Arlo's WJ Buildup thread - Page 13 - JeepForum.com
post #181 of 335 Old 03-25-2008, 10:00 PM
froggo27
froggo27's Avatar
how bout i give you $3.50 each time i fill my tires? i want a CO2 tank too, it's fast!
Kamil
04 WJ Limited
froggo27 is offline
post #182 of 335 Old 03-25-2008, 11:53 PM
newracer
FYI I removed the fitting where you can attach the hose. It looked like it would limit volume to me. It is a back-flow preventer, as long as you don't leave the valve open blowing CO2 you don't need it.
newracer is offline
post #183 of 335 Old 03-26-2008, 07:31 AM Thread Starter
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Cool, thanks for the tip
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #184 of 335 Old 04-13-2008, 11:19 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Well I used that tip and removed that check-valve...I couldn't find a female fitting to fit on that end anyways
Nearly burned down my Jeep welding in there, but I did it...have a mounted CO2 tank. The bin that is normally there (or CD-changer for those fancy WJ's) had broken (too much weight - recovery gear) and so I pulled it out and mounted my CO2 tank. Washers and bolts and spacers and a few tack welds and WALA:
Is slightly angled, 80-85deg or so. I think it'll be fine at that angle not being perfectly up...25ft coil hose easily reaches all the spots as well
post #185 of 335 Old 04-13-2008, 11:36 PM
CLNinja
CLNinja's Avatar
doesnt look right in a WJ... we should see if it looks better in a 93 ZJ
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #186 of 335 Old 04-14-2008, 07:33 AM
dnrisden
Rise of the Silver Slinky
dnrisden's Avatar
Sweet, you love that on the trail or at least at the end of the trail.
Don
03 Rubi w/SC/5.5 LAs/37s/Armor/always growing.
dnrisden is offline
post #187 of 335 Old 04-18-2008, 08:39 AM Thread Starter
ArloGuthroJeep
Mr. Hyde!
My knuckle inserts for my tie rod flip (poor mans high-steer) showed up yesterday...Perhaps Sunday I'll drill, weld, and flip
post #188 of 335 Old 04-18-2008, 08:46 AM
grenMEG
I tried it with out inserts and just tried to drill out a tapered end...It was interesting lil squirly on the highway .
If i would of done it 100 percent (w/inserts) it would of been perfect. You will like it.
Do you have spaced rims? my TRE rubbed the inner wheel, but they were stock Jeep Alloys. just grinded them sucka's
By the way how is your miller working out for you? Right now i am looking at a hobart 187 (220v) MIG, any suggestions input?
grenMEG is offline
post #189 of 335 Old 04-18-2008, 09:16 AM Thread Starter
ArloGuthroJeep
Mr. Hyde!
I imagine my bump steer will increase a bit since my draglink and trackbar will no longer be 100% parallel. Sounds like a good project, raise the trackbar mount
Yeah I have 4" BS (vs 6" stock) so I shouldn't rub at all - am following another WJ guys writeup. One of my friends who also did this swap found that if I order a Tie Rod End for a Right Hand Drive WJ, that I can use that. The original guy who did this had to get a chevy TRE, bend it, and then braced it where he bent it...
Miller is working great...Looks like in 3 weekends I'll head down to pick up some steel and over the next couple weekends, I'll start designing my bumper I am still a welder noob so I have no (worthwhile) input for ya
post #190 of 335 Old 04-18-2008, 09:24 AM
grenMEG
[QUOTE=ArloGuthroJeep;5104915]
[QUOTE]
Interesting. What do you think you are going to do?
Well atleast you didn't give me some BS about welding... honesty!
grenMEG is offline
post #191 of 335 Old 04-18-2008, 09:35 AM Thread Starter
ArloGuthroJeep
Mr. Hyde!
I already ordered the RHD TRE like 6 months ago
post #192 of 335 Old 04-18-2008, 09:46 AM
grenMEG
These things take time arlo, its ok, its ok (pat on the back)
grenMEG is offline
post #193 of 335 Old 06-09-2008, 01:14 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Woot...Ordered Clayton's LA kit for my WJ...$600 off the regular price because of a 25% off gift certificate they hooked up GSW with and I pseudo-won - they just raised their prices because steel went up in price (again) so that saved me $150... Should be here late next week.
I'll be running on 4" of lift until I can swing the cash for another set of springs which will probably happen either next month or as soon as I sell my current lift stuff.
post #194 of 335 Old 06-10-2008, 08:34 PM
froggo27
froggo27's Avatar
I hate you! Don't you want to try those LA on my Jeep first just in case they are defective?
Kamil
04 WJ Limited
froggo27 is offline
post #195 of 335 Old 06-11-2008, 01:55 AM
Colorado 5.9
Colorado 5.9's Avatar
I'm sure you know you'll have to set the pinions all over again if you run the 4" then go higher later on. It's a real pain to do over. If you go a few months it woun't seem that bad but if you get the new springs in a month or so I'd just wait & do the whole thing at once.
I do realize you want to get rid of those great tera arms asap though.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
Restaurant Thread shunt Colorado Jeep Forum 73 02-12-2010 08:30 PM
Another Black Friday thread... Naturalhoosier Colorado Jeep Forum 12 11-29-2008 11:36 AM
Arlo's Non-Wheeling Pic Thread ArloGuthroJeep Colorado Jeep Forum 109 12-28-2007 01:59 PM
There is a Colorado for sale thread why not have a WTB thread? luniz7 Colorado Jeep Forum 17 12-03-2007 09:40 PM
CB thread... wojtizzlator Colorado Jeep Forum 24 06-16-2007 07:47 PM
