What did you do to your xj/mj/tj/zj/wj/wk/lj/jk thread - Page 13 - JeepForum.com
 3Likes
post #181 of 8431 Old 01-18-2012, 03:13 PM Thread Starter
JeepXJMike20
Originally Posted by Jason View Post
You have a turn signal burnt out.
haha yeah i just looked at that picture going to put a bulb in.
4.5" Rough Country x series lift kit/ lifted xj 31x10.50 15x8 4"backspacing cragar rims/ trimmed front rear fenders/custom swaybar quick disconnects/custom winch bumper w/ warn winch/custom roof rack/ lights mounted.
my build thread http://www.jeepforum.com/forum/f22/my-jeep-build-xj-1156115/index3.html
JeepXJMike20 is offline
post #182 of 8431 Old 01-19-2012, 12:32 PM
HeavyArms
Cut it wide open!
Wiggle wiggle wiggle
HeavyArms is offline
post #183 of 8431 Old 01-19-2012, 08:32 PM
Jason
^^^ Mmmm. Boatsides.
I got the ****ing gears done. Glad I didn't settle for the first "final" set up. Found out that one of the bearing races was 2 thou taller than the other, throwing my pattern off on final assembly. Taking that into account, I got a much better set up, but I had to take the pressed on bearings and races out a few times. I'll paint up the axle for good measure and toss it back under the Jeep.
Next up is some JJs for the front axle:
Jason is offline
post #184 of 8431 Old 01-21-2012, 11:24 AM
Jason
Painted the rear. It's drying now. Since it's a summer only Jeep, it wasn't in bad shape, but since I had the axle pulled, figured I'd clean it up. The HP D30 is back on the operating table for the JJs I posted above, and final torque of the pinion nut. Never did that when I put it all together. Fear of commitment perhaps.
Jason is offline
post #185 of 8431 Old 01-22-2012, 06:42 PM
Jason
JJs are mounted on the front axle. I only tack welded the replacement for the bracket. I'll finish welding it after I test fit the front axle. Everything torqued and buttoned up. Hung it from a shelf upright in the garage to get it out of the way. Rear axle is all buttoned up, filled and back under the Jeep. Just need to tighten up the nuts and bolts and bleed the brakes, then it's done.
Running out of stuff to do.
Jason is offline
post #186 of 8431 Old 01-22-2012, 06:57 PM Thread Starter
JeepXJMike20
nice work man. i didnt do anything to the jeep over the weekend. i need to shime my rear axle a bit i got driveline vibe i can feel inside the cab nothing major even with a transfercase drop. going to get custom skid plates made soon for the jeep. and tax return is going to allow me go up to 4.5" lift kit. debating on doing it.
post #187 of 8431 Old 01-22-2012, 07:05 PM
Jason
Thanks. I think my next thing might be making a tire swing for my rear bumper.
What's the XJ skid plate like? Similar to a TJ? I've never looked.
Jason is offline
post #188 of 8431 Old 01-22-2012, 07:49 PM Thread Starter
JeepXJMike20
nice. they might be similar to a tj probley different measurements.
post #189 of 8431 Old 01-22-2012, 08:01 PM
Jason
I might be able to make one. Depends on what you have in mind.
Jason is offline
post #190 of 8431 Old 01-22-2012, 08:01 PM
beefcake3
takeing my block to a machine shop tomorrow to get bored hoping to get it running soon i really miss driving it
beefcake3 is offline
post #191 of 8431 Old 01-22-2012, 08:30 PM
HeavyArms
Started welding things up
post #192 of 8431 Old 01-24-2012, 07:46 PM
Jason
Rear axle is all snugged down.
I need to bleed the rears and adjust the parking brake. Need someone's foot to help with the bleeding.
Jason is offline
post #193 of 8431 Old 01-25-2012, 06:30 PM
Jason
Brakes are bled and beautiful. Wheels are back on and it's back on the ground. Parking brake needs to get done later.
Removed the license plate and mount. I might ditch the plastic mount. Cleaned up my fender flares.
Jason is offline
post #194 of 8431 Old 01-27-2012, 05:47 PM
Jason
Fender flares are reinstalled.
Where the **** is everyone?
Jason is offline
post #195 of 8431 Old 01-27-2012, 07:48 PM
phittie1100
SnoFari! 170+ people in West Branch this weekend, trying to make the most of a little bit of snow. Had good time today, more to come tomorrow.
Paul - 2005 Wrangler Unlimited
KD8PAV
phittie1100 is offline
Official Rothbury Thread tofuzeppelin Michigan Jeep Forum 3 12-20-2010 07:20 PM
