Annual DW tech conference - JeepForum.com
post #1 of 21 Old 08-21-2007, 12:57 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Well crap I got DW driving Jim home the other day and I have had it happen a few more times since then. So I took it in for an alignment today and my Toe was off (.07 on the left and .01 on the right)...Realigned to .1 on the L&R. It had a better feel on road now, but still isn't happy with I hit the right pot holes.
Camber is -.89 deg on the left and -.83 on the right.
Caster is 3.7 deg on the left and 3.6 deg on the right.
Camber is supposed to be between -.75 and .5 deg
Caster is supposed to be between 6 & 7.5 deg
My Caster & Camber haven't changed in the last year when I have been driving fine w/o DW so I suspect they are fine to be where they are...Plus changing them is a MAJOR PITA since most of my CA's are siezed up pretty well after this winter.
I can get about 1/4" to 3/8" movement out of my trackbar when I move the wheel back and forth at a stop. I suspect this is my problem but I don't know what to do to solve it, I have a brand new bushing in there and a freaking tight bolt. It is the bushing itself moving, not the sleeve.
I am about to take a shotgun approach in an attempt to make this Ouray trip and replace 4 tie rod ends, ball joints, and wheel bearings.
However at $144/wheel bearing ($300 total)
TRE's (2 x $30 and 2 x $45 = $150 total)
and ball joints (2 x $82 and 2 x $50 = $260 total)
that is $710 total and that is just stupid to throw that much money at something which I am not even sure is wrong (and don't think it is).
Any thoughts?
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #2 of 21 Old 08-21-2007, 01:54 PM
dnrisden
Rise of the Silver Slinky
dnrisden's Avatar
The DW has to be that trackbar. The more trails I run the looser my track bar gets. But mine has to do with the hole wholerin out not the bushing. Is your bushing a two piece with the sleeve in the middle?
dnrisden is offline
post #3 of 21 Old 08-21-2007, 01:55 PM
FPKites
ZJjazzyJim
FPKites's Avatar
I've got some duro trackbar bushings you can have for what I paid for them. I bought them for my rear TB, and may not end up using them. Pretty sure they'll fit yours.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #4 of 21 Old 08-21-2007, 02:12 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Yeah two piece with the sleeve in the middle.
Jim I may take you up on those bushings to see if they help...I fear I'll eat through that bushing just as quickly as I did the last two sets of duro bushings I did
post #5 of 21 Old 08-21-2007, 02:25 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Forgot you were eating trackbar bushings. They're in the garage if you want 'em. I ended up getting bushings and sleeves from Kevin thrown into the box with my steering brace, so didn't have to pay shipping on them. Kevin gets $46 plus $8 for the sleeves, can't see how you could kill the sleeves though. Since I decided not to use them, just hoping to get what I put into them.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #6 of 21 Old 08-21-2007, 03:05 PM
dnrisden
dnrisden's Avatar
If those are urethane bushings you will want to grease them before you put them in. I assembled mine dry like you would with rubber bushings and that was wrong. I am going to drill and tap mine to install a grease zirk this winter.
dnrisden is offline
post #7 of 21 Old 08-21-2007, 03:23 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
They are poly, however the instructions never said anything about greasing them (the JKS ones). The duro bushings Jim has (and I went through) come with grease and I greased mine last time I installed them.
Hey Jim, when are you available to meet up with me? I'll be down off of 104th & I-25 tomorrow night getting my pinion seal fixed, that anywhere near you?
post #8 of 21 Old 08-21-2007, 03:47 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
You looked at the packaging Jim? They should have some in there...I am starting to wonder if they're the same or not. I'll grab my old ones to compare. Perhaps you can toss a pic of yours online and some measurements?
post #9 of 21 Old 08-21-2007, 03:51 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Yup, looked right at the packaging. It was a really purdy transparent ziploc bag
**edit - if it'll make you feel better, I'll see if I can snap a pic of the shtuff for ya
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #10 of 21 Old 08-21-2007, 03:54 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Hmm, mine (from Kolak) came in a plastic sealed package w/name and everything on it. I wonder if Kevin doesn't want people knowing who makes them
post #11 of 21 Old 08-21-2007, 03:59 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Couldn't tell ya
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #12 of 21 Old 08-21-2007, 05:49 PM
Naturalhoosier
Naturalhoosier's Avatar
PICS OR BAN!!!! hahahaha
--Nick
My Ride: 1998 GC Limited
Colorado Jeep Club Member #15
Black Jeep Club Member #1976
Make the world a better place, punch a Boilermaker in the face!!!
Don't blame me...I didn't vote for him.
Naturalhoosier is offline
post #13 of 21 Old 08-21-2007, 06:27 PM
otisdog
2008 WK
I'd say you need to get your caster up into the 5-6* range. Your trackbar needs to be TIGHT.
My most recent case of DW was pretty bad.
Checked trackbar - AOK
Found that steering stabalizer bushing was screwed. Got anew stabalizer - took care of 80% of problem. My upper front control arms were still stock - bushings looked a bit crappy. This gave me a good excuse to order the new JKS uppers i'd been planning on. 99% of problem solved. Gonna get an alingment next. Haven't had one recently.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #14 of 21 Old 08-21-2007, 06:32 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Mmmmmm....shiny
**Edit - dog hair carries an extra charge
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #15 of 21 Old 08-21-2007, 07:18 PM
froggo27
froggo27's Avatar
I have the same problem ryan, I'm still trying to center my axle, the closer i get the better it gets.
Kamil
04 WJ Limited
froggo27 is offline
4th Annual Jim's Birthday Run - June 28th FPKites Colorado Jeep Forum 81 08-03-2009 12:25 AM
6th Annual Truck & Jeep FEST 2009 ... whos going? CLNinja Colorado Jeep Forum 19 07-13-2009 07:48 PM
6th Annual Christmas Caravan for Kids froggo27 Colorado Jeep Forum 38 12-06-2008 11:39 PM
2nd Annual JeepForum BBQ REDLYNER Colorado Jeep Forum 170 08-07-2007 12:28 PM
The 4th annual Christmas Caravan for Kids Colorado 5.9 Colorado Jeep Forum 8 12-04-2006 07:11 AM
