftc
1993 XJ Cherokee
Also, for those who might know, would 1.5 inch spacers be too much for my stock wheels or would they be okay?
post #3 of 25 Old 08-27-2007, 12:04 PM
RyanZJ
RyanZJ's Avatar
Just replied to the same question in the GC forum. My answer:
I'm using 1.25" spacers with my stock wheels without any problems whatsoever. The end result will basically be the same thing as buying a wheel with a smaller offset. You just have to make sure to re-torque the spacers every time you rotate your tires and you should be good to go.
Most people will tell you that you can buy 4 new steel wheels for the same price or cheaper than the spacers will cost you, but I personally like the look of a lifted Jeep with stock wheels, and I got all 4 of my spacers used for $100.
Hope that helps. I don't have a clue as to what kind of backspacing you should be looking for with a TJ...sorry.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #4 of 25 Old 08-27-2007, 01:13 PM
E_ROCK
After doing my waggy D44 swap, I decide it wasn't enough width. I have been running 1.5" spacers for about 3 yrs now. No problems with them or drivetrain parts yet. I suggest looking into spidertrex wheel spacers. I know you said you didn't want new, but I don't believe in cheaping out on these things. Remember to use red locktite on the threads of the axle lugs.
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #5 of 25 Old 08-27-2007, 01:15 PM
RyanZJ
RyanZJ's Avatar
Oh yeah, forgot about the locktite. I used red on mine as well.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #6 of 25 Old 08-27-2007, 01:23 PM
jeepster93
jeepster93's Avatar
I do not understand this???
I am always on the least popular side on everything...
When I did my 8.8, the thing is 1.5 inches narrower than stock, so I looked into wheel spacers. Right now, I have done nothing to correct the narrow axles, I will prolly gat a Super 88, this adds 1.5 inches.
A couple points:
I have seen a wheel fall off on trail, using wheel spacers with my own eyes.
Discount and other tire retailers WILL NOT warranty tires used on vehicles with wheel spacers.
jeepster93 is offline
post #7 of 25 Old 08-27-2007, 03:14 PM
E_ROCK
A couple points:
I have also seen people wheel fall off cars on the side of the road. You can tell because of the ground down rotor. Wheel spacers are a item you must check. I do believe many people put them on and don't check the torque on them. A few bad apples ruin the bunch. Also I do believe there is a huge differance in a quality spacer vs. the ebay specials. The toyota crowd has been using spacers of long time because their axle are alway narrow for big tires.
On the Discount warranty..... You shouldn't be buying their expensive warranty anyway. Their is a reason why they push sooooo hard for the warranties and it isn't to do you a favor. You have to ruin two set of tire before you save a dime.
E_ROCK is offline
post #8 of 25 Old 08-27-2007, 05:22 PM
RyanZJ
RyanZJ's Avatar
They are definitely an item that requires routine checking, but if you're rotating your tires like you should be it really isn't that big of a deal to check the torque on them while you're at it.
I've said it once and I'll say it again...there isn't a difference between a wheel with smaller offset and spacers as long as you keep up with checking the torque on the spacers (this is assuming that the spacers are quality hub-centric units like Spidertrax).
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #9 of 25 Old 08-27-2007, 05:26 PM
E_ROCK
I check my everytime I rotate my tires. I haven't come across a loose lug yet.
E_ROCK is offline
post #10 of 25 Old 08-27-2007, 07:46 PM
otisdog
2008 WK
Spidertrax 1.25" spacers here. No problems yet.
New ones will run you $200 for four. Bought mine used.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #11 of 25 Old 08-28-2007, 12:02 AM Thread Starter
stangman68inftc
1993 XJ Cherokee
I found these on craigslist, do you think they are cheapo knockoffs?
http://fortcollins.craigslist.org/pts/403666432.html
post #12 of 25 Old 08-28-2007, 09:25 AM
Naturalhoosier
Naturalhoosier's Avatar
What is the physical difference between the e-bay knockoffs and the spidertrax? They both come w/the add'l lugs. They both seem to machined from 6061T6 anodized aluminum. It seems like (and this is only from my readings) that you just need to keep an eye on them to make sure they don't come loose. So as stated before, it's just the matter of checking the lugs.
Again, I have no experience, but just eyeing them, that seems to be the case.
--Nick
My Ride: 1998 GC Limited
Colorado Jeep Club Member #15
Black Jeep Club Member #1976
Make the world a better place, punch a Boilermaker in the face!!!
Don't blame me...I didn't vote for him.
Naturalhoosier is offline
post #13 of 25 Old 08-28-2007, 09:28 AM
RyanZJ
RyanZJ's Avatar
Nick -
The cheapo ebay ones aren't hub-centric so they can work on numerous vehicles/manufacturers. Spidertrax are hub-centric, so the weight of the vehicle is supported mostly on the hub itself, and not on the lugs. I'm actually running the cheapo ones, but I'd prefer to have a hub-centric design.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #14 of 25 Old 08-28-2007, 09:29 AM
RyanZJ
RyanZJ's Avatar
Those look like the same ones I have. If you get them, you just have to be really sure to stay on top of the torque on them.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #15 of 25 Old 08-28-2007, 09:41 AM
Volcom
Volcom's Avatar
1984
I run 1.5" spacers along with some 15x10 2.5 inch backspaced wheels on my Toyota with no problems. I also check the spacer lugs every time I take the front tires off.
1984 Toyota 4Runner on 40's
Drive it like your sponsored
Volcom is offline
Opinions on reverse lights..... stangman68inftc Colorado Jeep Forum 3 11-30-2009 12:41 PM
Opinions needed.... stangman68inftc Colorado Jeep Forum 10 08-19-2009 07:26 PM
Apple computers, opinions. jeepster93 Colorado Jeep Forum 30 01-01-2009 07:39 PM
Opinions on an idea.... stangman68inftc Colorado Jeep Forum 5 07-11-2008 12:22 PM
Opinions on steering setup RAAB3485 Colorado Jeep Forum 55 02-01-2008 08:20 PM
