2nd Annual Spring Uwharrie OHV Jamboree - Page 6 - JeepForum.com
post #76 of 457 Old 03-11-2013, 01:52 PM Thread Starter
sjones26573
Originally Posted by tyvanwie View Post
I AIN'T SKEERED
Sent from my iForum using JeepPhone
One of the more recent times I was there, I had to winch an ATV back up the hill that rolled off one of the ledges.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #77 of 457 Old 03-11-2013, 01:57 PM
JCJeep97
Tyvanwie, just ask Seth if he'll help install that 8.8, I hear he's pretty good at it by now
My Build: http://www.jeepforum.com/forum/f22/back-black-2000-tj-build-1237980/
JCJeep97 is offline
post #78 of 457 Old 03-11-2013, 01:58 PM Thread Starter
sjones26573
F*** that. I hear my Jeep is back in the shop getting the ebrake fixed that they said they fixed last time.
Jeep-Owner.com
post #79 of 457 Old 03-11-2013, 02:12 PM
tyvanwie
tyvanwie is offline
post #80 of 457 Old 03-11-2013, 02:19 PM
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
I've never looked at the G2s before. I just figured they'd be way more expensive.
Suspension Lift: 2.5"- 3.5"
Shaft Options: Superior C-Clip Elim Kit (+$700.00)
ADD DIFF COVER: SOLID COVER (+$75.00)
Driveshaft Style : CV-SYE
ADD LOCKER: Full Detroit- 187C-145A (+$640.00)
Reman Unit with New Gears: F8.8- 4.88 (+$535.00)
FINISH: Flat Black
Select TJ Bracket Kit: ECGS TJ Brackets
$2,650
_________________
TJ D44 Rear Axle Assembly 5.38 ratio; With Detroit Locker
Dana 44 TJ Rear Axle Assembly
 5.38 gear ratio
 Detroit Locker
 G2 30 spline axle shafts
 1310 Series U-Bolt Yoke
$2,353
cut and paste from 4wheelparts
SEMPER FI
LifeProof is offline
post #81 of 457 Old 03-11-2013, 02:24 PM
Jankoid
That is assuming though that you are going straight to a built axle. He can get an 8.8 with factory 3.73s and no locker for much cheaper than that. Might be cheaper to find a stock tj44 though.
Jankoid is offline
post #82 of 457 Old 03-11-2013, 02:29 PM
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
right, but he said niether his dad or himself can weld and wanted a straight nolt in axle
SEMPER FI
post #83 of 457 Old 03-11-2013, 02:31 PM Thread Starter
sjones26573
There's several of us that could build it at a cheaper cost. I'm not volunteering, thanks to school.
Jeep-Owner.com
post #84 of 457 Old 03-11-2013, 02:31 PM
JCJeep97
I found a 44 for $425 at a JY back home while I was looking for my HP30. That had gears and all. I felt like that was decent for a 44.
JCJeep97 is offline
post #85 of 457 Old 03-11-2013, 02:32 PM
Jankoid
Right, but the prices you listed are for axles with gears, chromos, and lockers. He never anything about those. You can order an 8.8 from ecgs with factory 3.73s, shafts, and lsd with a tj axle bracket kit for significantly less than what you quoted.
Jankoid is offline
post #86 of 457 Old 03-11-2013, 02:34 PM
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
didnt think of it that way. so basically all your paying for is the axle with the kit mounted. he would still be able to do his own build on it. this is why i post here. sometimes you cant figure everything out on your own. i appreciate that
SEMPER FI
post #87 of 457 Old 03-11-2013, 04:19 PM
ITSKOOL
i might come watch some jeeps go up daniel. i dont really want to try it with my stock jeep. ive driven up to the point where things get difficult, but never really was interested in attempting it.
ITSKOOL is offline
post #88 of 457 Old 03-11-2013, 04:22 PM
JCJeep97
You could make it with the right lines and a good spotter probably. Worst case you can ride with one of us
JCJeep97 is offline
post #89 of 457 Old 03-11-2013, 04:38 PM
mjWJ12
I'm hoping to see what my wj can do. 3+" lift with 32"s . I love it
Sent from my WJ
(04 WJ Laredo)3" IRO +3/4" front spacers; Custom rear bumper +d-rings; universal front tow hook; plasti-dipped 16" silverblades; premium sliders; custom hi-lift mount; 265/75/16 Cooper Discoverer ATP.
mjWJ12 is offline
post #90 of 457 Old 03-11-2013, 04:41 PM Thread Starter
sjones26573
Everyone should list when they plan to be there and we can decide when to meet up. I should be there Friday morning around 9.
Jeep-Owner.com
