Looking for a 242J from a 2002-2003 WJ V8 - JeepForum.com
post #1 of 21 Old 04-23-2013, 01:08 PM Thread Starter
STRRAYNGE
Im looking to do a 242 swap in my WJ. Is there anyone local on here that might know where I can get a T-case from at a reasonable price?
1993 Jeep Grand Cherokee ZJ. 7" Clayton Long Arm Lift, 9" rear w/currie high pinion, D44 Trussed front axle, High Steer, chrome moly axles front and rear, ARB's front and rear, 35" BF Goodrich KM2's, Trail Ready front bumper with winch, custom rear with swing out tire carrier, etc, etc.
STRRAYNGE is offline
post #2 of 21 Old 04-24-2013, 03:26 AM
texlurch
I got one off Fleabay at a good price. Local you'll have to hunt and peck around the junk yards.
Just another old fart in a Jeep... watchout younguns!!!
RC LA, IRO 6 in springs, OTK, Bilsteins, Aussie, Eaton, RCV's, 242-SYE, hidden winch, JCR Stage 3, skidded and trussed & sleeved
Colorado Jeep Club Member #383
texlurch is offline
post #3 of 21 Old 04-24-2013, 09:07 AM Thread Starter
STRRAYNGE
Yeah, im having no luck at all local!
post #4 of 21 Old 04-24-2013, 10:43 AM
texlurch
I didn't either; yards or Craigslist or local 4x4 boards. Intraweb is yer friend!
texlurch is offline
post #5 of 21 Old 04-24-2013, 10:50 AM
texlurch
This is where I got mine from, for about the same cost
http://www.ebay.com/itm/TRANSFER-CAS...ht_2235wt_1020
He was also willing to sell the rear shaft for an extra $100 which is a good deal, since you need it unless you are going SYE.
texlurch is offline
post #6 of 21 Old 04-24-2013, 12:00 PM Thread Starter
STRRAYNGE
Thanks man! I think I may have found one down in Commerce City. Asking 400.00 plus 15.00 core. I guess ill need to see if he has matching rear drive shaft as well. As far as being able to tell for sure if it is the 242HD? Im guessing the only way to really tell is by the aluminum housing over the output shaft?
post #7 of 21 Old 04-24-2013, 11:46 PM
texlurch
Yep, if it has the alum extension on the back it is the HD. Or count the splines on the input side.. don't recall off my head but it is in the swap thread in the WJ section
texlurch is offline
post #8 of 21 Old 04-25-2013, 07:39 AM Thread Starter
STRRAYNGE
Yeah, I read that thread. I mainly just wanted some clarification from someone that has done it. Hes gonna sell me T-case and drive shaft for 475.00. Do you know of anything else I might need, any harnesses, plugs, brackets, etc?
post #9 of 21 Old 04-25-2013, 08:45 AM
texlurch
Other than the case and driveshaft, it's a bolt in
Change the cable to the bottom hole on the existing bracket (it's actually bolted to the side of the transmission), install, drive.
You don't even have to change the shifter out, but it makes it easier to know where the gears are.
Mine had two of the studs that mount it to the trans bent somewhere along the way, so I had to pull two from the 247
Also, the hardest part is accessing the 6 bolts; I found it simpler to drop the crossmember, and remove the mount off the trans, than trying to piddle with 1/4 turn on the two bottom ones.
Support under the trans pan with a couple 2x4's to spread the load
texlurch is offline
post #10 of 21 Old 04-25-2013, 08:48 AM Thread Starter
STRRAYNGE
Awesome! Thanks for the input. I will be doing this tomorrow. The speedo and everything all work fine, or will I need to put mine in the 242?
post #11 of 21 Old 04-25-2013, 08:52 AM
texlurch
Speedo is picked up off the ABS wheel sensors
Only wire there is comes from the 242, and lights the "4x4" light on the dash.
I didn't mess with finding a plug and connecting it
You'll also find the breather hose on top, it just pulls off the nipple and goes back on the 242 in the same place
The step by step in the WJ forum is really good; pics help a lot.
texlurch is offline
post #12 of 21 Old 04-25-2013, 09:39 AM Thread Starter
STRRAYNGE
thanks again. gonna go take another look at that write up.
maybe im thinking of the 249 and the regular 242 swap that I did on my wifes ZJ a couple years back. that one had the speedometer on the tcase.
post #13 of 21 Old 04-25-2013, 03:26 PM Thread Starter
STRRAYNGE
Got tcase, driveshaft, and shifter with selec-trac bezel!!
post #14 of 21 Old 04-25-2013, 06:16 PM Thread Starter
STRRAYNGE
Well, here it all is!!
post #15 of 21 Old 04-26-2013, 12:56 AM
texlurch
Can't see the pics but sounds like you scored!
texlurch is offline
