Arlo's WJ Buildup thread - Page 20 - JeepForum.com
post #286 of 335 Old 05-30-2009, 10:15 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Anything's better than the 4-slow he has
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #287 of 335 Old 06-06-2009, 04:39 AM
nierace
nierace's Avatar
2003 WJ
Looks great Ryan - how did you trim up front for the 35's ? I still haven't gotten mine right yet as I rub on the inner part of the wheel well
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #288 of 335 Old 06-08-2009, 09:40 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Looks awesome. So when can I come pick up the 33s?
Brian
WJ, WK, CJ5
GraKee99 is offline
post #289 of 335 Old 06-08-2009, 09:45 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Brian I wouldn't run my 33's unless it were mostly on the trail...I may have, uhm, neglected them towards the end of their life and have some bad wear patterns on them. If you're interested I'll sell them for pretty cheap though. 4 of the 33's are mounted & balanced and have similar tread depths and still totally worth while for 4-wheeling. The 5th is unmounted and what I would consider completely unused (although I suspect it has a few hundred miles on it). 4" BS, 16x7 Crager Soft 8's (4 rims) + TrXus MT's (4 tires used - 1 new(ish))...let me know.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #290 of 335 Old 06-08-2009, 11:41 PM
GraKee99
Rapist Wit
GraKee99's Avatar
Well it may take me a bit longer to get to a height wear I can use them than originally planned. Looking at CJ5s as we speak and hope to have one of those by September. Trying to move back to Colorado in January/February so funds will probably be tight for a little while. Maybe if I get back and you still have them, we can work something out. Thanks though Ryan, might have to try to hit the trails with you guys before I head back.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #291 of 335 Old 06-09-2009, 10:04 PM
lakailimited06
arlo, can you post pics of your SYE...how hard was it to do? when were you getting vibes?
99WJ 4.0
IRO 3", SYE, D30 aussie/8.8 aussie, 4.10s, 33's, skids/bumpers
lakailimited06 is offline
post #292 of 335 Old 06-25-2010, 01:58 AM
99blkwj
Originally Posted by ArloGuthroJeep View Post
The "ideal" backspacing for the WJ is 4"...AEV only makes the wheels in 4.6" BS and the tires are wider so I was taking a gamble getting these. At full lock I hit my control arms. Time to limit that turning radius
Ill second that, Im at 4" backspacing right now with the "Moabs" im running off a Rubicon TJ (5" backspacing) and the 1" spacers i used to change the bolt pattern. It looked a little goofy with smaller tires but with 35"s on there it looks sick
99blkwj is offline
post #293 of 335 Old 11-15-2010, 03:53 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Someone asked me about my build thread, so I dug it back up and realized I never posted the final pics of my Jeep from the trim job:
That was done in May '09. Between then and now, it has come off a bit in places. My prep was poor (I didn't sand it very well) so I am due to recoat it.
Also squeezed the biggest muffler I could find (happened to be the smallest one out there) to fit here:
Welding on top, blind, is no fun.
See the above pic Closest thing I took to a picture of it
post #294 of 335 Old 11-16-2010, 08:35 AM
Mud_Crazy
well im glad i was able to have you dig it up (apollo if you read this sorry man, went with similar to arlos's. your jeep is still sick though).
anyway sick jeep man. hopefully mine is just as sweet when done. i ordered alot of similar parts your running. i have a question about your drive shaft. although i have the V8. you had to replace the driveshaft when you went to 6" lift? do you know if its the same deal for the V8, will i have to get a new rear drive shaft? also are you running stock front axles, or aftermarket? and how are they holding up with the bigger tires?
SILVER&BLACK 02 JEEP GRAND CHEROKEE 4.7L V8 HO, Clayton 6" liftT w/ Bilstien 5100's and 2in pucks , 37X12.5 Nitto Trail Grappler M/T's on red and black Creeper Locks, front and back Dana 60 w/ ARB lockers, Chromolly shafts and 5.13 gears, ARB compressor, Flowmaster 50 exhuast, K&N FIPK, IRO front bumper and flares, and Cobra 29NW with firestick antenna.
Mud_Crazy is offline
post #295 of 335 Old 11-16-2010, 09:22 AM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Front axle is stock. I busted one CV joint a few years ago (http://www.jeepforum.com/forum/f310/...w-pics-377208/) when I was on 32's in snow - no reason it should have broken then - has been fine since then. I am pretty controlled with the throttle; I like to crawl through stuff slowly w/o wheel spin.
I have replaced my drive shaft too many times to count At 6" I replaced it because I installed a SYE. I was getting a mild vibration under throttle between 35-45 or so IIRC. I couldn't get my angles to stay happy so I installed a SYE and the problem went away. 6" is borderline for needing one, I suggest trying without one and then only if you need to, install one.
post #296 of 335 Old 11-16-2010, 11:02 AM
GraKee99
Rapist Wit
GraKee99's Avatar
Do you know your arm lengths Ryan?
Brian
WJ, WK, CJ5
GraKee99 is offline
post #297 of 335 Old 11-16-2010, 11:08 AM
KUK9
KUK9's Avatar
Do you run into issues with emissions since your exhaust is dumping in front of the axle? Mine does pretty much the same thing, and the emissions monkeys keep saying that they can't (read: won't) test it because it doesn't exit to the outside of the vehicle.
Other than that, looks great man! Wish I could go wheel again with ya...gonna be a while 'til I'm back on the road.
REDLYNER Racing #4550
My Build Thread:
http://www.jeepforum.com/forum/f22/adapt-die-kuk9s-stretch-tj-build-1160620
KUK9 is offline
post #298 of 335 Old 11-16-2010, 11:08 AM Thread Starter
ArloGuthroJeep
Mr. Hyde!
I think about 2/3's the way up the cladding:
Not offhand, but I can measure if you want when I get home
post #299 of 335 Old 11-16-2010, 11:10 AM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Yep, I put on some flex piping (weld it on, that is fun ) and exit it out the side, then an hour later I cut it off. Rinse and repeat every 2 years
How come you can't go wheeling?!?
post #300 of 335 Old 11-16-2010, 01:19 PM
Mud_Crazy
ok so you went through a couple drive shafts with 6". but the sye drive shaft fixed it. and you have not broke any front axles yet with the 35". i dont speed to much either, unless in a deep rut i have to get through. othe rthen that im pretty light on the gas. i also plan on swaping to 4.56 gears to make puttin around places easier and have a bit more torque.
Restaurant Thread shunt Colorado Jeep Forum 73 02-12-2010 08:30 PM
Another Black Friday thread... Naturalhoosier Colorado Jeep Forum 12 11-29-2008 11:36 AM
Arlo's Non-Wheeling Pic Thread ArloGuthroJeep Colorado Jeep Forum 109 12-28-2007 01:59 PM
There is a Colorado for sale thread why not have a WTB thread? luniz7 Colorado Jeep Forum 17 12-03-2007 09:40 PM
CB thread... wojtizzlator Colorado Jeep Forum 24 06-16-2007 07:47 PM
