ATTN : Josh ( others can chime in if they know ) - JeepForum.com
post #1 of 16 Old 08-27-2007, 08:19 PM Thread Starter
CLNinja
CLNinja's Avatar
I'm not sure if its related to the tires/wheels but...
on my way home from the install when you put them on there was 2-3 very loud popping noises as i was going down the highway
one came from the left side of the Jeep and 2 from the right
checked everything out and didnt see anything out of the ordinary.. still drives just fine... nothing noticable
yesterday it happened again.. 1 more very loud popping noise.. this time from the left side of the Jeep
is this normal or maybe have nothing to do with the new tires/wheel mounting?
I'm not too worried about it atm cause the Jeep still drives perfectly fine. I'm just really wondering what it is and if its something i SHOULD be worried about
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #2 of 16 Old 08-27-2007, 08:28 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Check your lug nuts
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 16 Old 08-27-2007, 08:32 PM
dnrisden
Rise of the Silver Slinky
dnrisden's Avatar
It's a Jeep?!
dnrisden is offline
post #4 of 16 Old 08-27-2007, 09:45 PM
KUK9
KUK9's Avatar
Umm....yeah. That's kinda wierd. I would definately start by checking your lug nuts- make sure they are all torqued down correctly. Check the wheel weights- see if they may have flown off. If it were anything related to the wheels/tires, I would think it would be one of those two things.
Without knowing exactly where the sounds were coming from, or how they sounded, I would start there. Check all your connections underneath as well- make sure everything is tightened down. It's quite possible that a wheel weight may have popped off and hit something, causing the sound.
REDLYNER Racing #4550
My Build Thread:
http://www.jeepforum.com/forum/f22/adapt-die-kuk9s-stretch-tj-build-1160620
KUK9 is offline
post #5 of 16 Old 08-28-2007, 10:24 AM Thread Starter
CLNinja
CLNinja's Avatar
it looked like all the wheel weights were on... ill double check though
Matt
CLNinja is offline
post #6 of 16 Old 08-28-2007, 10:28 AM Thread Starter
CLNinja
CLNinja's Avatar
wheel weights ( as far as i can tell ) are all on there.. i also dont have any vibes and im assuming missing weights would cause vibes from being off balance
lug nuts are all tight and secure
Matt
CLNinja is offline
post #7 of 16 Old 08-28-2007, 06:50 PM
towermonkey
2008 WK
What kind of tires? Could it be rocks? My TJ drove me nuts kicking rocks into the fenders after I got new BFG TA's
towermonkey is offline
post #8 of 16 Old 08-28-2007, 07:19 PM
KUK9
KUK9's Avatar
Ya got me stumped on this one. Since you've checked the wheels and weights, I wouldn't think it would be there any more. It's even more difficult if everything is tight underneath. You don't have any wierd rubbing or anything anywhere, do you?
My Build Thread:
KUK9 is offline
post #9 of 16 Old 08-29-2007, 10:04 AM Thread Starter
CLNinja
CLNinja's Avatar
no ive checked everywhere
i havnt heard it anymore so im just gonna forget about it.... if it happens again..then i will start really worrying about it
if i was to describe the sound it makes... the closest thing id be able to compare it to would be a champagne cork....but alot louder
Matt
CLNinja is offline
post #10 of 16 Old 08-29-2007, 10:53 AM
FPKites
ZJjazzyJim
FPKites's Avatar
Tread lugs all intact?
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #11 of 16 Old 08-29-2007, 12:02 PM
dnrisden
dnrisden's Avatar
Originally Posted by dnrisden
It's a Jeep?!
Just thought I would reiterate.
dnrisden is offline
post #12 of 16 Old 08-29-2007, 07:06 PM
froggo27
froggo27's Avatar
and i'll second that.
Kamil
04 WJ Limited
froggo27 is offline
post #13 of 16 Old 09-04-2007, 01:29 AM
FortCollinsZJ
I got a pinging noise from a slightly worn and loose old trackbar... and the same with loose control arm.
FortCollinsZJ is offline
post #14 of 16 Old 09-05-2007, 10:44 PM Thread Starter
CLNinja
CLNinja's Avatar
i figured out what it was... it did end up being wheel weights that got thrown off
Matt
CLNinja is offline
post #15 of 16 Old 09-06-2007, 07:25 AM
KUK9
KUK9's Avatar
I guessed it! I win!! Wait...I'm the one who put those on...so I lose.
At least you got it figured out. I must not have used ones that pinched down enough on the rim. You might want to double check the rest of the tires- maybe tap them with a hammer to make sure they are still tight. Sorry about that!
My Build Thread:
KUK9 is offline
ATTN : ZJ OWNERS - lifted ZJ found at junkyard CLNinja Colorado Jeep Forum 11 10-08-2009 12:18 AM
Attn: Don RyanZJ Colorado Jeep Forum 9 01-03-2008 04:09 PM
