Colorado Jeepers Unite!!! - Page 827 - JeepForum.com
post #12391 of 12519 Old 08-01-2012, 05:22 PM
FPKites
ZJjazzyJim
FPKites's Avatar
You can cause locker issues if you have different tires on the same axle, but that's on the street. If you need to use the spare to get off the trail, run it.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #12392 of 12519 Old 08-01-2012, 05:23 PM
1320quick
What size is your spare???? If it's not the same size as the other 4 tires, he is right. Having a different size spare is a no no and should only be done in an emergency. I know on the muscle cars I play with, a different size tire on the drive axle will burn up the clutches in the posi and I'd guess it would be hard on parts and make handling dangerous in you jeep. If its the same size and just worn out, you will be fine with it.
My 03 Rubicon build thread ---> http://www.jeepforum.com/forum/f22/1320quicks-03-rubicon-build-1504699/
1320quick is offline
post #12393 of 12519 Old 08-09-2012, 12:32 PM
jeepster93
jeepster93's Avatar
My spare is the same size, 33x12.50 but just worn out.
Luckily I have selectable lockers, so controlling on/off is easy. Will just keep the locker on that axle off while using the spare, which I hope is never.
The best I can do is $225(+tax) unmounted on a spare MT/R. So I'll keep looking for a bit. With luck...the right deal will present itself.
jeepster93 is offline
post #12394 of 12519 Old 08-09-2012, 12:45 PM
jeepster93
jeepster93's Avatar
So...
I blew the fan controller, that fancy DCC controller for the Taurus fan.
He fixed it. No biggie other than the down time and even then he(DCC) sent me a courtesy loaner controller for the 2 weeks it took to repair mine. Which to be fair is 4 years old.
This brings up a chance to add a on/off switch to the fan. For water crossings.
How useful is that going to be to me? The ability to turn off the electric fan.
Knowing 99% of my wheeling is Colorado/Utah. And I drive a not at all deep water resistant vehicle.
post #12395 of 12519 Old 08-09-2012, 10:49 PM
FPKites
ZJjazzyJim
FPKites's Avatar
I'm really glad to see that Brian is taking care of your controller after 4 years. Mine is running strong after 5+
For the on/off switch, I would get a super high amperage switch (maybe a relay setup?) and put it on the main lead. I put one on the yellow (switched) lead, and I'm not sure it completely cuts it off. Amp draw is lower when I switch it off though.
I cross water just as much as you, maybe less. I think my deepest water crossings over the past 5 years were Jenny Creek and Coney Flats. Coney is the only one I would have even thought of turning off the fan.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #12396 of 12519 Old 08-10-2012, 07:54 AM
jeepster93
jeepster93's Avatar
So disconnecting the yellow wire doesn't shut off the fan?
Not gonna worry much about it then. Not important enough to spend and mod.
Been to Jenny creek this year and it isn;t even going to get the hub caps wet.
I'll pass on that mod then.
I just rebuilt the transfer case and REMOVED the 2lo shift fork for the stock one. I never used it and even more so, found the indent hard to find and would find it by accident more often than not. That was an expensive and major pain.
Shhh...I am also sorta looking for a real small air compressor to run the lockers so I don't need to fire up that fancy belt driven oba for a simple locker engagement. Not sure of the value in it though, a small ARB compressor, I mean SMALL, is a couple hun.
post #12397 of 12519 Old 08-10-2012, 12:23 PM
Shag
Shag's Avatar
Tom is the 2 lo for a NP231? If so what are your plans for it?
____________________________________
Shaun
Originally Posted by afbond03
....just need a nice tug it would be really simple to get me from behind just pull me back....
is a thief. I bought
gears from him, and now I am out my money and still no gears. Do not trust him.
Shag is offline
post #12398 of 12519 Old 08-10-2012, 08:14 PM
FPKites
ZJjazzyJim
FPKites's Avatar
There's a distinct possibility that while I think I got the high-ish end switch from Advance that it may be not completely severing the circuit and sending enough current to turn on the controller, but still keeping it below the 2 amps that it was eating.
My level of electrical knowledge is nowhere near enough to be sure.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #12399 of 12519 Old 08-12-2012, 12:51 PM
jeepster93
jeepster93's Avatar
Shaun- I will let you know if it is no longer wanted. It came from my 231-j with a tera low and sye, it came from Advanced adapters with the sye, I think. Used only when I kind of made a point of doing so. I could see a use for it if you have an auto or lunch box locker in front and you need to remove the locker from the system, otherwise...
Jim- the yellow wire is the exciter wire, it really shouldn't carry much power, just sense the power supply for a switched/unswitched thing.
post #12400 of 12519 Old 08-12-2012, 02:04 PM
Shag
Shag's Avatar
I have a Spartan that I need to install in the front, so that would be perfect.
Shaun
Shag is offline
post #12401 of 12519 Old 08-12-2012, 09:10 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Yep - that's the one I was talking about. It doesn't carry much amperage by itself, but it does perform the switching for the relay - which applies power to the main power lead, which appears to draw 2.5a + at idle.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #12402 of 12519 Old 08-15-2012, 07:32 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Hey Jim what happened to the stickies in this section?
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #12403 of 12519 Old 08-15-2012, 07:33 AM
ArloGuthroJeep
Mr. Hyde!
Nevermind, look like they are still stickied, just not being identified as such.
post #12404 of 12519 Old 08-15-2012, 11:35 AM
jeepster93
jeepster93's Avatar
Close in jeepin' this weekend?
I DO NOT want to get involved in the traffic on I-70.
Jenny creek or some other closer trail not on I-70???
post #12405 of 12519 Old 08-15-2012, 08:43 PM
FPKites
ZJjazzyJim
FPKites's Avatar
I think the separator line that we had is gone. Not sure why. I'll see if there's any chatter in the mod section
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
Colorado Jeepers -- For Sale/Trade/WTB Thread RAAB3485 Colorado Jeep Forum 1494 04-01-2017 10:30 AM
Trail Advice from Colorado Jeepers Gymguyjeep Colorado Jeep Forum 13 06-04-2009 07:39 PM
Colorado Jeepers Trail advisements KUK9 Colorado Jeep Forum 6 07-13-2007 02:46 PM
Colorado Jeepers -- Pics of your Jeep Before, During and Now RAAB3485 Colorado Jeep Forum 54 03-01-2007 02:11 PM
Colorado Jeepers holiday party KUK9 Colorado Jeep Forum 76 12-19-2006 08:25 PM
