Arlo's WJ Buildup thread - Page 8 - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South Central USA > Colorado Jeep Forum > Arlo's WJ Buildup thread
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 08-13-2007, 01:43 PM   #106
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Nope, there is quite a bit of room between them.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline   Reply With Quote Quick reply to this message
Unread 08-13-2007, 02:16 PM   #107
FPKites
ZJjazzyJim
FPKites's Avatar
Definite design change from ZJ to WJ then - swaybars (front and rear) are pretty close to the coils in mine.
Jim Karlin
"Duh! Big RED Jeep!!!"
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline   Reply With Quote Quick reply to this message
Unread 08-13-2007, 02:19 PM   #108
ArloGuthroJeep
Mr. Hyde!
Here you can see the axle at full droop (ie: sway bar is as close as it'll get):
Unread 08-13-2007, 02:41 PM   #109
FPKites
ZJjazzyJim
FPKites's Avatar
That's right...completely different design. Axle-centric bar instead of frame-centric like the ZJ. I spaced that.
Jim Karlin
96 ZJ Laredo
04 WJ Overland
Clean.... :D
Unread 08-13-2007, 09:06 PM   #110
ArloGuthroJeep
Mr. Hyde!
Received a R&P, carrier, and master install kit for my front axle
Unread 08-13-2007, 09:13 PM   #111
REDLYNER
Mall Crawling Racer
REDLYNER's Avatar
Getty up buddy!
Installing it this weekend?
REDLYNER is offline   Reply With Quote Quick reply to this message
Unread 08-13-2007, 09:16 PM   #112
ArloGuthroJeep
Mr. Hyde!
Yeppers, 7am Sat morning
Unread 08-13-2007, 10:03 PM   #113
froggo27
nice Ryan, whats next? a V8 swap?
Kamil
04 WJ Limited
My Trail Pics!!
froggo27 is offline   Reply With Quote Quick reply to this message
Unread 08-13-2007, 10:07 PM   #114
ArloGuthroJeep
Mr. Hyde!
I hate V8 juice
Unread 08-13-2007, 11:26 PM   #115
FPKites
ZJjazzyJim
FPKites's Avatar
It's an acquired taste
Jim Karlin
96 ZJ Laredo
04 WJ Overland
Clean.... :D
Unread 08-14-2007, 09:28 AM   #116
ArloGuthroJeep
Mr. Hyde!
Yikes, $177 for wheel bearings, seals, and retainers. I think that order will have to wait a couple weeks
Unread 08-16-2007, 03:17 PM   #117
ArloGuthroJeep
Mr. Hyde!
Decided to go through Napa instead of Kolak. I picked up some rear wheel bearings. Napa only had one rear axle seal so since I am not leaking from either side, I'll try and get by like that.
Napa didn't have any (or even list) front axle seals. I'll give checker a shot tonight after work.
Unread 08-16-2007, 03:56 PM   #118
dnrisden
Rise of the Silver Slinky
dnrisden's Avatar
The front axle seals maybe a dealer only item, But not sure?!
It will be sweet to see it in action on Black Bear
dnrisden is offline   Reply With Quote Quick reply to this message
Unread 08-16-2007, 05:25 PM   #119
87Xota
1988 XJ Cherokee
I have a pair for a XJ HP30, Checker probably calls them inner axle seals. No part number on mine.
edit: probably the inners will be a National part # - 710068
If they are trying to sell you a part # - 722108, I think that is wrong, it's an outer that comes inside a unit bearing.
87Xota is offline   Reply With Quote Quick reply to this message
Unread 08-18-2007, 06:45 PM   #120
ArloGuthroJeep
Mr. Hyde!
With MUCHO help from Terry (87Xota) I was able to swap in 4.56 gears this morning. The second the cover came off, I noticed my spiders were HOSED...The pinion shaft spiders had chunks missing from all of the teeth Luckily Terry had some spares laying around from another D30 install he had done
Replaced the front & rear axle seals, rear wheel bearings...
That solved a mini vibration I had beteen 30 and 33 mph. Now I just have a whirl upon decelleration (perhaps it is just the new gears?)
