YJ Build has started!! - JeepForum.com
post #1 of 5 Old 01-29-2013, 08:46 AM Thread Starter
jmews
So I just got back from overseas and planned on doing a 318 swap in my YJ late Feb. Well, once I got home I decided to go ahead and knock it out.
I am swapping motor, trans, transfer case, drive shafts, rear and front ends. I already have the drive train pulled and clearing the tub as we speak to hopefully have it line-x'd this week.
jmews is offline
post #2 of 5 Old 01-29-2013, 03:35 PM
_AdriaN_
Looking good so far, you should have this moved to the builds or YJ section for more views. Are you doing the Line-X yourself or getting it done in a shop? Either way, what's the hit to the wallet?
96 ZJ 4.0
04 TJ 4.0
87 Rx7 TII
_AdriaN_ is offline
post #3 of 5 Old 01-29-2013, 07:31 PM Thread Starter
jmews
I used to work for a line-x shop in town while off rotation overseas. I will be doing all the prep myself then takin the tub up to get line-x'd. It about a grand for too and bottom of the tub, so worth it if you ask me!
jmews is offline
post #4 of 5 Old 01-30-2013, 09:26 AM
_AdriaN_
Yeah, if I had the money to do that I would. No worries about corrosion on the underside and easy clean up of the inside would be great.
96 ZJ 4.0
04 TJ 4.0
87 Rx7 TII
_AdriaN_ is offline
post #5 of 5 Old 01-30-2013, 11:16 PM Thread Starter
jmews
Looks like I have to wait on the line-x. After a good look inside my tranny found out it either needs a complete rebuild or replacement...
jmews is offline
