Arlo's WJ Buildup thread - Page 2 - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South Central USA > Colorado Jeep Forum > Arlo's WJ Buildup thread
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 02-09-2007, 09:52 AM   #16
jeepster93
I think I even have most of a d30 install kit too.
I know I have the carrier bearings and the pinion and crush bearings and seals, all new. I think I have a set of shims somewhere too.
It is a superior install kit. Bought it from Northridge 4x4.
I bought this install kit for my d30 arb locker install, but the arb came with everything needed less the consumables(thread locker and gear paint).
This I would sell to you as it is all new...$25 (worth about $125plus)
If you are installing the carrier yourself, I have the tools also(bearing puller, micrometers, bearing press, dial indicator and magnetic holder)
Tom
jeepster93 is offline   Reply With Quote Quick reply to this message
Unread 02-09-2007, 09:56 AM   #17
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
I'll take it As for the install I was going to ask Terry of Rock Frogs to help show me the ropes on that
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline   Reply With Quote Quick reply to this message
Unread 02-09-2007, 10:23 AM   #18
ArloGuthroJeep
Mr. Hyde!
Originally Posted by dnrisden
I can help with this portion of the build. The bumper reinforcement can be cut and a reinforcement welded further back toward the radiator. There is a ton of room there if you modify the bumper reinforcement. I have worked on many of the Wj's after an accident and have quite a bit of knowledge on how the assembled. This would be a lot easier than moving the radiator and condensor.
Let me know.
Don
Thats great news, as soon as I get a welder I plan on ripping into the front and seeing how much I can cut away
Unread 02-09-2007, 12:53 PM   #19
nierace
2003 WJ
Originally Posted by ArloGuthroJeep
The truss is from the RK LA lift kit
So it's not compatable or you refuse to have anything RK on your vehicle ?
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
sira4x4.net North East Offroad Club
www.carolinadriveline.com
www.ironrockoffroad.com
kolak@aol.com
nierace is offline   Reply With Quote Quick reply to this message
Unread 02-09-2007, 01:18 PM   #20
ArloGuthroJeep
Mr. Hyde!
Not compatable...
RK Truss:
Just realized that Claytons isn't a truss, it is just a different bracket that mounts on top of the diff...
Claytons kit:
Here you can see the bracket on top of the pumpkin:
Unread 04-12-2007, 10:09 AM   #21
ArloGuthroJeep
Mr. Hyde!
Have a D44a sitting in my garage that I am going to build up.
Already has 4.56 gears
But wait! Holy CRAP!
Pulled from this thread I called up Randy's R&P and wanted a quote on the axle shafts. The 3x and 4x part numbers is what I would need.
Turns out Yukon doesn't make the shafts anymore, but Dana/Spicer does. Their versions run $322.92 for the passanger and $399.20 for the drivers side Freaking $725 for the axle shafts!
The axle shafts do already come with the wheel bearings pressed on and the lugs installed
Think I'll try and source the Yukon's elsewhere if I can find them...
Unread 04-12-2007, 10:19 AM   #22
KUK9
Wouldn't you be fine with the stock shafts for a while? I understand upgrading, but I would think you'd be fine on the stockers for a while. Are you going to lock it too?
REDLYNER Racing #4550
My Build Thread:
http://www.jeepforum.com/forum/f22/adapt-die-kuk9s-stretch-tj-build-1160620
KUK9 is offline   Reply With Quote Quick reply to this message
Unread 04-12-2007, 10:21 AM   #23
ArloGuthroJeep
Mr. Hyde!
Yeah gonna lock it, and I would probably be fine for a long time on stockers. Just wanted to upgrade them while I have the axle torn apart.
Unread 04-18-2007, 11:47 PM   #24
ArloGuthroJeep
Mr. Hyde!
Got the truss all cut off my axle:
Just need to grind down the old welds now:
Unread 04-19-2007, 09:46 AM   #25
KUK9
Looks like you had fun getting it cut off!
My Build Thread:
Unread 04-19-2007, 09:54 AM   #26
ArloGuthroJeep
Mr. Hyde!
Had to use a hacksaw at the end to get to placaes I couldn't get my grinder...that sucked. Oh well it is off now and I'll never have to deal with that SOB again After ~2 minutes of cutting w/o ear plugs I realized how important they are
Unread 04-19-2007, 10:13 AM   #27
RyanZJ
Do you have a spare t-case in your garage?
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline   Reply With Quote Quick reply to this message
Unread 04-19-2007, 10:20 AM   #28
ArloGuthroJeep
Mr. Hyde!
It is a 247...and is missing most of the bolts since I have been trying to open the sucker up to see how the PC (Progressive Coupler) works. You're welcome to have it if you want it
Unread 04-22-2007, 10:57 PM   #29
ArloGuthroJeep
Mr. Hyde!
Ground off the rest of the truss yesterday and stripped down the axle.
Grinding pics always look cool to me 8-)
All smoothed out:
Axle stripped down as far as I'll take it (might take out the bump stops)
Bent back the brake dust shields (they were damaged from transport)...
The axle shafts I have look to be in good shape, I would however rather start with fresh shafts and use these as trail spares. I am having trouble sourcing shafts for this and unfortunantely may be looking at buying OEM shafts through my dealer contact (so at least a discount)
To buy:
1) New axle shafts (Upwards of $700 - that might wait)
2) Ebrake & regular pads + rotors ($100)
3) New brake lines ($100 for F&R)
4) Aussie locker ($259)
5) Possibly new calipers. These have been sitting outside for 1.5 years with no brake line connected to them. I fear they are rusted inside. ($175)
Unread 04-23-2007, 12:01 AM   #30
REDLYNER
Mall Crawling Racer
REDLYNER's Avatar
You should come out to our mod party next weekend. There will be lots of unbolting, bolting, grinding, and unbolting, and bolting.
Axle is looking good man!
REDLYNER is offline   Reply With Quote Quick reply to this message
