Anyone from Huntsville, AL??? - Page 151 - JeepForum.com
post #2251 of 3375 Old 11-04-2013, 03:33 PM
aintnofogie
Originally Posted by BigBlue7
Iron Gap, Saturday.
Where's iron gap?
aintnofogie is offline
post #2252 of 3375 Old 11-04-2013, 04:25 PM Thread Starter
BigBlue7
2010 JK Wrangler
Originally Posted by aintnofogie
Where's iron gap?
Tn.
Rock Krawler | TeraFlex | Synergy | Fox | Poison Spyder | Genright | Nemesis |Beer
BigBlue7 is offline
post #2253 of 3375 Old 11-04-2013, 04:59 PM
aintnofogie
lights
Originally Posted by aintnofogie View Post
Where's iron gap?
I just purchased a new bumper for my TJ and am wondering what kind of lights to put on it. Im looking at LED but not sure which are best. Anybody got any advice?
post #2254 of 3375 Old 11-04-2013, 07:11 PM
swill72
Originally Posted by 256ChiliPepper View Post
I love solving death wobble. I cant even count the number of times I have done this.
1) Torque every nut and bolt in your suspension for slack.
2) Make sure all your tires all have the same air pressure.
3) Have some one turn the wheel back and forth between 11 and 1, and look for slack in the tiered ends and ball joints. Also check track bar and control arms (if applicable) Also check your steering box for play at this step. The sector shaft going into the box should not wiggle around at all.
4) Lift the front tires off the ground one side at a time and grab the wheel top and bottom 12 and 6, and rock up and down. If theres play, your unit bearings or hub bearings are bad, or need to be tightened.
5) Get your tires balanced. I recommend the stick on weights that go inside the wheels because they are harder to knock off. If they have to put some ridiculous amount of weight on them, tell them to dismount the tire, spin it 180 degrees, and remount and try again. (places should do this, but they might hate you) If you have bigger then 35s, Balancing beads are an option.
6) Get an alignment. Camber is not adjustable but should be 0. Caster should be between 5-7 degrees. Toe should be about 2-3 degrees toed in (pidgin toed)
7) If you haven't solved it by checking everything, Ill be happy to take a look at it for you.
1. Check
2. Check
3. Lot's of play in the tie rods and drag link.
4. New bearings and ball joints placed in axle
5. Tires have had tread scraped off from PO trying to create better offroad grip. Therefore tires will not balance. I knew this when I got the axles and tires, but figured I would just get new tires later.
6. Need allignment for sure, after ball joints and all installed.
7. So now that I have learned more about it, I figure the out of balance tires starts the wobble, then the loose front end parts gets it into full blown wobble.
my hopefully solution is that I ordered flat top knuckles for the ford D44's today and I will order the high steer arms tomorrow. So I will then convert it to full high steer and replace the rods and drag link. Now I have to decide what ends to use, tie rods or heim joints? Any suggestions? Last but not least I will have to replace the tires, the 35" tires look so small now with the height, so now I am thinking 37" tires Instead........I can go bigger than that obviously, but I only have 15x10 wheels and I do not want to go to big.....since I want to keep it road worthy. But I think these things will fix the wobble........don't you? Oh and of course alignment at the end......
-Scott
1989 YJ- 350/TH350, 4" RC Lift, 1" BL, 35"x12.5" MTR's, 95 Tub Swap, XRC FB w/RC 9500 winch, D44 HD F/Ford 9" R, 4.56 Gears, Lockers, SOA, SYE, Front Tube Fenders
swill72 is offline
post #2255 of 3375 Old 11-04-2013, 07:14 PM
swill72
Originally Posted by jeffyt View Post
Yep, that was the TJ we bought, the PO had swerved to miss a small child at a gas station and crinkled the fender and bent the bumper.
Wow thats cool. Been seeing that jeep out there a few weeks. Hope you enjoy it!!!!!
-Scott
swill72 is offline
post #2256 of 3375 Old 11-04-2013, 09:59 PM
Insane
OK, got a 2013 jku and looking to get a decent bumper for winch. Looking for any feedback or suggestions. I would like to keep price reasonable as some of these bumpers are outrageous. I've seen the bestop narrow stubby for under $300...but not sure on look and quality. Thanks!
Insane is offline
post #2257 of 3375 Old 11-05-2013, 05:16 AM
spbarone
2015 JK Wrangler
I would check Rusty's. I got an awesome bumper from them last week and they are semi-local. Unfortunately you missed their overstock sale.
spbarone is offline
post #2258 of 3375 Old 11-05-2013, 07:51 AM
256ChiliPepper
Originally Posted by swill72 View Post
1. Check
2. Check
I had a good feeling it was worn out parts and out of balance tires.
Tierod end you can source from a parts house of your choice, mind you that you have to have a reamer to be ale to have the wholes in your knuckle tapered. Heims, just get good ones from Ruffstuff or QA1. Don't forget the safety washers too. And have a spare heim or two, just incase you break one.
Id pop the beads of the tires and put some airsoft BBs in them. That should help the balance issue.
You can run the 35s for a while while you look for some good 37s. You could probably find some half tread ones.
98 4cyl TJ on 35s, armored, geared, locked, and ready to wheel
88 MJ 4.0L AW4 4wd. Stock.
256ChiliPepper is offline
post #2259 of 3375 Old 11-05-2013, 01:02 PM
erickpl
erickpl's Avatar
Originally Posted by RammerJammerJP View Post
If Jeff doesn't take em I could use em. My jeep made friends with a tree last time out and I gotta replace the left.
Or if he only needs the right...
Haven't heard anything from him. Just let me know.
As for Stony Lonesome, they have REALLY grown that park since I was last there. Lots of good climbs and descents. Mud can be found if that is your poison (not for me). Not as many rocks, but combine some with gullies and such and it can get interesting. Our group hit a lot of good obstacles during the jamboree this past weekend down in Cullman.
I have our tracks recorded on my GPS so I can take my wife to some of the obstacles at some point. We even managed to go up AND down GutBuster with fairly new wheelers - they were THAT good! Hit up Powderpuff, Three Kings, Switchback, and several other runs on the second day.
A few pics... though none really show the steepness of the climbs. That doesn't even show up in my GoPro videos.
A fellow JF'er...
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #2260 of 3375 Old 11-05-2013, 06:54 PM
Insane
Thanks for input. I'm thinking bout a JCR mid width.
Insane is offline
post #2261 of 3375 Old 11-05-2013, 09:18 PM
broach70
While we are on the subject, probably will be selling my front BTF Bumper and sliders off my CJ here soon. I'm needing a new facelift. Anyone of interest let me know.
broach70 is offline
post #2262 of 3375 Old 11-06-2013, 07:59 AM
RammerJammerJP
I had a JCR rear with tire carrier for my JK. Loved it, great bumper, looking at them for my TJ now.
RammerJammerJP is offline
post #2263 of 3375 Old 11-06-2013, 06:59 PM
swill72
Before I list these anywhere else. I have a set of waggy 44's that I am selling now, since I went with the 9" rear and HD D44 front. Anyone interested?
-Scott
swill72 is offline
post #2264 of 3375 Old 11-06-2013, 07:28 PM
broach70
How much?
broach70 is offline
post #2265 of 3375 Old 11-06-2013, 09:59 PM
Insane
JCR has big sale right now
Insane is offline
Huntsville rapist RAZORBILL General Discussion 42 04-25-2011 12:21 PM
University of Alabama Huntsville erickpl General Discussion 22 03-10-2010 07:07 AM
San Angelo or Huntsville laxwarriors21 General Discussion 6 03-26-2006 04:33 PM
