Jeep repair day - Page 2 - JeepForum.com
post #16 of 40 Old 12-06-2006, 06:17 AM
E_ROCK
Originally Posted by KUK9
It must be nice to have the cash for OBA!! I need to start saving up to get me a setup as well. Has anyone heard any differences between the York and Kilby OBA? I know that I can get the full setup from Kilby for like $1200, but not sure if it's that much better/worse than York....
I can't see paying this price. I know YJ are a little different and I didn't have AC to start with, but I set up a complete OBA system for $250.
Here is my winter list
Make a front D44 truss (if it is easy, make the rear one too)
Install hydro assist
Redesign hood hoop/bumper
Redesign tube fenders
Make a front square DS
Play around with my front suspension to strectch it out a couple of inch.
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #17 of 40 Old 12-06-2006, 08:05 AM
dnrisden
Rise of the Silver Slinky
dnrisden's Avatar
I want to retain my ac so a brkt to move the altenator down and mount the york compressor that I already have and then just add the clutch. I found everything that I need on sale with free shipping for $280.00 so not to bad?
Later,
Don
dnrisden is offline
post #18 of 40 Old 12-06-2006, 09:57 AM
KUK9
KUK9's Avatar
Later,
Don
Where did you get all your stuff from? I don't really know where to get a used compressor, so I think that's a big part of things. Where did you get your brackets and everything?
REDLYNER Racing #4550
My Build Thread:
http://www.jeepforum.com/forum/f22/adapt-die-kuk9s-stretch-tj-build-1160620
KUK9 is offline
post #19 of 40 Old 12-06-2006, 11:41 AM
dnrisden
dnrisden's Avatar
I'll have to send you a link for the brkts, but as far as the ac pump you can visit the local salvage yard or look for someone parting out an older(late 70 early 80s) vehicle that has the york compressor. A used compressor should only cost 30-40 buck as the clutch will have to be replaced with a new one.
Later,
Don
dnrisden is offline
post #20 of 40 Old 12-06-2006, 02:00 PM Thread Starter
jeepster93
jeepster93's Avatar
I know a couple of us(like me, I use an Extreme Flow) are using a sanden compressor instead of a york...
6 of 1 half dozen...
My Winter list:
replace rear springs( 1 broken leaf and a sagging jeep)
replace aluminim pinion shims with steel
install a coelessing filter on the oba
replace red battery cable
replace front front drive shaft u-joint
8.8 rear diff(at which time I will have a used Super 35 with a Detroit and disc brakes for sale)
Sye and a new drive shift(low)
I have accumulated these parts for the winter:
2 new BDS springs
4 bump stop extenders
2 steel pinion shims from Poison Spyder
4 new axle u-bolts(see below)
Battery cables
Front ds u-joint
I did buy a cheap output filter(harbor freight) for the oba, but have thought twice about installing it(will go to kilby for it instead)
I am debating the changing the shackle u-bolts to the dynatrac reversal set, so will not do spring work until the debate has been won by one side or the other.
jeepster93 is online now
post #21 of 40 Old 12-06-2006, 02:32 PM
KUK9
KUK9's Avatar
Is the S35 coming out of your YJ? If so, I might be interested in it for my XJ. It might be an easier route than getting all the stuff for the 8.25 that I was going to do to run my 33's. What's it geared at?
My Build Thread:
KUK9 is offline
post #22 of 40 Old 12-06-2006, 03:08 PM Thread Starter
jeepster93
jeepster93's Avatar
It would be the one I am using now on my Yj(remember...I am still using it )
It is geared at 4.11 with Yukon gears. It has Superior 4130- 30 spline axle shafts. Detroit 30 spline Soft locker. The disc brakes are from a '90s ford ranger, so parts are cheap and around. It has a 3/8 by 3 inch truss on each axle tube. The tubes are welded to the pumkin.
As Dana 35's go, this one is sweet.
Prolly looking at after the new year before I do any thing about it.
If you want...I'll give you first shot...It is well USED.. so it will most likely will be CHEAP
post #23 of 40 Old 12-06-2006, 04:03 PM
KUK9
KUK9's Avatar
I would be very likely to take it off your hands. I've got the S35 in my TJ, and it'd be a better route for me to go with as opposed to the 8.25 in the XJ. I'd need to regear it, and likely redo the spring perches, but no biggie there. Let me know when you get it swapped!
My Build Thread:
KUK9 is offline
post #24 of 40 Old 12-07-2006, 12:18 AM
RollerHman
Make Jeep Great Again
RollerHman's Avatar
so it sounds like we all have a to-do list, are we gonna get together and do some work? done with school for the winter shortly....
Colorado Jeep Club Member #46
16 Renegade
99 XJ
RollerHman is offline
post #25 of 40 Old 12-07-2006, 08:14 AM
Naturalhoosier
Naturalhoosier's Avatar
I'm off work on the 22nd if we want to get together then!
--Nick
My Ride: 1998 GC Limited
Colorado Jeep Club Member #15
Black Jeep Club Member #1976
Make the world a better place, punch a Boilermaker in the face!!!
Don't blame me...I didn't vote for him.
Naturalhoosier is offline
post #26 of 40 Old 12-07-2006, 08:54 AM Thread Starter
jeepster93
jeepster93's Avatar
I will talk to my boss about using the parking lot for our repairs. It is a small place, perhaps 4 or 5 rigs at a time. The nice thing is, it is centrally located at I-25 and Evans.
I will ask about the 22nd.
post #27 of 40 Old 12-07-2006, 09:35 AM
Naturalhoosier
Is it inside?
--Nick
post #28 of 40 Old 12-07-2006, 10:13 AM
KUK9
KUK9's Avatar
Bah. You people and your getting days off! Must be nice! Looks like I'll be out if we do it the 22nd. No biggie.
My Build Thread:
KUK9 is offline
post #29 of 40 Old 12-07-2006, 11:11 AM
RollerHman
RollerHman's Avatar
hmmmm early on the 22nd? i was supposed to head to the mountains that day for xmas, i really wanted the stuff on there before than so i could go wheel up in summit county.
16 Renegade
99 XJ
post #30 of 40 Old 12-08-2006, 06:30 PM
2fastlx
2fastlx's Avatar
Does anyone need any welding done?
Colorado Jeep Club Member #44
I couldn't really understand what you were saying or asking, but I think you need a bigger hammer.
2fastlx is offline
Recommend Shop for T-Case repair kagraham Colorado Jeep Forum 2 12-08-2009 02:56 PM
windshield crack repair rballman Colorado Jeep Forum 10 04-02-2009 02:14 PM
Repair shops in the CO Spgs area mxmike211 Colorado Jeep Forum 1 03-03-2009 06:00 PM
repair help?? PillowPants Colorado Jeep Forum 22 05-15-2008 09:53 AM
