Anyone from Huntsville, AL??? - Page 107 - JeepForum.com
post #1591 of 3372 Old 03-02-2013, 04:49 PM
lifesaflaw123
Good wheeling. Apparently I slung another wheel weight. Time for another balance visit.
lifesaflaw123 is offline
post #1592 of 3372 Old 03-02-2013, 05:29 PM
256offroad
Ask them to Throw some stick on weights or you can put air soft bbs in it.
98 2 door xj rockrig- KRAWLERS on allied beadlocks, RSOR steering, 3link, built axles
96xj dd- 4"RC, 33s on Moabs, 8.8 4.10s
HERS 98 2 door xj- 3" rustys, 31s on moabs.
256offroad is offline
post #1593 of 3372 Old 03-02-2013, 05:33 PM
BamaJeepman21
Does anyone know someone local that could set up gears? RCOR would be $1,300 which isn't bad, but if I could save some money that's be great.
-Jack
BamaJeepman21 is offline
post #1594 of 3372 Old 03-02-2013, 05:47 PM
lifesaflaw123
Yeah, I may throw some air soft bbs in there so I don't have to worry about it again
post #1595 of 3372 Old 03-02-2013, 06:41 PM
spbarone
2015 JK Wrangler
Good times today on our impromptu wheeling trip. Front lockers are amazing.
spbarone is offline
post #1596 of 3372 Old 03-02-2013, 06:48 PM
highspeed
Where did y'all go?
highspeed is offline
post #1597 of 3372 Old 03-03-2013, 08:08 PM
spbarone
2015 JK Wrangler
Just some random trails around town.
Looks like I'm in the market for a replacement 30 or a set of 44s. Anybody know of anything?
spbarone is offline
post #1598 of 3372 Old 03-03-2013, 08:21 PM
BamaJeepman21
What happened to yours?
I've been looking for a rear 44 for awhile now. No luck.
-Jack
post #1599 of 3372 Old 03-03-2013, 09:50 PM
spbarone
2015 JK Wrangler
I'll post the pic tomorrow but there's about to be a sizable chunk of metal missing from where the carrier seats in the housing.
spbarone is offline
post #1600 of 3372 Old 03-04-2013, 08:15 AM
BamaJeepman21
If you have the cash, I'd get a built HP30 from East Coast Gear Supply. A nicely built one will run about $1,500...
-Jack
post #1601 of 3372 Old 03-04-2013, 11:12 AM
256offroad
Waste of money..... Find a rubi44 for that or a g2 44 for a little bit more.
Ill have a 4.10 hp d30 open with some add ons like currie flex joints installed in the upper control arm bushings, zj tierod, plated diff cover full circle clip 760x spicer joints. Lower control arm skids.
Be a great swap for someone going to a 8.8.
Not planning on pulling it for a couple of months....but I'd sell it for cheaper than a built d30 from ecgs.
post #1602 of 3372 Old 03-04-2013, 11:30 AM
BamaJeepman21
The only difference between a TJ front 44 and a HP30 is the ability to gear deeper and a little bit thicker gears. Otherwise the 44 uses the same tubes, knuckles, unit bearing hubs, ball joints, outer axle shaft stub, u-joint, brakes...
I might be interested in the HP30 you have whenever it comes off.
-Jack
post #1603 of 3372 Old 03-04-2013, 11:52 AM
256offroad
I agree but the shear size of a Dana 44 4.88 gear set vs. a Dana 30 is a big difference. Mainly the pinion. I have stripped 3 sets of Dana 30 gears and haven't on a 44 yet.
Ill keep you in mind
post #1604 of 3372 Old 03-04-2013, 12:11 PM
spbarone
2015 JK Wrangler
I know replacing an axle is the ideal time to do gears but I if I can't find a set of 44s I'll probably just start hunting for a 30 that's set up for 3.73s. Don't really have cash laying around to buy an axle AND regear the rear.
spbarone is offline
post #1605 of 3372 Old 03-04-2013, 12:19 PM
lifesaflaw123
I'd be looking to dump that 35 before anything else.
Huntsville rapist RAZORBILL General Discussion 42 04-25-2011 01:21 PM
University of Alabama Huntsville erickpl General Discussion 22 03-10-2010 08:07 AM
San Angelo or Huntsville laxwarriors21 General Discussion 6 03-26-2006 05:33 PM
