Arlo's WJ Buildup thread - Page 13 - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South Central USA > Colorado Jeep Forum > Arlo's WJ Buildup thread
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 03-25-2008, 11:00 PM   #181
froggo27
how bout i give you $3.50 each time i fill my tires? i want a CO2 tank too, it's fast!
Kamil
04 WJ Limited
My Trail Pics!!
froggo27 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2008, 12:53 AM   #182
newracer
FYI I removed the fitting where you can attach the hose. It looked like it would limit volume to me. It is a back-flow preventer, as long as you don't leave the valve open blowing CO2 you don't need it.
newracer is offline   Reply With Quote Quick reply to this message
Unread 03-26-2008, 08:31 AM   #183
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Cool, thanks for the tip
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline   Reply With Quote Quick reply to this message
Unread 04-14-2008, 12:19 AM   #184
ArloGuthroJeep
Mr. Hyde!
Well I used that tip and removed that check-valve...I couldn't find a female fitting to fit on that end anyways
Nearly burned down my Jeep welding in there, but I did it...have a mounted CO2 tank. The bin that is normally there (or CD-changer for those fancy WJ's) had broken (too much weight - recovery gear) and so I pulled it out and mounted my CO2 tank. Washers and bolts and spacers and a few tack welds and WALA:
Is slightly angled, 80-85deg or so. I think it'll be fine at that angle not being perfectly up...25ft coil hose easily reaches all the spots as well
Unread 04-14-2008, 12:36 AM   #185
CLNinja
doesnt look right in a WJ... we should see if it looks better in a 93 ZJ
[color="#003300"]Matt[/COLOR]
[color="white"][CENTER][size="1"]
[url="http://www.jeepforum.com/forum/showthread.php?t=434081"][color="white"]Click Here For My Build Thread[/COLOR][/url]
[/COLOR][/SIZE][B]**September 2009 Grand Cherokee Of The Month**[/B]
[SIZE="2"][url="http://www.jeepforum.com/forum/forumdisplay.php?f=123"][color="white"]Colorado Jeep Club Member #88[/COLOR][/url][/SIZE][/CENTER]
CLNinja is offline   Reply With Quote Quick reply to this message
Unread 04-14-2008, 08:33 AM   #186
dnrisden
Rise of the Silver Slinky
dnrisden's Avatar
Sweet, you love that on the trail or at least at the end of the trail.
Don
03 Rubi w/SC/5.5 LAs/37s/Armor/always growing.
dnrisden is offline   Reply With Quote Quick reply to this message
Unread 04-18-2008, 09:39 AM   #187
ArloGuthroJeep
Mr. Hyde!
My knuckle inserts for my tie rod flip (poor mans high-steer) showed up yesterday...Perhaps Sunday I'll drill, weld, and flip
Unread 04-18-2008, 09:46 AM   #188
grenMEG
I tried it with out inserts and just tried to drill out a tapered end...It was interesting lil squirly on the highway .
If i would of done it 100 percent (w/inserts) it would of been perfect. You will like it.
Do you have spaced rims? my TRE rubbed the inner wheel, but they were stock Jeep Alloys. just grinded them sucka's
By the way how is your miller working out for you? Right now i am looking at a hobart 187 (220v) MIG, any suggestions input?
grenMEG is offline   Reply With Quote Quick reply to this message
Unread 04-18-2008, 10:16 AM   #189
ArloGuthroJeep
Mr. Hyde!
I imagine my bump steer will increase a bit since my draglink and trackbar will no longer be 100% parallel. Sounds like a good project, raise the trackbar mount
Yeah I have 4" BS (vs 6" stock) so I shouldn't rub at all - am following another WJ guys writeup. One of my friends who also did this swap found that if I order a Tie Rod End for a Right Hand Drive WJ, that I can use that. The original guy who did this had to get a chevy TRE, bend it, and then braced it where he bent it...
Miller is working great...Looks like in 3 weekends I'll head down to pick up some steel and over the next couple weekends, I'll start designing my bumper I am still a welder noob so I have no (worthwhile) input for ya
Unread 04-18-2008, 10:24 AM   #190
grenMEG
[QUOTE=ArloGuthroJeep;5104915]
[QUOTE]
Interesting. What do you think you are going to do?
Well atleast you didn't give me some BS about welding... honesty!
Unread 04-18-2008, 10:35 AM   #191
ArloGuthroJeep
Mr. Hyde!
I already ordered the RHD TRE like 6 months ago
Unread 04-18-2008, 10:46 AM   #192
grenMEG
These things take time arlo, its ok, its ok (pat on the back)
Unread 06-09-2008, 02:14 PM   #193
ArloGuthroJeep
Mr. Hyde!
Woot...Ordered Clayton's LA kit for my WJ...$600 off the regular price because of a 25% off gift certificate they hooked up GSW with and I pseudo-won - they just raised their prices because steel went up in price (again) so that saved me $150... Should be here late next week.
I'll be running on 4" of lift until I can swing the cash for another set of springs which will probably happen either next month or as soon as I sell my current lift stuff.
Unread 06-10-2008, 09:34 PM   #194
froggo27
I hate you! Don't you want to try those LA on my Jeep first just in case they are defective?
Kamil
04 WJ Limited
My Trail Pics!!
Unread 06-11-2008, 02:55 AM   #195
Colorado 5.9
I'm sure you know you'll have to set the pinions all over again if you run the 4" then go higher later on. It's a real pain to do over. If you go a few months it woun't seem that bad but if you get the new springs in a month or so I'd just wait & do the whole thing at once.
I do realize you want to get rid of those great tera arms asap though.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Latest Pics
Colorado 5.9 is offline   Reply With Quote Quick reply to this message
