Two tracks or fire roads - SE Ohio - JeepForum.com
post #1 of 5 Old 06-11-2010, 10:42 AM Thread Starter
Paul04TJ
We're heading to the Hocking Hills Area.
Are there any scenic areas to drop the top and have a nice afternoon drive?
2013 2 door bright white Moab
White Jeep Club Member # 269
Sold!
Red Jeep Club Member # 269
'04 Wrangler 'X'
Paul04TJ is offline
post #2 of 5 Old 06-12-2010, 11:57 AM
tdavidk76
There are all kinds of nice roads to drive in that area with the top off! I am originally from that area. There may not be any wheeling easy to find but lots or scenic rds to travel. Many in the Hocking hills region you are headed to and more farther south off of 33. You should head to the Wayne National Forest Headquarters which is just past Nelsonville on 33. You should be able to get a map of the forest there and head out on some of the back rds (alot of 'em will be gravel so u will get dusty). I am guessing you are heading to Old Man's Cave. You can probably get maps there also. If you aren't going to Old Man's Cave you should try and fit it in. It is beautiful. Hope this helps. Hope I got to you before you already left. lol
Ted - 2001 XJ Sport, Patriot Blue. HD rear springs (1"-1.5" lift). Rusty's-1.5" shackles, 3" coils, LCA (custom for factory wheels). 31 10.50 15
tdavidk76 is offline
post #3 of 5 Old 06-12-2010, 12:16 PM
tdavidk76
Here is a link to a pdf map I found online. Most of the rds you see surrounding 33 will give you a nice scenic drive. Roads in particular- StRt 56. You could take it all the way from Hocking Hills to Athens. The loop of StRt 685 and 13 would be a nice quick trip. I lived off of 13. If you take some of the side rds south off of 685 or west off of 13 you will be smack in the middle of Wayne NF. Also hard to get lost on those rds. All come out to either 33,13, 685, or a smaller rd that will get you to one of those main rds. Ask around at shops/stores/gas stations while your down there. Most people are very nice and will point you in the right direction even if you are from Michigan (lots of rabid OSU fans down there. Go Bucks!!!)
http://fs.usda.gov/Internet/FSE_DOCU...rdb5108535.pdf
post #4 of 5 Old 06-14-2010, 12:58 PM Thread Starter
Paul04TJ
Thanks for the tips, we aren't going until mid July. Apparently we are signed up for Zip lining as well. Should be interesting with my wife being afraid of heights.
We got the whole Bucks thing covered. My wifes family is originally from Clevelend............. Luckily they got out!
Sold!
'04 Wrangler 'X'
Paul04TJ is offline
post #5 of 5 Old 06-14-2010, 08:21 PM
ruff88xj
if you wanted some light wheeling, down around tarhollow/vinton county area, there's a few unmaintained township roads we run about once a month. They have little bit of everything. its nothing hardcore but with some lift and tires you could do just about anything. We had stock ZJ with us last time. we spotted him through some stuff but he had a good time. You should be able to get a rd map from the Vinton County Clerks office from what i was told
92 YJ
83 & 85 CJ7
Build Thread:
ruff88xj is offline
unmaintained roads in ohio 8balls12 Ohio Jeep Forum 7 09-20-2009 12:03 AM
Anza Borrego GPS Tracks dirtman13 California Jeep Forum 6 10-31-2008 08:50 PM
Ocean County NJ Fire Roads tj7695 North East USA 2 01-17-2008 11:37 AM
Fire roads PA St.Patrick North East USA 1 01-11-2008 06:38 AM
4x4 off roads in Iceland thrandur Mexico/International 6 06-06-2004 03:47 PM
