What did you do to your xj/mj/tj/zj/wj/wk/lj/jk thread - Page 55 - JeepForum.com
 3Likes
post #811 of 8431 Old 05-03-2012, 07:05 PM
Jason
Originally Posted by cheap5.0 View Post
Hey jason, on yjs in order to change the rear pinion angle you can either cut/weld your spring brackets or use shims.
from the reading I've been doing I figured out the lca's are what control pinion angle right?
What purpose do aftermarket uca's serve
Aftermarket CAs should serve a few purposes; flex better than stock, control axle movement, center the axle and correct pinion angle. The length of upper and lower control arms work together to control the pinion angle. You can use adjustable rear uppers to change your pinion angle, but rotating the axle back by lengthening the uppers without shortening the lowers will cause the wheel to be un-centered in the wheel well at full bump, especially with lengthened, fixed lowers like most kits include.
That being said, there are apparently some little knockouts on the UCA mount on the axle side that you can knock out and use a cammed bolt to adjust the pinion angle slightly. I just learned of this the other day and don't have any real experience with it. I do know cammed bolts have the potential to move around and loose their adjustment.
Jason is offline
post #812 of 8431 Old 05-03-2012, 07:14 PM
Jason
Adding too this:
If it was a hardline, replace them all now along with any other cheap componet while your there.
Use prebent lines unless your a pro with brake lines and the double flare tool. They may seem expensive, but they are so worth it. That is first hand experience btw....
I've replaced more hardlines than I care to admit, and never used a prebent one on a brake line. I keep 25 ft spools around for repairs. Unless you're doing a full replacement and/or a museum restoration, I don't see the need for the prebent lines. The bends on the repairs don't need to be perfect, they just have to function. Most people driving vehicles old enough be blowing the brake lines can't afford the full prebent replacements.
Jason is offline
post #813 of 8431 Old 05-03-2012, 07:32 PM
thunderdan2000
If you pump the pedal does it build pressure that goes away?
Nope, its dead all the way no matter how much I pump them. I have heard horror stories about the DYI brake lines. Could a wheel cylinder be a possible issue?
thunderdan2000 is offline
post #814 of 8431 Old 05-03-2012, 07:33 PM
--chris--
--chris--'s Avatar
I suggested pre bents for one reason only, for speed and ease of install.
I had to put all new lines on my yj last fall, I think the learning curve made it worse that it normally is, but getting the lines to follow the frame was rough, then getting the flare tool to flare correctly was hell.
I think my lines ran me $50 after mistakes. For $190 I could of had ss lines that were pre bent.
--chris-- is offline
post #815 of 8431 Old 05-03-2012, 09:02 PM
Jason
If you already pumped all the fluid out of it, it would not pump up. It could be a wheel cylinder, but blown line seems more likely. Have to find out where the fluid is leaking from.
Jason is offline
post #816 of 8431 Old 05-04-2012, 03:53 AM
thunderdan2000
Right now fluid is leaking ,INTO MY BASEMENT. I have a foot and a half of water and still rising. Sump pump don't fail me now!!!!
post #817 of 8431 Old 05-04-2012, 06:44 AM
Jason
Yeah, not kidding. It rained a bunch. I thought I had a leak in my basement, but it was condensation dripping from the pipes.
Jason is offline
post #818 of 8431 Old 05-04-2012, 07:26 AM
phittie1100
Needed a canoe to get to work this morning. Haven't seen flooding this bad around here in a long time. They are saying as much as 6.5" in the last 24 hours right in the bullseye...I live in Burton right on the right side of the bullseye.
http://www.weather.com/news/michigan...oding-20120504
Paul - 2005 Wrangler Unlimited
KD8PAV
phittie1100 is offline
post #819 of 8431 Old 05-04-2012, 07:33 AM
Jason
Should've taken a sick day!
Jason is offline
post #820 of 8431 Old 05-04-2012, 07:34 AM
--chris--
--chris--'s Avatar
No **** guys!
Yall really got it, e only got 2" here in Lapeer. Im glad i spent 4 hours transplanting my hedgerow of lilacs yesterday No watering needed today thats for sure lol....
post #821 of 8431 Old 05-04-2012, 09:56 AM
thunderdan2000
Just down the road from me. At least my house wasn't that bad.
So cheap, you are from Lapeer? I grew up there.
post #822 of 8431 Old 05-04-2012, 10:19 AM
Jason
All you guys east of me -- Any experience with HW Motorhomes in Canton? I might head out there this weekend to look at truck campers and toy haulers.
Jason is offline
post #823 of 8431 Old 05-04-2012, 11:11 AM
--chris--
--chris--'s Avatar
@ dan yep, im from lapeer-tucky. Born/raised.
We are somehow out of power lol...the lady at dte said we r part of 200 people out. Wtf
@ jason I can't comment. We did rent a rv from the place in birchrun, which we found a big nest of hay in the engine bay....after we drove it to apalachacola florida.
post #824 of 8431 Old 05-04-2012, 02:08 PM Thread Starter
JeepXJMike20
no power outage here but if i did i have a generator.
4.5" Rough Country x series lift kit/ lifted xj 31x10.50 15x8 4"backspacing cragar rims/ trimmed front rear fenders/custom swaybar quick disconnects/custom winch bumper w/ warn winch/custom roof rack/ lights mounted.
my build thread http://www.jeepforum.com/forum/f22/my-jeep-build-xj-1156115/index3.html
JeepXJMike20 is offline
post #825 of 8431 Old 05-04-2012, 02:57 PM
--chris--
--chris--'s Avatar
I picked up a subaru powered 6500 geny 3 years ago. I've used it atleast 6 times since then for power outages.
I can live without electricity, my wife however drives me nuts with boredom without juice.
Official Rothbury Thread tofuzeppelin Michigan Jeep Forum 3 12-20-2010 07:20 PM
