Arlo's WJ Buildup thread - Page 16 - JeepForum.com
post #226 of 335 Old 06-25-2008, 12:16 AM
theksmith
2003 WJ
good excuse to buy a recip saw it'll be worth the money
theksmith is offline
post #227 of 335 Old 06-26-2008, 12:32 AM Thread Starter
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Got the rest of the welding finished up tonight and painted. Just have to remove that bolt and replace it...then swap in the front LCA's (6 bolts). That'll be the next step (next week unfortunantely) and the final day will be bending the rear UCA brackets open a bit as they are too tight and then installing those 4 arms (8 more bolts + 3 for a bracket).
17 more bolts until I am done
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #228 of 335 Old 06-30-2008, 10:28 AM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Got the front LCA mounts cut off, painted, and then the new CA's all bolted up. I did it with the weight on the axle still so my caster angle should be the exact same as with my short arms on there.
I have pretty bad DW (Prior to LA's) and now with LA's it is still there, but more bearable. When removing my old CA's I noticed a few of the bolts were loose. I think DW's loosened them up
Ordered new TRE's last Friday and should be here Wednesday/Thursday. I am hoping they are what is causing the DW. When Terry was over a couple weeks ago we looked at them and noted some play in them. I think I'll do the OTK swap now as well.
Just have 2 more mounts to cut off in the rear, and bolt up the diff bracket for the new UCA's, remove the a-arm (should be fun since I think they are tapered bolts), and bolt up the 4 arms. I think it'll take a bit longer then the front - although the front only took 2.5 hours to bolt everything up. Going through a ton of sawzall blades on the mounts
post #229 of 335 Old 06-30-2008, 01:46 PM
RyanZJ
RyanZJ's Avatar
Sah-weet. You'll be a pro when it comes time to install mine!
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #230 of 335 Old 07-02-2008, 11:52 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
All done...Just have things to button up like grease the rear joints, check for interference in the front (rear already done), check for vibrations from pinion angle (front should be ok, rear needs to be checked).
Where the A-arm used to be - no more
Oh yeah, in the front & rear I have to weld in the spacers (really kind of optional):
Here is the turn down. I want to move it a bit since it is blowing right on the joint, I'll point it down a bit more.
post #231 of 335 Old 07-03-2008, 12:05 AM
theksmith
2003 WJ
are you running a muffler, or is that turn-down directly after the cat?
post #232 of 335 Old 07-03-2008, 12:18 AM
TJSport01
i havent read the whole thread but it looks great, i dont know if you have already commented about this but your pinion angle looks quite aways off
Build Thread:
2001 Jeep TJ, 1in JKS Body Lift, 35x12.50x15in Goodyear Mtr's and a RE 4.5 SF with AA sye, tom woods custom cv drive shaft, tnt tube fenders w/3in flares and flush mounted led turn signals, 1in mml, cobra cb and firestik, custom rock sliders, herced, trail scars
Looking for 4.88s (R&P) for a d44/d30 PM me
TJSport01 is offline
post #233 of 335 Old 07-03-2008, 12:28 AM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Yes, for now. The UCA/LCA bracket makes it very difficult to fit a muffler in there. I will probably end up running a very small muffler like a cherry bomb...
It is pointed up somewhat. I didn't bother measuring what it was at before () but I don't think it is too far off. I'll find out tomorrow night after I replace the steering components (TRE/DLE) so I can drive faster then 30. Also remember I am a LWB so my pinion angles are a lot more tollerant then they are on a TJ...
post #234 of 335 Old 07-12-2008, 03:24 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Woot, well I have done a few things since I last updated this.
  • I corrected my rear pinion angle to be 6deg up (TC is 6deg down) and no vibrations.
  • I replaced my front passanger ball joints (PITA until I figured out the tricks).
  • Replaced all the TRE's and DLE's and straightened out my steering wheel.
  • Built spring retainers & spring post for the frong drivers spring (only one that droops far enough to warrant one).
  • Built a belly skid - 1/4" is HEAVY
Only "major" thing I have left to do until I am happy with this stage of the build is to get a new exhaust installed. Somewhat difficult because the rear CA's want to crush any exhaust tubing
I'll get pictures of the springs retainer/spring posts & belly skid up as soon as the paint dries on the belly skid & I have it mounted...
post #235 of 335 Old 07-12-2008, 04:08 PM
jeepster93
jeepster93's Avatar
So...
When are you going to wheel this Jeep?
Much more fun to wheel than wrench...
jeepster93 is offline
post #236 of 335 Old 07-12-2008, 05:39 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Going up to Waldorf Ghost Town/Mine tomorrow with the GF and then over Argentine Pass and probably just back over 285 - unless there are some other easy trails on the way back (will look in a bit here)...
Finish everything up and test drove it. Everything looks to be working well
post #237 of 335 Old 07-12-2008, 07:08 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Biggest rock around me...I have 2-4 more inches of down travel I believe:
33's fitting in there perfectly:
Pre-Belly skid - very exposed:
Belly Skid all installed:
Tucked as tight as possible to the TC:
Complicated multi-piece belly skid. I did this so it is lighter if I ever have to take it off on the trail. The "main" piece is the one held on by two bolts in this picture. It has a lip coming out of it which the rear piece braces against and is notched for. Meaning that once the front/main piece is up, the rear one slides up into the notch and one side is held up to make installation easier.
Nice and smooth:
post #238 of 335 Old 07-12-2008, 07:09 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Notched out for my exhaust movement. When I get my muffler installed, I will install the third and final piece behind this. It'll sit ~2" higher then the existing piece.
Picture of the spring retainer:
And of the new centering post. It isn't sqaure, it is cut on a 6deg angle because the spring post on the WJ is at an angle.
post #239 of 335 Old 07-12-2008, 07:27 PM
froggo27
froggo27's Avatar
looks sweet man, did you get a different driveshaft?
Kamil
04 WJ Limited
froggo27 is offline
post #240 of 335 Old 07-12-2008, 07:40 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Lengthened the drive shaft.
Restaurant Thread shunt Colorado Jeep Forum 73 02-12-2010 09:30 PM
Another Black Friday thread... Naturalhoosier Colorado Jeep Forum 12 11-29-2008 12:36 PM
Arlo's Non-Wheeling Pic Thread ArloGuthroJeep Colorado Jeep Forum 109 12-28-2007 02:59 PM
There is a Colorado for sale thread why not have a WTB thread? luniz7 Colorado Jeep Forum 17 12-03-2007 10:40 PM
CB thread... wojtizzlator Colorado Jeep Forum 24 06-16-2007 08:47 PM
