Arlo's WJ Buildup thread - Page 14 - JeepForum.com
post #196 of 335 Old 06-11-2008, 08:38 AM Thread Starter
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
I have an angle finder so I am hoping that I'll be able to measure all the angles and then when setting the new lengths, reset those angles to be the same. It won't be fun but I want a Jeep I am not scared of driving
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #197 of 335 Old 06-11-2008, 11:57 AM
wojtizzlator
1987 XJ Cherokee
yeah cuz then you will have one like mine!
Wojtek
"who needs paved roads when u have a jeep"
87 xj 6" long arm lift, 35's, 4.88 yukon gears, front detroit true trac
colorado jeep club member # 74
wojtizzlator is offline
post #198 of 335 Old 06-11-2008, 10:54 PM
erocksnow
I still have those 6.5" front springs that rock krawler sent me and wouldn't take back if you want them....$80 if you pick them up
-Eric
Colorado Jeep Club Member #67
2007 Wrangler Sahara Unlimited...sold
erocksnow is offline
post #199 of 335 Old 06-12-2008, 09:20 AM Thread Starter
ArloGuthroJeep
Mr. Hyde!
I might take you up on that offer Eric
I just realized that I'll have to modify my TC skid plate...or I could sell it (to someone local) and make my own belly skid at the same time
post #200 of 335 Old 06-16-2008, 08:02 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Got DW pretty bad the other day - between 35-->42 I get a vibration in the steering wheel (that didn't change after I rotated my tires) and was triggering DW. Suspected trackbar bushing. Replaced it this evening and it looked fine. Checked all the TRE's and DLE's using Terry's new fancy method of removing them and they all looked good.
Lastly I checked my ball joints and they are moving up and down maybe 1/16" on the passanger side - I assume that is bad? Looks like I'll replace them while installing LA's.
post #201 of 335 Old 06-16-2008, 08:25 PM
froggo27
froggo27's Avatar
When are you gonna be installing the LAs?
Kamil
04 WJ Limited
froggo27 is offline
post #202 of 335 Old 06-16-2008, 08:25 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Probably partially this week and partially next week. Will be gone this weekend.
post #203 of 335 Old 06-16-2008, 08:26 PM
FPKites
ZJjazzyJim
FPKites's Avatar
My jaw hit the floor (driveway?) when Terry showed me how to get TREs to let loose. I was all ready to shatter my Harbor Freight puller
I'm thinking BJs are fried Ryan. Quite possibly your DW culprit.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #204 of 335 Old 06-16-2008, 10:47 PM
87Xota
1988 XJ Cherokee
We just did Ball joints in Mellow Yellows rig last weekend. I believe they are the same in his rig as yours. They are also the same as D44's use.
I can get those for $26 a side.
But I'm skeptical that the ball joints are your problem.
Check out these links
http://autorepair.about.com/cs/troub...ng/l/bl307.htm
http://www.tomorrowstechnician.com/A...ll_joints.aspx
It basically comes down to, there should not be much lateral movement in any of the different ball joint types, Up and down movement is often normal though.
I've seen new ball joints in some applications have up and down movement.
Beware of the technician that tries to sell you ball joints because of up and down movement, in some applications it is normal and alot of techs don't realize that.
So the question is, is that normal in Jeep ball joints?
Sorry i don't remember, service manual should have specs for it though.
Colorado Jeep Club Member # 200
87Xota is offline
post #205 of 335 Old 06-16-2008, 10:56 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Thanks for the words of caution Terry...I'll investigate some more this week. I have the feeling that it is something blatently wrong, not just a little out of spec/loose based on how reliable it happens. The vibration worries me since that appears to trigger it and rotating tires didn't change that at all. Also got back from Moab just fine w/o any wheel vibrations (just the DS vibration) and then all of a sudden, I had wheel vibrations & DW.
post #206 of 335 Old 06-17-2008, 09:29 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Recieved these:
Which unpackaged look like this:
Very nice kit so far - beefy and well built. All of the nuts are nylon locking nuts and some of the bolts have zerk fittings attached to them to grease the joints - top quality!
Rear bracket frame side for UCA/LCA's:
post #207 of 335 Old 06-17-2008, 09:34 PM
CLNinja
CLNinja's Avatar
very nice Ryan... but those look like WJ long arms... i have a ZJ... send em back for the right ones
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #208 of 335 Old 06-18-2008, 05:43 AM
froggo27
froggo27's Avatar
Chee thank god i don't know where you live which eliminates me as a suspect...just in case they come up missing overnight.
Kamil
04 WJ Limited
froggo27 is offline
post #209 of 335 Old 06-18-2008, 09:13 AM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Yeah uhm, power was out this morning and for some reason, most of the neighborhoods garage doors were open...odd!
post #210 of 335 Old 06-18-2008, 09:51 AM
CLNinja
CLNinja's Avatar
it was kamil... he was searching for your house... good thing he didnt find it
Matt
CLNinja is offline
Restaurant Thread shunt Colorado Jeep Forum 73 02-12-2010 08:30 PM
Another Black Friday thread... Naturalhoosier Colorado Jeep Forum 12 11-29-2008 11:36 AM
Arlo's Non-Wheeling Pic Thread ArloGuthroJeep Colorado Jeep Forum 109 12-28-2007 01:59 PM
There is a Colorado for sale thread why not have a WTB thread? luniz7 Colorado Jeep Forum 17 12-03-2007 09:40 PM
CB thread... wojtizzlator Colorado Jeep Forum 24 06-16-2007 07:47 PM
