Arlo's WJ Buildup thread - Page 23 - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South Central USA > Colorado Jeep Forum > Arlo's WJ Buildup thread
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 03-18-2013, 04:54 PM   #331
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Axles have held up fine - but I am pretty light on the gas.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 08:33 AM   #332
Kdeome
Arlo did you cut/roll your front fenders or just cut them?
Kdeome is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 09:49 AM   #333
ArloGuthroJeep
Mr. Hyde!
Cut and roll. Then sanded down the paint where it chips off (at the roll), and "rhino-lined" (different brand though) the exposed metal. I re-paint it every 1-2 years as necessary. This last coat seems to be lasting a lot longer though.
http://arlojeep.com/Trip-Reports/LHC-5-31-09/
Unread 12-31-2014, 12:04 PM   #334
redman333
Hey if I run the same lift and then add the bushwacker flares to the setup do you think 35s would be doable? Also before you trimmed could you drive around town without issues. I want to run 35's just don't know if I can or not. It's my daily but I do have another vehicle to drive but would rather not have the WJ down too long. I'm thinking if I can lift it and then mount the 35s and drive around town and see what else needs to be done then I can do those later.
redman333 is offline   Reply With Quote Quick reply to this message
Unread 07-25-2015, 09:25 PM   #335
=KZ=
Hey Arlo I was wondering if you could give me a little advice. I have a set of ironmanfabrications adjustable control arms and am at 3.25 inch lift front and 2 inch rear. I am gonna trim up the fenders like you did, but would like to get my 285 70 17 (33s) duratracs on the vehicle but lack the time off work and noticed that you ran yours without doing all the trimming. Did you need to put the axles as forward and back as far as possible to avoid having to trim near the doors or is this the kind of thing a guy needs long arms for? any tips would be appreciated thanks! also im using 17" moabs off a jk with 1.25" wheel spacers
Looking to buy 4" front BDS springs
=KZ= is offline   Reply With Quote Quick reply to this message
