What did you do to your xj/mj/tj/zj/wj/wk/lj/jk thread - Page 442 - JeepForum.com
 1Likes
post #6616 of 8410 Old 07-16-2013, 05:49 PM
Jason
Originally Posted by thunderdan2000 View Post
I should let you borrow mine for a month. Your ocd could fix it up nicely. Lol
I can fix whatever you can afford.
The tire balance didn't take it all away. Still there a tiny bit. Found a little bit of play (2 mm?) in one upper ball joint. Replaced that and it's better. Not all the way, but mostly. I can drive 55 and it doesn't shake at all. It seems to now closer to 60, and again just the tiniest bit.
"Ugly Betty" Build - 97 TJ 5.9 Magnum / 46RE Swap
We're men! We don't need no stinkin directions!
Jason is offline
post #6617 of 8410 Old 07-16-2013, 08:00 PM
YoureverydayXJ
Originally Posted by Jason
lol. Yeah. Way ocd about the jeep. Especially steering. I got too much time and money wrapped up in this thing for it to be any less than perfect.
I bet WJ crossover setup with one ton steering won't have any shimmy
I just saw an XJ that did the swap, but kept the stock XJ steering (temporarily) and says it is driving great. I may increase the parts collection speed to get that done, since there is much left to desire on the front of mine.
The next expensive thing I buy will probably be some A/C for the house though. I'm dyin here.
'00 XJ not quite there..
'00 XJ parts donor, '98 XJ body donor
YoureverydayXJ is offline
post #6618 of 8410 Old 07-16-2013, 08:06 PM
Jason
The WJ bits would require new knuckles, calipers, etc., right? I'm thinking about getting a ZJ tie rod and ends since its about the only think I haven't replace yet.
I would die without A/C. You could get a window air conditioner temporarily, at least for the bedroom or living room.
Jason is offline
post #6619 of 8410 Old 07-16-2013, 09:03 PM
jtackerman28
Well the tie rod for a wj is longer. The axles are wider.
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #6620 of 8410 Old 07-16-2013, 09:57 PM
clgielin
2003 WJ
Bought a window unit for my rental house today! Someday I'll replace whatever tie rod(s) is bad on the front of my WJ and bring in down to GR.
Chris
2003 WJ 4.7L
Build Thread Here: 2003 WJ
Michigan Tech Jeepers #4
Utah JeepCrew #16
clgielin is offline
post #6621 of 8410 Old 07-16-2013, 10:20 PM
jtackerman28
Jeep loaded up for silverlake
post #6622 of 8410 Old 07-17-2013, 07:47 AM
YoureverydayXJ
Yep. I picked up knuckles a few weeks ago at the yard, but they didn't have the brakes I wanted. I've heard before that you can get loaded calipers from NAPA for decent. Still need those, ball joints, new unit hubs, and spacers. I put a V8 ZJ tie rod on mine last year. I'm happy with that for now, way beefier than stock.
And yes, I will probably end up with two small window units since my house is fairly small that will do fine. Better than nothing!
post #6623 of 8410 Old 07-17-2013, 05:35 PM
Rubicon0311
Plans are already in the process of being made.....
Rubicon0311 is offline
post #6624 of 8410 Old 07-17-2013, 06:05 PM
thunderdan2000
I am about ready to put the yj up for sale. It is really trying my patience.
thunderdan2000 is offline
post #6625 of 8410 Old 07-17-2013, 08:34 PM
Jason
Sounds fun. Do tell? I want to go west.
Now what?
Jason is offline
post #6626 of 8410 Old 07-17-2013, 09:19 PM
thunderdan2000
Originally Posted by Jason View Post
Now what?
I don't know, I was backing out of the drive way to get some ice cream with the fam and it stalled on me. It keeps acting like when you drop the clutch on a manual except I have an automatic. This happened once before but this time I wasn't able to get it started back up.
post #6627 of 8410 Old 07-17-2013, 09:26 PM
ashland82391
Out of money yet...Yup!
ashland82391's Avatar
Tps??
ashland82391 is offline
post #6628 of 8410 Old 07-17-2013, 09:28 PM
Jason
Tps??
This, or dirty air filter or throttle body components.
Jason is offline
post #6629 of 8410 Old 07-18-2013, 05:34 AM
Rubicon0311
Rubicon trail....no dates are set yet, but within the next year.
post #6630 of 8410 Old 07-18-2013, 06:20 AM
jtackerman28
The stalling is probably the iac. Idle air control. Mine went bad and did the same thing. At least that is the first place if start
Official Rothbury Thread tofuzeppelin Michigan Jeep Forum 3 12-20-2010 07:20 PM
