The NC Guys Chat Thread - Page 52 - JeepForum.com
post #766 of 4193 Old 06-29-2013, 06:03 PM
Jankoid
I could lock up my 35s with my old Advance Auto pads and OEM rotors, still the same with Black Magics and Centric rotors. I don't see how that made my stopping distance any less. If it wasnt for the fact that they were free because I won TJotM, they wouldnt be anywhere near my Jeep.
Jankoid is offline
post #767 of 4193 Old 06-29-2013, 06:08 PM
jeepbro's
You get free parts for winning TJOM??? Hell I need to start entering! haha
But I guess maybe I'll just swap in some all new auto zone pads and rotors and rear shoes. Maybe just some all new parts will help, my pads are about 5+ years old so it may do it for me. If it still sucks maybe I'll try black magic pads in 5 more years haha
2002 tj sahara 3" lift 35" km2, AtoZ rockers, 8k warn, 4.56 gears, lock-rites front and rear
jeepbro's is offline
post #768 of 4193 Old 06-29-2013, 06:10 PM
Jankoid
You did back in 2012, now all you get is $100 gift certificate to MetalCloak.
Jankoid is offline
post #769 of 4193 Old 06-29-2013, 06:20 PM
jeepbro's
Well damn, I should have at least tried. Oh well
post #770 of 4193 Old 06-29-2013, 06:54 PM
BGClemson
I could lock my old ones up as well too, I just has no idea which direction I was going with the steering wheel straight. Maybe my originals were trashed, not trying to start anything. I guess compared to what I had anything would of been better. I can't imagine how bad the original brakes I had would be with 35's. I probably would of rear ended someone
BGClemson is offline
post #771 of 4193 Old 06-29-2013, 08:00 PM
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
after laughing at that for like 2 solid minutes I realized that I should probably replace my pads and rotors. I always have that problem going from 60-0. I can stop before the red light, I just might not be in the same lane.
SEMPER FI
LifeProof is offline
post #772 of 4193 Old 06-30-2013, 08:39 AM
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
so I erased the codes last night and took it out for a spin this morning, still the same codes.
I checked and found there is a 10 amp fuse for the O2 sensors and a big black fuse thing for them also. both look good.
Here's more info I found.
This code refers to the front oxygen sensor on Bank 1. The heated circuit in the oxygen sensor decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0135
A code P0135 may mean that one or more of the following has happened:
•O2 Heater element resistance is high
•Internal short or open in the heater element
•O2 heater circuit wiring high resistance
•open or short to ground in the wiring harness
Possible Solutions
•Replace oxygen sensor (cannot repair open or short that occurs internally to sensor) well since I already replaced them I will try to tackle the next
•Repair short or open or high resistance in wiring harness or harness connectors
SEMPER FI
post #773 of 4193 Old 06-30-2013, 10:19 AM
Jankoid
Headed to URE in about am hour to test my new rear locker. Gonna be muddy!
Jankoid is offline
post #774 of 4193 Old 06-30-2013, 10:20 AM Thread Starter
sjones26573
How long you gonna be there?
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #775 of 4193 Old 06-30-2013, 11:00 AM
Jankoid
No more than a few hours probably.
Jankoid is offline
post #776 of 4193 Old 06-30-2013, 11:04 AM Thread Starter
sjones26573
Ok. Just gonna finish my skid.
Jeep-Owner.com
post #777 of 4193 Old 06-30-2013, 12:40 PM
jeepinjeepin
Possible Solutions
What vehicle are you working on? My 2004 WJ burns a CEL almost all winter. I think there is a ECM reflash to lengthen the timer.
jeepinjeepin is offline
post #778 of 4193 Old 06-30-2013, 12:45 PM
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
2002 jeep wrangler x 4.0 L 6 cyl.
SEMPER FI
post #779 of 4193 Old 06-30-2013, 01:03 PM
jeepinjeepin
Factory exhaust? I found on another forum that a relay sends power to the O2 heaters. Relay 34? Under the hood. Swap it with something nonessential that you would notice, AC compressor, heater motor, etc.
post #780 of 4193 Old 06-30-2013, 01:13 PM
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
Everything is factory except the muffler, but I did replace it with one, I think it's a Thrush muffler.
I'll go check relay 34 though, I don't have an ac but I'll see what I can do.
I appreciate all the help
SEMPER FI
badasses , nc guys , tyvanwie is a derp , tyvanwie is a sellout , who is ron?
