Jeeper in Need of Help! - JeepForum.com
post #1 of 6 Old 08-25-2007, 10:29 AM Thread Starter
Pinky&theJeep
1981 CJ7
Colorado jeepers, I need some help and I will pay.
I just CANNOT get the timing cover back on my 258 with the oil pan in place. I am afraid I will have to take the oil pan off and I'm not sure about doing that either without someone who has done it or knows what they are doing.
I found the noise, the damper is rubbing against the timing cover. I got a new cover, a new damper, but I am having problems with getting it all to fit right. Can anybody help me? I can't drive it anywhere, and I still would like to do this. I don't want to tow it to a shop and tell them to fix what I can't because then I'll never learn.
I am north of Denver, near 88th and Washington.
I'll have to go get new gaskets. PM me if you can help.
Thanks.
Pinky and the Jeep
1981 (at least that's what the vin plate says) Jeep CJ-7
Colorado Jeep Club Member #258
Pinky&theJeep is offline
post #2 of 6 Old 08-25-2007, 04:28 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Moved your post into a new thread
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 6 Old 08-25-2007, 04:41 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Don't be afraid of removing the oil pan. It's less of a job than the timing cover. In fact, it really needs to be removed (or at least dropped down) to do the timing cover properly. It will also give you a good oportunity to clean the pan out, and make sure the oil pump pick-up is good n clear of any gunk/debris.
You had the marbles to pull the timing cover, so you got nothing to fear dropping the pan . Just don't over-tighten the bolts, and use a criss-cross pattern when putting the pan back on.
Kruzin is offline
post #4 of 6 Old 08-25-2007, 06:25 PM Thread Starter
Pinky&theJeep
1981 CJ7
Cj
Thanks, Im a bit frazzled right now, I'm surprized I didn't post it on some gardening website. At least I got close.
However, as for the timing cover I am so far out of the ball park I can't stand it.
Will the alignment of the timing cover with the vibration damper make the damper chew up the front of the cover where they meet in front?
What keeps them from touching to begin with? They don't look like they should be actaully touching. But now a second timing cover, with a new damper has been shaved off.
What the F%$@ am I missing? All I've seen is that if the timing cover isn't centered I'll have an oil leak. This is no oil leak. This is a shreaking noise as the damper shaves the front off of the cover. I just DON"T GET IT. I've looked at the tear-down pics. I don't see anything different. I found an oil slinger, which was missing fron the original engine, and installed that.
I'm going to get ANOTHER timing cover from spitfire on Monday.
Could the cam be bent or crooked? This is a brand new engine, and save the horrid screeching it sounds and runs GREAT. When it is together.
OK. I'm done.
Pinky and the Jeep
post #5 of 6 Old 08-28-2007, 10:40 AM Thread Starter
Pinky&theJeep
1981 CJ7
OK, thank you to all of those who helped.. I dropped the oil pan...such a huge difference, and I took my 2 dampers and 2 timing covers over to Spitfire Engine (where btw they can dyno a 258) and Mark Logan, the owner looked at it and told me exactly what was wrong, the bolts on the pulley attached to the damper were too long.
Frustrated since a professional installed that particular part of the engine, I went home and ground off a third of the bolts, reassembled and it sounds AWESOME! I just need to get the fuel injection tuned or fixed or whatever it needs and I am a happy jeeper!
Thanks again
Pinky and the Jeep
post #6 of 6 Old 08-28-2007, 10:55 AM
ArloGuthroJeep
Mr. Hyde!
Glad to hear you get it worked out
Newest Jeeper Naturalhoosier Colorado Jeep Forum 24 06-25-2009 09:34 PM
Jeeper gone bad element981 Colorado Jeep Forum 3 07-28-2008 11:39 AM
Help a Fellow Jeeper ColoradoTJ Colorado Jeep Forum 4 04-27-2008 09:01 AM
Another CO Jeeper here elks96 Colorado Jeep Forum 0 04-15-2008 09:11 PM
