Got Some Trouble 4x4 not working!!! - JeepForum.com
post #1 of 9 Old 01-21-2013, 12:56 PM Thread Starter
RedLongArm96
hey guys im new to the fourm im 16 years old and just got my first jeep grand cherokee 96 model! it has a 11" lift on it 6 susp. and 5" body lift the previous owner had a Ford rear end put in it and said the the gears wouldnt line up and that was why 4x4 wont work i dont know if thats the real reason but can someone please give me some advice on how to go about fixing this!
also im looking to be apart of a group to go about some trails and find some mud and fun!
Thanks,
Brian
RedLongArm96 is offline
post #2 of 9 Old 01-21-2013, 01:31 PM
wnckrawler
5" body lift? -_-
So are you running off the front diff only? Some more info would be great... Gears not lining up doesn't really make a lot of sense.
wnckrawler is offline
post #3 of 9 Old 01-22-2013, 09:40 PM
Steel4Pens
Pictures might would help too.
And I see your from Granite Falls....Tell Eric Church hey
Freeman Park @ Carolina Beach Pass Holder
Red Jeep Club #656
Steel4Pens is offline
post #4 of 9 Old 01-24-2013, 06:28 AM
TimMcc
Not sure, if serious.
__________________________
01 Laredo 4.0, 4" RC X Lift, Aussie, JK Rubicons, 32's
TimMcc is offline
post #5 of 9 Old 01-24-2013, 06:41 AM
1FuddyMucker
1983 CJ7
Thanks,
Brian
The po may have put the kanudeler valve to close to the muffler bearings
You have jeep gear lube in a ford rear end, might as well flush the turn signal fluid while your in there...It's hard to say.
Don't breed em' if you can't feed em'.
1FuddyMucker is offline
post #6 of 9 Old 01-24-2013, 06:47 AM
threeb
You guys are brutal. Take the body lift off and reset the radiator. It should work fine after that. That is way to much body roll for the gears to work.
LJ Owners Group member #431.
threeb is offline
post #7 of 9 Old 01-24-2013, 06:56 AM
1FuddyMucker
1983 CJ7
You may have to swap the lift around, it should be 5 in suspension & 6 in body lift. That should do it.
Did you ask the po for the box of leftover bolts???
post #8 of 9 Old 01-30-2013, 07:30 PM
toxic-xj
When your that high up you need to take out the shocks and weld re-bar in there its the only way to line up the gears.. You could remove the body lift and replace it with 2x4s that might also help Unless your serious/ then more info and photos are required.
toxic-xj is offline
post #9 of 9 Old 02-01-2013, 07:59 AM
BLarkin
I'm right below you in Hickory, I might be able to take a look. I'd sure love to see the body lift though, I might want to do mine after that...
BLarkin is offline
