What did you do to your xj/mj/tj/zj/wj/wk/lj/jk thread - Page 405 - JeepForum.com
 3Likes
post #6061 of 8431 Old 04-29-2013, 07:55 AM
--chris--
--chris--'s Avatar
Looks like everyone had fun!
Can someone fill me in on soft tops with our jeeps?
The TJ has a Bestop replace-a-top (i think its the cheaper of the 3 options) thats about 6 months old. It fit ok during the winter. I say OK becasue the passenger side front area that connects to the top of the windshield has always had a slight "cracked window" noise and the driver/pass side rear section that tucks into the rails just below the rear windows (the windows next to the rear seat) pops out of the tracks every 50 miles or so.
Now that its warmed up and the sun is getting hotter, it fits poorly. I had my windows open Saturday and i noticed some noise from the rear window area. I look back and the whole soft top is undone where it connects to the tub in a 18" section on both sides. I stopped a few miles down the road, tucked it in properly, went into walmart then came out and drove home. Almost as soon as i hit 50 mph the back section popped out again. I cant keep it in the rail, nothing will keep it snug. It fits very very loose.
Is there a way to adjust the soft top frame? I need to remove about 1.5" of slack i figure.
--chris-- is offline
post #6062 of 8431 Old 04-29-2013, 10:35 AM
Jason
There's nothing that adjusts the top tension, except the latches at the windshield header panel. I assume you have those locked down (right??). If that top uses the factory frame, look at the two bows. There should be some webbing along the top that connects the bows. It's riveted to the bows and perhaps came undone. Maybe the top isn't fully attached to the rear bow? It just snaps on there.
You shouldn't have this kind of issue with a 6 month old top, so something probably came undone with the frame. My 8 year old OEM top is still nice and tight; I have to push down on the rear bow to gain enough slack to remove the "C-pillar" flap. The 97 has an aftermarket top (forget the brand) that is very tight. It's difficult to put up and down because it's so tight.
We're men! We don't need no stinkin directions!
Jason is offline
post #6063 of 8431 Old 04-29-2013, 03:28 PM
Rubicon0311
Helping my buddy get ready for Bundy this weekend
His jeep is running too rich, trying to figure everything out
Rubicon0311 is offline
post #6064 of 8431 Old 04-29-2013, 04:04 PM
--chris--
--chris--'s Avatar
Ill look it over, maybe somethings loose. It was barely noticeable in the winter when i got it (because it was cold im guessing). But its gotten pretty bad in the warmer weather.
Ill give it some eye balling tonight. If nothing, ill call best top and see what they say.
Also someone is coming from Everet (sp) MI, to look at/buy the welder tonight.
Attachment 618154
Mmmmm 8 cylinders of Jeep.
post #6065 of 8431 Old 04-29-2013, 09:05 PM
Ryanw10
Attachment 618154
Is that the blue yj that hangs around wmu?
Ryanw10 is online now
post #6066 of 8431 Old 04-29-2013, 09:24 PM
Rubicon0311
Yes
post #6067 of 8431 Old 04-30-2013, 02:45 AM
YoureverydayXJ
Needs more turbo?
'00 XJ not quite there..
'00 XJ parts donor, '98 XJ body donor
YoureverydayXJ is offline
post #6068 of 8431 Old 04-30-2013, 05:27 AM
--chris--
--chris--'s Avatar
Checked out the soft top bow, its snug as a bug. Nothing is loose as far as the frame goes. The header clamps are down and snug as well. Ill call best top and see what they think.
post #6069 of 8431 Old 04-30-2013, 05:31 AM
Jason
That webbing strap connected? I had to re-rivet mine a few years ago.
Jason is offline
post #6070 of 8431 Old 04-30-2013, 08:34 AM
Jason
Pretty good lightning show followed the rain this morning. Headed east for you folks out that way.
Jason is offline
post #6071 of 8431 Old 04-30-2013, 08:59 AM
thunderdan2000
So much for warm and cloudy. I had plans to work on the jeep today on my one day of break.
thunderdan2000 is offline
post #6072 of 8431 Old 04-30-2013, 09:02 AM
Jason
I think it should clear out by the afternoon. There was hail falling a few minutes ago....
Jason is offline
post #6073 of 8431 Old 04-30-2013, 10:25 AM
Ryanw10
Yes
My buddy Collin was telling me about that, sounds like a sweet rig
post #6074 of 8431 Old 04-30-2013, 06:21 PM
Rubicon0311
Fabricating some brackets for my tow bar...
post #6075 of 8431 Old 04-30-2013, 07:43 PM
TJeep32
2009 JK Wrangler
Plasti dipped my rims today, turned out pretty good
Sent from my GS2 using JeepForum
TJeep32 is offline
Official Rothbury Thread tofuzeppelin Michigan Jeep Forum 3 12-20-2010 07:20 PM
