Steering alignment shop in Columbia area? - JeepForum.com
post #1 of 3 Old 10-27-2011, 02:16 PM Thread Starter
Palmetto
Palmetto's Avatar
1981 CJ7
I have a 2000 XJ with a 3" lift that I think has bad caster due to the lift.
I need the steering aligned from a shop that knows what they are doing.
I called one place that told me I needed to put a new steering
stabilizer on. They also said that bad caster makes the wheels go
only one direction, not either direction when they should be re-centering.
So, just looking for a place that knows my dilemma and can help fix it.
Thx
ΜΟΛΩΝ ΛΑΒΕ!
Do your duty in all things. You cannot do more, you should never wish to do less.
Robert E. Lee
Groups
Originally Posted by DiabloYJ View Post
It's a Jeep thing, I don't even understand it sometimes.
1981 CJ-7, AMC 360 bored .30 over, Edelbrock Intake, Edelbrock Cam, Edelbrock Double Roller Timing Chain, Holly 650 truck avenger carb, Flowcooler water pump. '97 Dodge 4wd Std NV4500. D300 Twin Sticked. Corbeau Seats, Custom Dash with Autometer guages, Electronic Speedo, all stainless hardware, Outlaw II Wheels, BFG AT 33" Tires, Flex-A-Lite Dual Electric Fan, AGR steering box, Borgeson steering shaft, ididit tilt column, Mean Green Starter, Tuffy console, poly gas tank, handmade rear bumper, cheap radio and speakers.
2000 XJ - HO 4.0L, 245/75R16 Goodyear Wrangler Duratracs. PSC gearbox. IRO Double Shear Trackbar. New headliner. IRO Hack & Tap SYE. IRO adjustable UCA & LCA, RE 3.5" lift, Bilstein 5100 shocks, JKS Quick Disconnects. Future mod: OTK steering, lockers, FIPK, rock sliders, JCR Bumpers, rear storage, high pinion rear (3.55), frame reinforcement, hood louvers, rack lighting.
Palmetto is offline
post #2 of 3 Old 10-29-2011, 05:41 PM
Mayfair_Jeeper
Mayfair_Jeeper's Avatar
Do you have adjustable uppers and lowers? To fix the issue your having, you will need those. You can but bolts that will help adjust the caster but they're not very reliable. loosen up while driving over time so you have to keep adjusting them. It is much easier and more affective to use a just adjustable lower control arms
2006 Jeep TJ X Modded with toys
2008 Jeep Liberty Sport Stock
1987 Cherokee 4.0 Renix...Build in Process
Mayfair_Jeeper is offline
post #3 of 3 Old 10-29-2011, 05:42 PM
Mayfair_Jeeper
Also...post up on offroadSC.com. there is a pretty knowledgeable group of guys on there....
Need Jeep Mechanic near Columbia SC Timmy.o.tool South Carolina Jeep Forum 5 06-06-2012 07:51 PM
Trails Near Newberry/ Columbia peytonimor7 South Carolina Jeep Forum 4 07-21-2011 01:12 PM
New to Columbia, SC SniperYJ South Carolina Jeep Forum 14 11-18-2008 06:44 PM
Moving to Columbia, SC ssgchappy South Carolina Jeep Forum 2 10-26-2008 05:59 PM
Any Good Places In Columbia Sc? mudman31890 South Carolina Jeep Forum 2 10-22-2008 10:59 AM
