Uwharrie ok for a DD w/ a BB? - JeepForum.com
post #1 of 9 Old 03-04-2008, 08:33 AM Thread Starter
NCJEEPFAN
2006 WK
Hey fellas, i just got my BB installed and my TJ for next couple of years will be DD. i want to wheel some. now i have been to Uwharrie back in 1995 w/ my Nissan 4wd truck. at that time it did great, we had no issues, and had a ball.
my question is, with the years gone by, can i still take my TJ DD down there, avoid the rocks, go easy on the skinny pedal, not tear anything up and drive it home?
right now from the threads i have read, i think the answer is yes, but i want to be sure. when the weather breaks, i want to load the wife and kids up, pack a lunch adn go for a ride to URE.
i would love to hear from people that have been down there lately w/ a stock or mildly lifted TJ.
thanks guys!
06 WK Laredo
3.7, 4wd......lift and tires coming soon!
NCJEEPFAN is offline
post #2 of 9 Old 03-05-2008, 03:53 AM
DonohueNC
Last time we went we had a guy with us with a 2.5" lift and 31s make it down every trail with us. He took the bypass on Rockt Mtn. but he even made it up Daniel (with some abuse to his skid plates).
If you're going alone (without other jeeps) I would say don't worry too much, but keep to the safe trails.
'98 TJ, 60s, 40s, Comp Cut, Flat Fendered
DonohueNC is offline
post #3 of 9 Old 03-05-2008, 04:50 AM
orangetj05
orangetj05's Avatar
you should have no problem on 98% of the trails. just avoid Kodak rock and you will be fine.
2005 TJ 5.7 HEMI, Caged, Locked, Long armed, Stretched, Air shocked, Cromoed, Running 37 Irocks
orangetj05 is offline
post #4 of 9 Old 03-05-2008, 07:03 AM Thread Starter
NCJEEPFAN
2006 WK
thanks for the replies. can either of you give me a list of trails to avoid and ones that should be ok? i have found a fairly decent trail map.
http://home.windstream.net/ezduzit/uwharrie.gif
06 WK Laredo
post #5 of 9 Old 03-05-2008, 03:50 PM
DonohueNC
Daniel is the only trail marked "Extremely Difficult" on the state maps, it has a loose hill climb on it. Other than that, Kodak is the only other spot to look out for, but that has a bypass that runs right beside it.
post #6 of 9 Old 03-05-2008, 07:30 PM
jeeptillidie
jeeptillidie's Avatar
Every trail is doable in a stock Jeep when dry and probably when wet too.
jeeptillidie is offline
post #7 of 9 Old 03-05-2008, 07:55 PM
hscrugby
Just go with some friends.
1, you never know.
2, it's always more fun.
I'd avoid Daniel, unless someone with you has a winch. Posssible to get yourself in some bad places if you aren't careful.
hscrugby is offline
post #8 of 9 Old 03-06-2008, 11:05 PM
jeepbro's
if its dry you can do anything there, if you want to beat it you could prollly do kodak, i saw a tj w/ stock tires and a bb just romp on it and bounce up one of the easier ines on kodak that was still pretty tough, and daniel if you pick a good line on the first few parts its simple and easily walked up, when its dry that is, did just about everything in my xj on 31" bfg at's but havent been there in rain yet
2002 tj sahara 3" lift 35" km2, AtoZ rockers, 8k warn, 4.56 gears, lock-rites front and rear
jeepbro's is offline
post #9 of 9 Old 03-08-2008, 12:07 PM
RichardD
1987 YJ Wrangler
Tj
We did Uwharrie this past Thanksgiving, the trails are great. Anything there is doable for you as long as it's dry. For Daniel: SKINNY PEDAL!!! ..... by that I mean don't stop and pick a good line of course too. Kodiak has a bypass up the left side. We ran my fiancee's DD, an '02 TJ X with a 2" BB, 1" BL, BFG AT 31 10.50X15's, JKS Quicker Discos, engine/tranny, steering box skidplates, diff guards and came away with no damage.
If you don't want to go alone, which is never a good idea anyhow, go to the Eldorado Outpost in the morning, (many groups start out there) and see if anyone will let you tag along, most folks don't have a problem with this.
Be well,
Richard
'87 YJ Laredo My Daily Driver
'02 TJ X Fiancee's DD, and our Trail Rig
'65 M-416 Trailer
Live each day as if it were your last, 'cause you just never know.....
RichardD is offline
Uwharrie NF 7/2-7/5 bebout North Carolina Jeep Forum 1 06-05-2012 09:49 PM
Uwharrie OCT 3rd-4th cb19950 South East USA 18 10-04-2009 10:30 PM
Uwharrie Oct 17-19 Desertfox1023 North Carolina Jeep Forum 0 10-16-2008 01:42 PM
Another Uwharrie run... abnormal North Carolina Jeep Forum 6 10-13-2008 09:11 PM
UWHARRIE - Oct 26-27 Big-n-Broke-YJ North Carolina Jeep Forum 10 10-30-2007 07:35 AM
