Need a good YJ mechanic in South Florida - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Wheelin' Neighborhood > South East USA > Florida Jeep Forum > Need a good YJ mechanic in South Florida
The ULTIMATE "Selectable" Locker System! BroughRough Country Lift Kits and Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-10-2014, 06:34 AM   #1
elias75
1987 YJ Wrangler
Hello,
I am in desperate need of a good Jeep YJ mechanic. I own a 1987 YJ 4.2 and im having overheating problems.
If anybody can please recommend a good mechanic i would very much appreciated it.
Thank you in advance
elias75 is offline   Reply With Quote
Unread 04-10-2014, 10:57 AM   #2
Cobra21
Give Brandon's a call in Pompano Beach (on Dixie Hwy south of Atlantic Blvd). They did some work on our Jeep and were recommended by others.
As far as overheating, did you change out the thermostat, water pump, replace the coolant?
Check the fan clutch, make sure it's engaging.
Cobra21 is offline   Reply With Quote
Unread 04-11-2014, 05:29 PM   #3
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Try Mean Max, he has a Jeep shop in Stuart.
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade: http://www.jeepforum.com/forum/f12/9...grade-1287758/
5.7YJ is offline   Reply With Quote
Unread 04-16-2014, 08:16 PM   #4
ABNJOE
I own a 1988 YJ 4.2 and had a lot of work done at Brandon's. Straight shooter, very knowledgeable and can fix, fabricate, invent and/ or install anything you want done. Tell him the Sergeant Major sent you.
ABNJOE is offline   Reply With Quote
Unread 05-19-2014, 03:08 PM   #5
goducks3620
Green's garage in Miami. I don't trust anyone else with my TJ, and Junior (owner) is a Jeep nut. They've replaced my rear axle and fixed some cooling issues I was having.
goducks3620 is offline   Reply With Quote
