The NC Guys Chat Thread - Page 9 - JeepForum.com
post #121 of 4193 Old 05-26-2013, 08:38 AM
BGClemson
Originally Posted by LifeProof View Post
The 30/35 isn't that bad if you have the right build plan for it. Im going the route of learning how to regear while im in afghan so when I get back I can swap in 4.53's and go up to 33" tires. I'll figure out what to do as far as strengthened shafts, I might just pull stock 27 splines for spares from a JY and wheel easy on the skinny pedal.
Also touching on RC, I have their 2.5" springs and shocks and I wheeled flawlessly at URE when I went there. Doing everything except Daniel in all directions. Never felt like my RC or stock components were putting me in jeopardy or flat lining the jeep. But its all about how you wheel.
Once I went truly wheeling for the first time, I completely threw out all my "upgrade lists" and "perfect rig build plans" because once you put rubber to rocks/dirt/gravel/etc it really changes the difference between needed and wanted.
I appreciate the insight, and also your service
Let me rephrase on the rc kit. The springs/shocks could be great for all I know. I just don't like that transfer case drop, but I am getting ready to take care of that next!
As far as build plans are concerned, I know nothing is ever etched in stone. The ideas that I have for the heep change daily. It will be good for me to get out and beat on this thing and go from there
BGClemson is offline
post #122 of 4193 Old 05-26-2013, 08:39 AM
tyvanwie
My plans have changed at least ten times in the past few months.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #123 of 4193 Old 05-26-2013, 09:23 AM
Jankoid
If you guys want to do a URE trip, I'll show up, but that place just doesn't do it for me. I'm planning on heading to Gulches once my TJ is buttoned up, which should happen here in the next month or so.
Oh, and RC 2.5" coils are pretty much the best coil on the market for running less than 3" suspension lift, just sayin.
Jankoid is offline
post #124 of 4193 Old 05-26-2013, 09:25 AM Thread Starter
sjones26573
Following Seth and following me require different levels of confidence.
This couldn't be truer.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #125 of 4193 Old 05-26-2013, 09:33 AM Thread Starter
sjones26573
I'm not sure how soon I'll be ready to go anywhere, as working on the rig yesterday uncovered several issues I need to fix. I need f&r trackbars, stretch tank or cell (yes Jake you had a nice idea but I don't believe it will help the track bar without triangulating the rear), a new top foremost, some steering stuff, and at least some sliders (which means I'll need to at least have front fenders for alignment on hand.) Also would like an engine skid and a few other things.
Jeep-Owner.com
post #126 of 4193 Old 05-26-2013, 09:41 AM
Jankoid
So go ahead and triangulate it. It's not hard. All you need are brackets for the uppers, some tube inserts, and some tubing. You can use the JJs from your Rokmen arms. I could even show you how to stretch 3-4" with those RC lowers I gave you. Hardest part would be the coils, but with such a small stretch you wouldn't have to notch the frame like I did.
Jankoid is offline
post #127 of 4193 Old 05-26-2013, 09:44 AM Thread Starter
sjones26573
I'm not going to have the downtime this summer to do that I believe, plus I'll need the stretch armor, which is even more $$
Jeep-Owner.com
post #128 of 4193 Old 05-26-2013, 09:45 AM
tyvanwie
My top isn't I the best shape but if you need it I can sell you it for cheap.
tyvanwie is offline
post #129 of 4193 Old 05-26-2013, 09:47 AM Thread Starter
sjones26573
Wasn't your top spice?
Jeep-Owner.com
post #130 of 4193 Old 05-26-2013, 09:47 AM
tyvanwie
Yeah. I just didn't know if you wanted a quick replacement.
tyvanwie is offline
post #131 of 4193 Old 05-26-2013, 09:47 AM
Jankoid
You don't have to stretch it to triangulate it. This would be a lot easier if you stopped caring so much about looks.
Jankoid is offline
post #132 of 4193 Old 05-26-2013, 10:12 AM Thread Starter
sjones26573
That's never gonna happen. But looks arent my primary concerns with this stuff. More money and time than looks
Jeep-Owner.com
post #133 of 4193 Old 05-26-2013, 10:14 AM Thread Starter
sjones26573
I won't need one until mid August.
Jeep-Owner.com
post #134 of 4193 Old 05-26-2013, 10:25 AM
tyvanwie
Alright
tyvanwie is offline
post #135 of 4193 Old 05-26-2013, 10:50 AM
jeepbro's
I agree with that . The first time I ever wheeled my TJ anywhere other than sand by the beach was at URE, it was on 33's 2" lift and stock open 3.73 gears and I did almost every trail there including Daniel and Dickey Bell. After adding more mods to my jeep its become even easier so its almost boring running some of the trails, just getting covered in dust going up and down the berms forever and finally getting to one or two obstacles that dont even require a spot. I would like to try somewhere like gulches too, or the flats when they have an open invite that place looks pretty fun!
2002 tj sahara 3" lift 35" km2, AtoZ rockers, 8k warn, 4.56 gears, lock-rites front and rear
jeepbro's is offline
badasses , nc guys , tyvanwie is a derp , tyvanwie is a sellout , who is ron?
