Ac Blows - JeepForum.com
post #1 of 2 Old 07-29-2012, 03:58 PM Thread Starter
bigeb
Xj Ac Blows
My 96 cherokee AC blows (not cold niether). I have dumped a couple 2 or 3 cans of juice in it. Seems to come out as fast as I put it in. Were does all that oil go? Don't see it anywhere. Evaporator? Really!! I am new to this sight but have been researching a little bit. I heard of evap problems with 97-2000. Is the 96 prone to it to? Will that uv dye hurt anything? Maybe I'll luck out and it will be condensor or something.
bigeb is offline
post #2 of 2 Old 07-29-2012, 05:39 PM
streetglideok
2005 KJ Liberty
Too much dye can cause issues, as it is caustic in high amounts. Without knowing what the pressures are, the actual amount of R134A in the system, and the purity of the contents in the system, its hard to know what is going on. I can say this, you can not keep dumping cans into the low side to fix it. Evap core leaks suck to find, and suck even worse to replace. Been there, done that, changed a few of them.
streetglideok is offline
