New to Tennessee - Page 4 - JeepForum.com
post #46 of 54 Old 03-15-2013, 06:40 AM
pmcjeep
Sounds good im normally home by 4 during the week. Just give me a call. I have that steering stabilizer for you also.
01 tj 4.0,bds springs,ROKMEN arms, ecgs 8.8 and hp30 both locked with 4.88s,35in STTs,Smittybilt bumpers,8k winch,hylined MCE flatties,TKHfab rocksliders,and lots more to come!
pmcjeep is offline
post #47 of 54 Old 03-15-2013, 10:03 PM Thread Starter
NYTrailrider
1988 MJ Comanche
Mj
Really eyeing that 4.5 Zone kit.
88 Comanche AX15/NP231 swap. Zone 4.5" lift Future-Dana 44s, lockers, 36" tires, 4BT swap
NYTrailrider is offline
post #48 of 54 Old 03-23-2013, 10:26 PM Thread Starter
NYTrailrider
1988 MJ Comanche
So I bought the Zone 4.5 kit, I have it all laid out in my basement for paint. i am putting Krylon's Pumpkin Orange in the shocks, steering stabilizer, lower (BEEF) control arms, shackles coil springs, trans case lowering blocks and sway bar links. I am going to order the orange braided brake lines from Quadratec to match the paint. When I take the zxles off, i am going to paint them and other components with black Rustoleum appliance Enamel. As soon as I can find a set of 33's or 35's I will start the install. Until then, I will be spraying PB Blaster on all the bolts that need to come off for the install. I think with some help I can install this kit. I spent a couple hundred on tools from taxes, so I am set there until I need something like a specialty tool.
post #49 of 54 Old 03-25-2013, 12:39 PM Thread Starter
NYTrailrider
1988 MJ Comanche
Kit is painted up and I am going to get some 35's in a little while. pmcjeep, wanna help wrench? When is good for you?
post #50 of 54 Old 03-25-2013, 06:35 PM
pmcjeep
Yep i should be able to help out as long as im off work. Are you going to get new rims also?
pmcjeep is offline
post #51 of 54 Old 03-25-2013, 06:56 PM Thread Starter
NYTrailrider
1988 MJ Comanche
Mj
I wasn't planning on it, only because if these will work, I will run them. But if the backspacing is off, I may need too. I was thinking about mounting one tire and using that for fitment and checking the backspacing. We shall see I guess. I wouldn't mind a nice set of aluminum rims from a Cherokee or something, just not sure what exactly will fit. Most Jeep rims should, but I think there are one or 2 models that don't. Also, I have discovered in looking around there are a ton of pair and trios of tires and rims, few sets lol/
Also, were you in Athens the other day? I think I saw you, and I was like, damn that's a nice Jeep and then realized it was you
post #52 of 54 Old 03-25-2013, 07:16 PM
pmcjeep
I would say if you run them on a stock set of rims you may need a set of spacers or adapters to get the bs you need.
I think i rode up that way cant remember what day tho. Lol
pmcjeep is offline
post #53 of 54 Old 04-09-2013, 07:17 AM Thread Starter
NYTrailrider
1988 MJ Comanche
All right, lift is in, all I really need to do is bleed the brakes and check the alignment, and It should be good to go. pmcjeep told me how to make some trick sway bar disconnects, I got 2 non threaded hitch pins (probably not the right name) and drilled out the bolt holes on the axle to 5/8ths, they slid right in, and I use the flip style pins to hold it in place. I shall post a pic.
Yes, I know the bolt is missing form the stbilizer, I am heading to lowes after breakfast to get the right bolt. That ride will be my test run.
post #54 of 54 Old 04-09-2013, 10:00 AM Thread Starter
NYTrailrider
1988 MJ Comanche
Runs just as ****ty as it always has! I am satisfied for the moment
