Good Jeep Mechanic or Shop in Nashville, TN - JeepForum.com
post #1 of 9 Old 12-17-2009, 10:28 AM Thread Starter
JohnTN
Greetings all,
Could anyone reccomend a good Jeep mechanic or even dealer service department in the Nashville, TN area?
I have a case of the angry sparrows and I just don't really have the time and place to tackle it myself right now. I pulled the front driveshaft and the noise went away, so I'm thinking the CV joint is the culprit.
I had a local driveshaft shop take the joint and shaft apart, clean and repair if necessary. They said it was fine, couldn't see a problem. When I attempted to re-install the shaft, I attached it at the transfer case first, but then I couldn't get the shaft to compress enough to get it in to the front yoke.
I don't object to paying to get this fixed, but I'd like to know that whoever I take it to knows what they are doing when it comes to Jeep driveline repair.
Any suggestions would be greatly appreciated.
Thanks!
JohnTN is offline
post #2 of 9 Old 12-17-2009, 11:13 AM
BlaketheSnake
BlaketheSnake's Avatar
Try these guys,
Tennessee Off Road, LLC
4755 Lebanon Rd
Lebanon, Tn 37087
Lebanon: 615.443.7126
Nashville: 615.248.8638
Out of State: 866.248.8638
I've heard a few good things about these guys.
Thanks,
Blake
Tread lightly or we all will be tree hugging hikers!
BlaketheSnake is offline
post #3 of 9 Old 12-17-2009, 11:20 AM Thread Starter
JohnTN
Blake - I've seen their shop but hadn't heard comments one way or the other, so thanks for the update!
JohnTN is offline
post #4 of 9 Old 03-28-2016, 10:58 AM
gadgetjimbo
Who's best Jeep mechanic in Nashville/Brentwood/Franklin? Need suggestions. Thank you!
gadgetjimbo is offline
post #5 of 9 Old 03-28-2016, 02:55 PM
TheBoogieman
JEEPS ROCK!
TheBoogieman's Avatar
Moved to GD.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #6 of 9 Old 03-28-2016, 02:58 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Moved to the Tennessee forum, non-tech.
Jerry Bransford is offline
post #7 of 9 Old 05-20-2016, 09:10 AM
xprezoh
TN Offroad is the best place to get jeep work done or anything done in TN
xprezoh is offline
post #8 of 9 Old 05-23-2016, 11:30 AM
SmashDN
Have heard the same. Guy at work had some axles in there to get re-worked and his only complaint was he was slow to get them done. Took better than two months as I recall to get what he wanted done to them.
SmashDN is offline
post #9 of 9 Old 06-19-2016, 06:21 AM
J3PH3RY_J33P
2011 JK Wrangler
It is in Murfreesboro ( which, given another year or two will be a true suburb of Nashville)but the most dependable that I have found for heavier weld work on my Jeeps that I cannot do myself - is Essentially Off Road . Their facebook page that links from the website will get the quickest response after a phone call. Dependable and more time conscious than what I have heard other local* places can be.
<* I also had a friend that dropped a Jeep off at TOR and it took months.>
'11JKUr 5.13s|OX|3"SynergyMfg|5160's|SynergyLinks|37"KO2s| ArtecTrussed|ExpOne
J3PH3RY_J33P is offline
Can anyone recommend a good Jeep mechanic/shop in Boston area mscmsc JK Wrangler Technical Forum 5 03-11-2014 01:14 PM
Need a good mechanic, a JEEP mechanic bamaboy YJ Wrangler Technical Forum 6 02-14-2011 09:20 AM
Can someone recommend a good Jeep mechanic/shop in Houston, TX Rabb Wrangler General Discussion 2 09-25-2008 03:54 PM
Good Jeep mechanic/transmision shop in San Bernadino/Loma Linda CA area? dasgreif YJ Wrangler Technical Forum 1 02-16-2006 11:23 PM
Looking for honest, good jeep mechanic Stormtrooper TJ Wrangler Technical Forum 7 01-28-2004 10:05 AM
