1994 built Toyota Supra for sale..wanting jeep project - JeepForum.com
post #1 of 3 Old 05-23-2013, 08:31 AM Thread Starter
93civEJ1
What is your First & Last name? Ronnie Long
What is your phone number?
What is your City? : Knoxville
What is your State? : TN
Asking 30,000.
No low ballers...only serious inquiries
This isnt a have to sell...just a change of interests
starting to want a jeep project...so I would maybe consider a jeep trade (stock) and money.....
Ad Description:
I bought this car from Nashville a few years back with around 127k on the odo. It was a BPU+ car on stock wheels with a E-TTC setup and automatic trans.
I daily drove this car for a while just to and from work (around 50 miles a day highway)
Car now has around 160k on chassis, and less than 2,000 miles on the new motor / trans. All vin numbers match except the hood. When i first got the car way back in the day, I traded a guy for a carbon hood for my stock one and never saw the stock one again. I found another stock one and had it freshly painted and put it back on my car.
Eventually I got another vehicle and put this one away to be my project / weekend car.
In time I tore it apart and built the motor, singled it and put in a manual trans swap.
I built the car and now it just sits in the garage protected from the weather and elements. Low boost and still barely over break in on the motor. I havent had it on the dyno nor raced it. It needs to be tuned to make the full potential power. This was my plans and to switch to E-85. I feel the motor is built to handle an easy 1000hp comfortably. Just interests is changing as I get older and I feel I would rather invest in some land instead of having a car that sits and never gets driven.
Here is a run down of the parts list: There are probably more that was just forgotten to be added.
Exterior:
RMM Wing with carbon fiber center
Euro front glass head light housing
Mcculloch 6k HID
98 turn signals
98 tail lights
Wings West Front Lip
Suspension and Rolling:
Eibach Springs
KYB AGX 4 way
18x8.5 front 18x10.5 rear SSR SP-1 Professor wheels
315/30/18 Hankook RS2 Rears
Front Slotted Rotors
Steel braided brake lines
Interior:
98 seats front and rear
TRD shift knob
6spd shift console and boot
Toyota 6spd Brake pedal
Toyota 6spd Clutch pedal
Electronics:
Greddy Boost gauge
Greddy EGT
AEM UEGO wideband gauge
MAP ECU
Greddy BCC
Apexi AVC-R digital boost controller
HKS turbo timer
Pioneer Premier CD player (no speakers right now because I took all the stereo out..but do have speaker mounts for 6.5's)
Engine:
750 CC Fuel Injector Clinic kit (fuel rail, injectors, etc)
Earls inline fuel filter and fittings
Additional -6 Aeroquip socketless feed line
Dual Walbro fuel pumps
Aeromotovie FPR
Greddy 3 Row Intercooler
Valve covers powdercoated grey
-10AN valve cover exhaust fittings
Steel braided hoses to catch can
Power House Racing ITS 67 turbo kit
HKS turbo manifold
stainless steel braided oil feed
HKS 60mm Racing wastegate and dump tube
Stainless steel braidedwastegate vacuum hose
PHR downpipe
HKS Carbon Ti exhaust
Tial style BOV
EGR blockoff plates
Head sent to Dover cylinder head for inspection and cleaning
Viton Valve Stem seals
Ferrea Comp 6000 valves
HKS 272 cams
Polished Adjustable Cam gears
BC Springs and Retainers
CP .20 over pistons
BC Pro Series Rods
Arp head studs / mains/ and hardware
ACL Race bearings
ACL thrust washers
New oil pump
New Water pump
New thermostat
New front main and rear seal
New gaskets and seals
New timing belt tensioner
Gates Racing Timing Belt
Polished Alternator, Water Pump and AC pulleys
PWR Radiator
Twin FAL electric fans
Boost Logic Crank pulley
R154 Manual 5Spd transmission / swap
1jz bell housing
New 1jz Flywheel
ARP flywheel bolts
new toyota synchros and bearings
Marlin crawler thrust washer
Marlin crawler bearing plate retainer
Marlin crawler billet shift fork
Marlin crawler speed sensor conversion
Competition Clutch Stage 4 6-puck sprung clutch
Toyota 6spd Clutch Master Cylinder
Driftmotion Stainless steel braided clutch hose
Driveshaft shop 1pc aluminum driveshaft
Redline fluids used
Other mods:
TRAC control removed
TRAC butterfly deleted
Cruise control removed
AC works
66333_531648896338_214700136_31676576_5236396_n.jpg   IMG_0320.JPG   35297_528166170748_214700136_31573804_7581945_n.jpg   img00162.jpg
93civEJ1 is offline
post #2 of 3 Old 06-12-2013, 10:41 AM
jeepsterdan83
I saw this car yesterday, very nice. Glws and your future Jeep project.
jeepsterdan83 is offline
post #3 of 3 Old 09-29-2013, 03:13 AM
xxkilljoyxx
Is the vehicle still for sale? If so call me at 661-444-1810 please.
My name is Sunni Singh
xxkilljoyxx is offline
